6 bolt and center lock compatibility
Old 04-08-22, 10:08 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
I'm thinking of building some new wheels for my wife's bike. I noticed that for the kind of hub she needs, a center lock hub is a little cheaper than 6 bolt. My question is: Will the disc be in the same position as on her old rear wheel, so that she can swap wheels without too much fuss? Or will she need to re-position the rear brake? Any other pitfalls that I need to know about?
Gresp15C is offline
Old 04-08-22, 10:58 PM
Kabuto
Kabuto's Avatar
Quoted: 174 Post(s)
Liked 78 Times in 54 Posts
Should be very close or the same. You may (or may not) have to reposition the caliper slightly. Same goes for a new 6 bolt hub anyway.
FYI there are adapters for converting 6-bolt discs to centerlock.
Kabuto is offline
Old 04-09-22, 08:16 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
Perhaps the centerlock hub will be cheaper but I believe centerlock rotors are typically more expensive than 6-bolt for equal quality.
HillRider is offline
Old 04-09-22, 09:07 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times in 1,439 Posts
Even if the new wheels were 6-bolt, she still might have to fiddle with the calipers when switching wheels, so I wouldn't base your wheel decision on that. But in theory, both 6-bolt and Center Lock place the rotor the same distance from the hub. If the 6-bolt rotor is slightly inboard compared to the Center Lock rotor, you could conceivably shim the 6-bolt, but not the other way around. Even then, the odds of getting both wheelset's rotors lined up exactly the same is remote. The good news is that making the necessary caliper adjustments will quickly become a two-minute operation with practice.
Hope this helps.
Rolla is offline
Likes For Rolla:
Old 04-09-22, 09:11 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2220 Post(s)
Liked 3,400 Times in 1,774 Posts
I use two very thin shims under my 6-bolt rotor to make it equivalent to the center-lock rotor on another rear wheel. The front wheels are interchangeable with no shims.
Polaris OBark is offline
Likes For Polaris OBark:
Old 04-10-22, 05:56 AM
richosti
Bikes: 1974 peugeot noveau folding (restored), 2016 polygon helios a9x, vivente world randonneur patagonia, merida e one twenty 500, new unidentified steel frame??
It should be similar but even with 2 of the same wheels you may need a little caliper adjust.
richosti is offline
Old 04-11-22, 08:45 PM
Gresp15C
Gresp15C's Avatar
Thanks, all!
Gresp15C is offline
Old 04-12-22, 03:47 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
They make shims to adjust minor differences so wheels can be swapped without fiddling with the caliper. I ordered a set of 4 with my centerlock wheel/hub thinking they might be hub-specific, but looking at them, they're certainly generic. You just need centerlock shims or 6 bolt shims. Search for shims online and look at Youtube for info on this sort of thing.
Camilo is offline
