Indoor bicycle trainer help ?
Hi!
I have an old slightly bonked bicycle, and i was wondering if its possible to use with an indoor bike trainer?
The break pads on it were bent to the point they would dig into the wheel and stop the wheel entirely. But if i take them off, the wheel rolls just fine. Would it be possible to use it for an indoor trainer instead of throwing it away?
Quoted: 821 Post(s)
Liked 1,655 Times
Hi!
I've yet to need the brakes on mine.
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Most smart trainers warn riders NOT to use brakes on the rear drive wheel so taking those off would be recommended. Your front wheel never moves so no brakes required there either. Great option for a dedicated trainer bike and will save you a trip to the dump.
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
aren't smart trainers that use the rear wheel driven by the wheel? if so, what the cautionary note about not breaking?
Quoted: 548 Post(s)
Liked 473 Times
Can't give you the mechanics behind the statement but it's written right in the user's guide. See the explanation here
Liked 1,182 Times
i really don't get their explanation. the conditions they describe are not much different from braking while descending.
only once did i brake while on the trainer. it was when i started Rouvy and came up to a round-a-bout with a car next to me and a pedestrian starting to cross. i braked for him then realized i didn't need to do that. got me laughing for sure.
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
I've got too many indoor solutions in my basement. Dumb trainer w/ mag flywheel, kreiter rollers, a wahoo smartie w/ a pretty fat flywheel. There is no flywheel on any *bike* trainer that weighs enough to matter in this context. Those directions seem pretty silly to me.
Quoted: 2952 Post(s)
Liked 3,106 Times
Randomhead
Liked 3,696 Times
On wheel-off trainers the brake pads would be hitting air. I don't see why you would brake a wheel-on trainer though, but I don't really see the harm in it either. Other than you would wear the tire slowing down the flywheel.
Quoted: 548 Post(s)
Liked 473 Times
The other thing is if you are riding a wheel on trainer and your chugging along at a good cadence and suddenly put on the back brake, that roller will continue to spin at the cadence you were riding which will be rubbing into the tire. Not sure how much damage that could cause, but probably the reason the manufacturers recommend not to do it.
Liked 3,106 Times
Liked 1,182 Times
Likes For spelger:
Quoted: 548 Post(s)
Liked 473 Times
Likes For gthomson:
Liked 3,106 Times
