How to patch a tire using a jacket liner
Old 06-28-21, 05:22 PM
seibaatgung
Quoted: 169 Post(s)
Liked 26 Times in 17 Posts
Originally Posted by dabac
Tires are more than rubber. They have a reinforcing layer of threads. You might have seen tires listed as having this-or-that TPI - threads-per-inch. For any chance of a lasting repair your patch needs to have a similar structure.
I've used patches cut from an old jacket liner. I work liquisole into the patch until saturation before applying over the cut. For a road tire I'd patch both sides. You might want to stitch the cut closed first. And clean/roughen the surface first. I've used abt 15 mm overlap.
Does anyone know what dabac means by a jacket liner?
seibaatgung is offline
Old 06-28-21, 05:41 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
I would imagine that it is the polyester sateen material which lines the inside of an outdoors jacket.
dsbrantjr is offline
Old 06-28-21, 05:47 PM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
By jacket he means something you wear in cooler weather. Some jackets have internal liners, that is an additional layer of fabric on the inside. He has cut a piece of fabric from the internal liner of an old jacket, and glued it to the inside of a tire, to patch it. It is necessary to use appropriate glue.
This could be used where a tire is split, and pumping it up would open up the split. The fabric glued to it, holds it closed.
alo is offline
Old 06-28-21, 05:48 PM
alo
Quoted: 529 Post(s)
Some people have used ordinary patches on the inside of tires, but they have not been strong enough.
Another option is to glue a thicker piece of rubber to the inside of the tire.
alo is offline
Old 06-28-21, 05:51 PM
seibaatgung
Quoted: 169 Post(s)
I'm a native English speaker. I know what a jacket is and that they usually have inner mesh layers but was confused as to how that sufficed to hold the tire together. Anyways I'm not totally sure how it would work for a sidewall slash.
Like a radial patch for a car tire?
Old 06-28-21, 06:00 PM
Troul
Troul's Avatar
Liked 2,936 Times in 1,900 Posts
Conditions & options are not predictable, but if it were I, I'd use the old tube & double patch the tires problem area. Then install the new tube.
-Oh Hey!
Troul is offline
Old 06-28-21, 06:35 PM
seibaatgung
Quoted: 169 Post(s)
I'm tubeless
Old 06-28-21, 08:15 PM
alo
Quoted: 529 Post(s)
You could use anything that is strong enough. For example, you could cut a piece of rubber from a truck tube, and glue it inside the tire.
You could even use two layers.
You need an appropriate glue.
Another option would be to cut a piece of rubber from the sidewall of an old tire and use that.
alo is offline
Old 06-28-21, 08:21 PM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
I think dabac is just using his smarts to improvise with a perfectly good solution and anything that is a light, strong and non-elastic woven material should work. Regular tube patches are a poor solution for cuts as they can stretch rather than hold a cut closed. They can work for small cuts and emergency repairs but not as strong as a proper patch. There are special patches made for cuts in tubeless tires as well and his suggestion to sew the cut together first is a good one.
Crankycrank is offline
Old 06-29-21, 06:12 AM
Troul
Troul's Avatar
I'm tubeless
That blows.
-Oh Hey!
Troul is offline
Old 06-29-21, 06:44 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
Perhaps spinnaker cloth would work?
JohnDThompson is offline
Old 06-29-21, 06:47 AM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Liked 204 Times in 151 Posts
That blows.
Or sucks, if you are in deep water.
Geepig is offline
Old 06-29-21, 07:16 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
fwiw - I started carrying these a while ago. I use tubes, but I suppose they would work for tubeless, no?
Park Tool TB-2 Emergency Tire Boot (Pack of 3)
rumrunn6 is offline
Old 06-29-21, 07:25 AM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,436 Times in 4,663 Posts
If the cut is big enough that the area bulges, I'd personally pitch the tire. If the cut is small enough that it doesn't bulge, a regular inner tube patch kit will suffice.
WhyFi is offline
Old 06-29-21, 09:19 AM
Trakhak
Trakhak's Avatar
Quoted: 2468 Post(s)
Liked 2,944 Times in 1,671 Posts
Best fix for tire slits: Tyvek from FedEx shipping envelopes. Cut a piece from the flap of the envelope, peel off the paper that covers the adhesive, and apply. I always use two pieces of the Tyvek, one on top of the other, with the fibers in the patches oriented at 90 degrees to each other.
Trakhak is offline
Old 06-29-21, 09:40 AM
squirtdad
squirtdad's Avatar
Quoted: 2336 Post(s)
Liked 2,804 Times in 1,532 Posts
get a new tire....that simple, especially tubeless or put a tube in and get some more miles on the tire
squirtdad is online now
Old 06-29-21, 10:11 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
There are TL patches meant for TL tyres, made with a reinforcing ply of "cloth" They are usually a different colour identify and separate them from ordinary tube patches I believe the Rema ones are blue. For instance the Rema tip top tt13 set of patches and glue.
Racing Dan is offline
