What headset with hexagonal cups is this?
Quoted: 753 Post(s)
Liked 735 Times
I found this Raleigh Competition and it has a headset with "hexagonal" top and bottom cups. Can any one identify the make and model? Thanks
Likes For bark_eater:
Quoted: 753 Post(s)
Liked 735 Times
Yes sir..
Quoted: 3803 Post(s)
Liked 3,324 Times
Brampton Alatet
https://velobase.com/ViewComponent.a...m=111&AbsPos=9
those are not hexagons
count the flats; those are decagons
headlugs are Prugnat 62d
Brampton Alatet
Likes For juvela:
Quoted: 753 Post(s)
Liked 735 Times
Close. Decagons but no "teeth"
But here's one like mine. Thanks. The one I have is heavily indexed, but very cool looking. Any thoughts as to whether is worth finding another one?
Liked 3,324 Times
production life was long and there are variations
here is another -
note pattern of lock nut
https://velobase.com/ViewComponent.a...=111&AbsPos=10
quality of finish varies
your example is relatively late production and exhibits indifferent finish
races take 26 5/32" balls each and are not rectified after plating
head cup diameter is 30.0mm
fork crown race i.d. is 26.9mm
stack height is 36.1mm for your version; it is a bit greater for the toothed version
here is another -
Quoted: 753 Post(s)
Liked 735 Times
I have a NOS Stronglight Competition headset with the V races. Any thoughts on relative "performance"?
Liked 3,324 Times
these have rectifed after plating races which a plus
the V design spreads loads for each ball to four points instead of two
V races are less forgiving in terms of self-centreing than traditional cone & cup designs
so fitment is more critical
Quoted: 753 Post(s)
Liked 735 Times
Thanks!
Quoted: 3464 Post(s)
Liked 2,827 Times
TDC made a headset in a similar style.
often fitted to Bob Jackson’s in the 70’s
Liked 3,324 Times
one possible complication of fitting a Stronglight V-4 is the fork crown race
its i.d. is stepped with the lower portion for fitment to the fork crown being 27.0mm
the upper half is smaller and can be a problem in cases where the fork crown race seat is too tall
if you look closely at the manufacturer's illustration below you shall be able to see the feature -
stack height is greater than Alatet at 39.3mm
races also take 26 5/32" balls each
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Those were more durable in that the balls had two contact tracks on the race rather than just one, but they were very fussy about alignment. The later roller bearing models were more accommodating.
Old fart
Liked 3,395 Times
Magistroni made a headset with octagonal cups. The notched lockring on the OP's headset might be anomalous:
Likes For JohnDThompson:
Quoted: 753 Post(s)
Liked 735 Times
No steps on my example. The bit about being more dependent on alignment than needle bearing head sets is a little concerning, but I'm planning on keeping this bike, so it may be worth sending it out to a framebuilder for alignment and faceing.
Quoted: 1607 Post(s)
Liked 2,214 Times
Not Magistroni, Way-Assauto on the Bot.
VeloBase.com - Component: Way-Assauto (flats on cups)
P1030664 on Flickr
P1030664 on Flickr
Liked 3,324 Times
thank you for this clarification
the fitting in the middle of the photo appears too tall to be a fork crown race
it looks more like an upper head tube race
the fork crown race of the Competition V4 set has a thickness/height of 5.2mm
Quoted: 753 Post(s)
Liked 735 Times
I was digging through my stuff and I actually have 2 sets of Stronglight Competition headsets. The second has the step in the crown race.
