Caliper for brake rotor recommendation please.
I want to check my rotors to be sure they meet minimum thickness. There are tons of inexpensive electronic calipers available on Amazon, but I thought I'd check here first. I see the ones that have probes that look like pliers, flat surface, and I also see the ones that come to point. Seems to me the ones that come to a point would be best for measuring something flat like a rotor, no?
The one's with points have long arms, so I also wonder whether they're likely to get hung in in spokes.
What are you all using?
Thanks..
Thanks..
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
Something like this is fine and they have plenty of room to get in where you need to go:
https://www.ebay.com/itm/274400814814
Plastic may seem cheap, but this type is actually pretty good. If you feel fancy spring the ten buck for metal ones.
Something where the contact surface is a point is not good because rocking the calipers around will cause you to measure diagonally through the disc, which will give a false reading, too thick.
Quoted: 1438 Post(s)
Liked 1,092 Times
Quoted: 6178 Post(s)
Liked 4,795 Times
Calipers should work. Just make sure to get the edge of the disc into the relief of the jaws. A micrometer will eliminate all worry, but mic's are more accuracy than is needed for this.
I bought this one. I think it hits the sweet spot for my purposes. It has 4.5 stars on Amazon, and the reviews seem consistent. https://clockwisetools.com/products/...=5455899525149
Just wanted to update. After further deliberation, the micro I finally decided on was this one, rather than the one from the Far East. It's manual Mitutoyo in metric, measures to the hundredth of a millimeter. Only $50. It's a really quality tool, one which I'll probably pass to my heirs. Although I forget exactly when I last replaced the rotors, I know I did it within the last 2-2.5 years. I use metallic pads on Shimano 160mm Icetech, and they're pretty worn down, 1.6mm on the front, and 1.53mm on the rear. I ride in a lot of dirt, often wet dirt, so I guess that's why they wore so quickly. New is 1.8mm, and 1.5mm is the minimum...time to replace. I thought it interesting that the rear wore faster than the front, but then I remember that I used to think it was a good idea to use the rear brake near-exclusively on dirt. That's changed after I learned the hard way that the rear brake is almost useless on gravel, packed dirt, when you're going down an incline (decline?), even a very shallow one. That lesson only cost me a cracked rib. 😜
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
