Are waterproof bike covers necessary?
Old 06-09-22, 10:22 PM
rbloem
Quoted: 18 Post(s)
I picked up one for $30. Is there another way to protect bike from rusting. Bolts, pedals etc? Is a bike cover even necessary?? I use it for commuting but store it in my garage when at home.
rbloem is offline
Old 06-10-22, 04:04 AM
Trakhak
Quoted: 1186 Post(s)
Liked 1,093 Times in 637 Posts
Waterproof bike covers promote condensation, which increases the rate of rust formation. Best to use such a cover only to protect the bike from rain and then remove the cover when the rain stops.
Trakhak is offline
Likes For Trakhak:
Old 06-11-22, 08:13 PM
poetman
Quoted: 40 Post(s)
Liked 5 Times in 3 Posts
I have a tarp over my family's bikes, but the bottom is generally open for air to pass through. Do you think that helps avoid condensation/rust?
poetman is offline
Old 06-11-22, 08:51 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 3489 Post(s)
Liked 2,267 Times in 1,473 Posts
I've had (and have) city bikes where I use lubricants for their ability in the wet, chose parts accordingly and paint the bikes with appropriate paints. 2-part brushed epoxy, powdercoat. Marine grease aka boat trailer hub grease in bearings (lots!) and all threads (and on any metal having water issues). Finishline wet lube for the chain. Seats with plastic covers and/or a produce bag to put over them when I park the bike. The only things those bikes don't really like is going into puddles deeper than the bearings and even then, with enough marine grease stuffed in, many bearing do fine.
79pmooney is offline
Old 06-11-22, 11:40 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2764 Post(s)
Liked 1,579 Times in 1,030 Posts
You can buy your way out of it somewhat. Pricier bike components are usually anodized, stainless, or nickel plated, or at worst chrome plated and powder coated. Cheaper ones might be black oxide coated or galvanized. Better components also have better ball bearing seals, especially for MTB parts. On the other hand leather saddles and grips and luggage are more susceptible than plastic. Waterproof luggage is made from waterproof fabric, but if it's leather or heavy fabric like a book bag it needs wax.
Kind of depends on the water too. Coastal areas are going to get salty corrosive moisture
Genesis 49:16-17
Darth Lefty is online now
