Consensus on vintage binder bolts?
Quoted: 189 Post(s)
Liked 468 Times
Learning about the vintage bike world comes in phases. I'm in the seat binder bolt phase...
So...I think I need a Campagnolo seat binder with the serrated edge on one side, versus the "key" found on Sugino binder bolts. Are there alternatives to the Campagnolo binder or is it simply a ~$75 part you have to buy? If not, is there an alternative?
Quoted: 3766 Post(s)
Liked 3,256 Times
IIRC there were several makers who did the serrated type
some names recalled include REG, ROTO, Zeus
I never use a Campagnolo binder bolt after breaking 2.
Semper fi
Semper fi
Quoted: 189 Post(s)
Liked 468 Times
So I’ll be looking for a vintage used binder bolt? Is there anything new that mimics the old Campagnolo one? Do people just use one without the ridged side that is fixed and use washers on both sides?
There are non keyed binder bolts out there, I can’t recall the name though. You can always file the key off a Sugino. I have one bike that I ended up using some form a bolt with what I’m pretty sure is a chainring nut.
For the record, I’ve never broken a Campy binder bolt, but will now carry a spare because I’ve just tempted fate.
Likes For Spaghetti Legs:
Stop reading my posts!
Quoted: 1408 Post(s)
Liked 1,025 Times
Also Simplex.
FWIW I don't think the serrations actually do much especially after they have worn the inner surface of the seat lug ears and/or been worn too smooth to "bite", so I have no qualms about using an Asian bolt with the "tab" ground or filed off smooth.
Those cost far less than $75, even after I pay myself for the highly skilled labor of grinding and filing!
Bikes: Yes
Quoted: 3228 Post(s)
Liked 3,848 Times
I've done this a couple of times recently. A cheap $8 new binder bolt plus a minute with the Dremel tool and Bob's your uncle.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 4719 Post(s)
Liked 3,034 Times
Campagnolo binder bolts were the worst. We got generic, Japanese, CrMo bolts that were far superior. When we couldn't get them, we used Sugino bolts and filed the key, when necessary.
Likes For T-Mar:
Friendship is Magic
Bikes: old ones
Quoted: 26212 Post(s)
Liked 10,179 Times
...I have busted a couple of those Campy seat binder bolts, one while installing, and one in use. which is a literal PIA. I. too, just file off the tab on the Asian one. Never broke one of those. Cinelli makes a kind of deluxe one, to fit the SC frames, but I don't think they work on anything else. And they're not cheap.
Quoted: 2986 Post(s)
Liked 3,670 Times
Likes For iab:
Friendship is Magic
Bikes: old ones
Liked 10,179 Times
^^^^cool^^^
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
The Campagnolo binder bolts have a reputation for breaking. I've broken two already. As others have noted, Campagnolo isn't the only game in town. Zeus binder bolts were the go-to alternative BITD, but others from REG, Roto, Gipiemme, and probably others can be found. Worst case: grind the key off a Sugino bolt and use two Allen wrenches when you secure the post.
Crawlin' up, flyin' down
Quoted: 996 Post(s)
Liked 2,444 Times
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 320 Post(s)
Liked 672 Times
I once broke the Simplex seat binder bolt on my PX10 and it sure was easy. I’ve haven’t broken a Campy bolt yet but it’s a near certainty that I will. I recently replaced a quick release seat bolt with a cheap Campy (style) bolt from my LBS, I think it cost me about $10 or so.
Quoted: 1598 Post(s)
Liked 2,181 Times
Broke one and ordered 2. Need to be gentle with them. The serration is useless. I always use two Allans. The force on the bolt is on the post side. When it is tightened , a bending force is applied to the bolt, stretching the post side. As you tighten it, the stress increases with the rotation with deformation rotating with the screw on the threaded side. Then POP!
blahblahblah chrome moly
Quoted: 1150 Post(s)
Liked 2,499 Times
The Campy bolt for normal lugs with an 8 mm hole has a 6 mm thread. All the clones too, Zeus Simplex Sugino etc. Even the Richard Sachs, better metal no doubt but still just M6. I have a Jim Merz Campy clone in 6/4 Ti, but still just M6 thread.
The older style of bolt was 8 mm with an external nut on it, a bit heavier and the wrench to fit it is a lot bigger/heavier, not something you'd want to bring with you. But if you want one, you won't find one nicer than this Cinelli, for sale by Boulder Bikes
You definitely won't break it!
Another option might be the best of both worlds, the Campy 10 mm seatpost pinchbolt, which has an 8 mm thread. Godlike reliability, light weight, and takes a 5 mm allen wrench.
Downside is you need to drill or ream the hole in the seat lug to 10 mm, and then forever after you'll be stuck with this 10 mm bolt. Hardly anyone else made them in that size, though some triple chainring bolts work in that location. In fact the Campy 10 mm seatpost bolt is hardly any different from their triple chainring bolts, other than the female side has knurling on the seatpost bolt, versus two tiny notches for a chainring nut spanner.
Some frames can't be embiggened to 10 mm, and even if you can, finding one of these rare Campy bolts isn't easy. They were never popular. Triple chainring bolts are a thousand times easier to find, and they work great. Functionally just as good as the rare Campy seatpost bolt, but not as pretty on the backside, not bright chrome plated, no iconic 'Patent Campagnolo' stamping. I put one on my '71 Super Course in about '72, just about the first upgrade I did on the bike. Found the chainring bolt in the bikeshop's junk bin, a lonely triple bolt, good for nothing else when you don't have 5 of them, so it was a free upgrade. (Or maybe I just palmed it without telling the boss. Don't rat me out OK?) The Nervex Pro seat lug was very easy to embiggen to 10 mm. I think I used a tapered hand reamer. That part is still on that bike to this day. I still have the bike, one owner for 50 years.
Mark B
Mark B
Quoted: 4183 Post(s)
Liked 2,903 Times
Richard Sachs sells fancy campagnolo-style binder bolts but with slightly rounded fixtures to that they can pivot in the hole as the ear alignment changes as you tighten the bolt, but I think those run in the $50-60 range. IRD also used to make a keyless bolt that sold in the $15-20 range, but, when I looked this spring, no one had them in stock.
Bikes: Road: 1972 Raleigh Competition,1989 Marinoni, 1990 Limongi. MTN: 1990 GT Team Avalanche, 1991 Rocky Mountain Blizzard, GT Team RTS , Rocky Mountain MSL 50 Element, CCM fat bike
Quoted: 33 Post(s)
Liked 79 Times
I see them on Amazon with a key ridge for about $10. If the length is listed as 16 mm, does the represent the minimum or maximum opening?
Liked 2,181 Times
The RS kit is $54 the bolt itself is $39.
Likes For SJX426:
