Intriguing Raleigh, what model is it?
Señor Member
Quoted: 1491 Post(s)
Liked 1,089 Times
Any chance you can post the serial number on the bottom bracket? Likely starts with "W".
First guess - a 1979-ish Competition GS.
Likes For USAZorro:
Quoted: 3803 Post(s)
Liked 3,324 Times
+1
mechs, wheels, pedals, stem & saddle not original
appears photographer has a Rizzato product as well...
+1
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
+1, that looks like a competition G.S. with a swapped rear derailleur to me.
I am working on what appears to be the same frame now. Most of my components don't appear to be original. Based on help on the forum, and some serial number research I believe mine is a 1977 GS. Yours has the same brake and shifter cable braze ons as mine which I had not seen in the on line Raleigh catalogs. Until seeing yours I though they may have been added later as mine has been repainted. Do you have water bottle bosses on the down tube? The post for mine is here if you are interested:
https://www.bikeforums.net/classic-v...ying-bike.html
incazzare.
I thought so at first, but I don't think those had braze-ons on the top tube for the rear brake housing. At least, the '79 I had didn't.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
I also tend to agree that it is a Competition GS. The frameset, 3 arm crankset, and Weinmann brakes pointed that out to me. Front and rear derailleurs have been changed.
Quoted: 702 Post(s)
Liked 671 Times
The front wheel looks extremely close to the down-tube. Did the later GS's have tighter wheel-bases?
for comparison...
for comparison...
Quoted: 702 Post(s)
Liked 671 Times
It looks like they did tighten up the wheelbase in the 1977 model
Quoted: 1815 Post(s)
Liked 1,693 Times
I love that version of the Competition. When I bought my Raleigh Professional in 1973, a couple of my friends each bought a Competition just like that one. Despite the fact that my bike cost a couple of hundred dollars more, their bikes were slightly lighter and had the same beautiful slope crown fork that my Pro had. Love those Huret Jubilee derailleurs. At the time that bike was a phenomenal bargain
Likes For alcjphil:
Same color as the 1982 GS I have had since new. If memory serves well, the Japanese built GS had brazed on cable guides, but the Carlton GS did not. I am old, so don't trust my memory.
Quoted: 3464 Post(s)
Liked 2,827 Times
looks pushed back at the steerer above the crown or at the crown.
Suggest Drop the fork. the upper 4-5 inched of the blades should be aligned with the steerer, front and back, uniform.
I don' think so to quote Ricky Ricardo.
Quoted: 872 Post(s)
Liked 2,270 Times
I have an original condition 1977 (November) Competition GS , no braze on cable guides or shifter bosses. It is light and tight and a lot of fun to ride.
Non original front wheel , maybe a 27”? It looks too close to downtube.
Señor Member
Liked 1,089 Times
I'm not seeing anything that's an exact match in catalogs. The lugs, and cable guides suggest Japanese frame. The chrome and Campagnolo dropouts suggest not. I was hoping that a serial could at least pin down the year.
Quoted: 175 Post(s)
Liked 305 Times
The headbadge says Nottingham whereas my 1981 GS was made in Japan and says /////// on the headbadge. It also has the 5 arm GS crank with what I think is a 1980 date (0 in a circle)
Quoted: 1854 Post(s)
Liked 661 Times
The headbadge is put on with pop-rivets. Is it even original? If not, and with no S/N, I don't see what indicates the frame is even a Raleigh. The headbadge design is quite traditional, but is it too traditional? Not to say it's a bad frame, it looks good.
What are the front and rear dropouts? Chainstay lengths match?
The fork crown looks sloped in the scanned catalog pics, but seems to be more square in the bike pics. Do the fork blade cross-sections match what Raleigh used? Front wheel radial clearance is very tight - is that wheel/tire to original spec?
I'm not sure it's even a Raleigh.
Señor Member
Liked 1,089 Times
Liked 661 Times
The steerer is likely bent a bit - which could account for the clearance. Also, the OP hasn't stated there's no serial number - simply hasn't posted it, or about it. I'm not discounting the possibility that it isn't a Raleigh, but there was recently another frame that someone was asking about from roughly the same era, and with attributes (including the top of top-tube guides) that didn't match catalog pictures either. However, it did have a "W" serial.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Forks are bent without a doubt. Look at the bottom 1/3, the graceful curve is gone. Does look like a late 70 "s Comp GS, same about the forks.
