can you grease a sealed cartridge bottom bracket?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yes, i know...they're cheap enough to replace. but, long story short, just want to see if i can salvage this old yet high quality one that i have. it doesn't feel rough, just a little dry. so, can it be done? i don't care about worthy of time, but if i can save $20-$30 why not?
Bikes: Custom Ti Gravel Self built Force AXS 1 X 12, Allied Cycle Works All Disc Force AXS DT Swiss 1400 Spine, Santa Cruz CC XTR
Ditto to last reply, Outboard Sealed BB like FSA Mexaexo or Shimano Hollowtech can be done, but the latter is more difficult. Shimano has writing saying Don't disassemble on their outboard cartridges.
If it's old school like Isis or Shimano Octalink, that's a whole different story, Probably can be done, but I have neve done it.
Likes For oberwl:
Quoted: 83 Post(s)
Liked 64 Times
Have no idea what you’re looking at but most sealed bearings can be cleaned, greased & re-sealed in a pinch (or while waiting for new ones to arrive). Carefully use a pick to pry up the seal, being careful not to bend it. Clean & regrease, then pop the seal back into place. Done often on farm equipment where rpm and loads are much higher and time is critical. I’d always prefer to replace.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 303 Post(s)
Liked 136 Times
Plastic seals are easily removed and usually replaceable after cleaning and lubing the bearing. Metal seals are removable but
not nondestructively so replacing is difficult, main option is to remove bearing from BB remove one seal clean and grease and
reinstall bearing with intact seal to exterior. I resurrected a couple of Phil Wood BB that froze up when the grease turned to
wax over a 25 yr storage by popping out the seals and regreasing.
Likes For sch:
Quoted: 4201 Post(s)
Liked 3,857 Times
So the answer is that as long as you can get access to the cartridge seals you can flush and relube. But many cartridge bearinged BBs have that access somewhat blocked by the unit's construction.
My suggestion is to have the replacement on hand before trying to service the old BB, just in case... Andy
AndrewRStewart
AndrewRStewart
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 2363 Post(s)
Liked 1,749 Times
I believe RJ the Bike Guy has a youtube video on how to take apart and re-grease a '90s-era Shimano cartridge BB. At least one of the parts is reverse thread, IIRC.
Likes For madpogue:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
the drive side threads are reverse. i'll look that up on youtube. i've seen a lot of his videos. thanks!!
Liked 1,749 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
madpogue i found the video. i see what you mean about reverse thread...that is the lock nut for the cone
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Liked 3,857 Times
Park made a tool (BBT-8) for the lock and adjusting nut/cone for the earliest cartridge BBs (at the lower price points) they made. The tool is fairly uncommon and Shimano soon moved on from that BB design. I have one but no image to show. When I search for BBT-8 all I got were hits for more the modern BBT-18. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
The BB-UN55 and some similar Shimano models are put together in such a way that there is no adjusting of the preload. All the magic is in the geometry of the bearing-contacting surfaces of the spindle and of the main body.
Someone has gone there and shared the story: Repacking a Shimano BB-UN55.
Likes For John Valuk:
Park Tool BBT-6
Liked 3,857 Times
AndrewRStewart
AndrewRStewart
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
is there any chance in hades i could talk you into a picture or few of this tool? i can tell much by the drawn diagram in the shimano service link. i'm curious to make a tool, if possible. but, no big deal if you're not interested or just not possible. i don't have a camera or phone with which to do pictures myself. so, i'd understand whatever your case or inclination would be on it
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Liked 3,857 Times
AndrewRStewart
AndrewRStewart
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Liked 3,857 Times
Here's the tool. It will prove to be hard to dup as the sockets are so close to the same size and need to nestle with each other. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1062 Post(s)
Liked 665 Times
I serviced one of these, a number of years ago, on a cheap Gary Fisher mountain bike. There is a way of adjusting a cup 'n' cone bearing if you don't have the proper tools, that is a pain in the neck but can be done if you're patient, where you turn the cone in tiny incremental steps by pushing it with something, then tightening the locknut, and seeing if it feels right. Again, I wouldn't do it this way if I had access to the tools, but I would also not buy a tool set that cost more than a new modern BB.
It has lasted many years after that overhaul, though dedicated to winter service.
About the locknut, I would prefer plastic over aluminum, if threading into an aluminum shell, due to the likelihood of galling.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
