Q's while watching the TdF 2021 ...
1. Watching a mountain stage that featured constant cold rain and 45 mph downhills: is there such a thing as rain tires for bicycles? Like car and motorcycle tires get, some rubber compound that grips better on wet surfaces?
2. How come just about every cyclist out there is clean shaven? Athletes in other sports who are in their 20s and 30s have some hip-looking growth. Is it aero something? Or tradition?
3. What is the point of "chasing down" a breakaway rider, especially uphill? So the pursuit riders catch up with him ... then what happens? They can't slash his tires.
4. After a big crash and pile-up .... how do they sort out or assign times to the riders caught in the pile-up, whether they are injured or not, or their bikes broken or not?
5. Mountain stages: what's a typical rear cassette gear pack? They have big gears for the brutal uphills but also tiny gears for downhills - I see them pedaling for more speed when they're already going 45+ mph. Related Q: Do riders ever use triple chainrings?
=K
=K
Likes For KiwiDallas:
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
The high tire pressures and relatively low speeds of road bikes make them generally immune to hydroplaning, so there's no point making tires with channeled tread patterns. Some tire manufacturers do put shallow "herringbone" tread on some tires in an effort to improve wet grip by getting the rubber to interlock with road irregularities, but there doesn't seem to be consensus on whether this has any actual efficacy.
Oftentimes racers will run a bit lower pressure in nasty conditions.
Shaving the arms and legs, however, has a tangible aerodynamic benefit. And if a crash occurs with nasty road rash, things clean up far better if there's no hair.
If you're well behind someone at the top of a climb, but you want to catch up with them, you'll potentially need to spend a lot of time on the subsequent descent and flats putting out a bigger effort than them in order to do that.
But if you catch someone before the crest, you can use their draft to keep up with them at much lower effort. Or the two of you can work together, trading turns at the front of the pair, so that the two of you are able to ride faster than if you were each solo.
There is the "3km rule": if you crash or suffer a mechanical in the last 3km of a stage, and riders from the group you had been in continue up the road and finish ahead of you, then when you cross the finish line you're awarded the same time as those riders.
Other than that, being in a crash basically just sucks, and any time lost due to injuries or bicycle damage is just lost.
On mountain stages, big cogs in the ballpark of 30T or even larger sometimes show up.
Likes For HTupolev:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
They won't use triples because of tradition essentially. I often theorize that will change in the future. In general triples aren't as clean shifting as doubles. Anyway - back in the day they would put a 27 tooth cog on the back with their 53/39. Then they used compact cranks. Then we widened out the cassettes. Today it's simply a combination of what is available to the rider through the team gear and what they want to use.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Thanks for the detailed replies; I appreciate those - and I'll head over to the "Pro Cycling Fans" section for more info (didn't know it was there).
=K
=K
Habitual User
Quoted: 4942 Post(s)
Liked 8,081 Times
Very often, it's defensive tactics. If the rider up the road is a potential threat to your team's top-placed GC rider for overall time, chasing down that rider eliminates any time advantage that rider might have gained at the finish of the stage. For flat stages, a team may work hard to chase down a breakaway so their sprinter still has the opportunity to win the stage.
Likes For Eric F:
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,277 Times
Incorrect. The wind doesn't care [sic] where on your body the hair is so long as it's exposed...so if facial hair "has very little impact on aerodynamics" than so too does arm and leg hair.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I eat carbide.
Liked 1,306 Times
Ahh.... the wind tunnel.... where every bicycle race is conducted.
Quoted: 2952 Post(s)
Liked 3,106 Times
Correction. That's not a wind tunnel. It's the *Win* Tunnel.
Likes For caloso:
I eat carbide.
Liked 1,306 Times
Quoted: 1221 Post(s)
Liked 629 Times
It's how the Slovenians crush dreams. Sometimes you risk repeatedly getting slammed to the ground and withdrawing from the race because of it.
Likes For ksryder:
Quoted: 4396 Post(s)
Liked 4,842 Times
There are guys in the peloton that often have facial hair e.g. Thomas De Gendt always does and Peter Sagan sometimes.
Quoted: 6193 Post(s)
Liked 4,808 Times
I thought the clean shaven was mostly because so many are still young and would be really scraggly looking trying to cultivate facial hair
Quite a few of the older guys sport a beard or mustache or even the Don Johnson/Miami Vice look. But by far most are clean shaven. Just like most of those I see day to day that aren't pro cyclists.
Liked 4,842 Times
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,593 Times
I thought F1 races were won or lost in the pit stops.
Likes For cb400bill:
Habitual User
Liked 8,081 Times
Quoted: 18409 Post(s)
Liked 15,530 Times
“If you’re not first, you’re last.”—R. Bobby
Likes For indyfabz:
Liked 15,530 Times
Klaatu..Verata..Necktie?
Quoted: 10422 Post(s)
Liked 11,884 Times
Except for the actual scientific wind tunnel tests that proved otherwise. Facial hair made no appreciable difference, but shaved legs saved about 82 seconds over 40 km. Facial hair made no appreciable difference, but shaved legs saved about 82 seconds over 40 km.
EDIT: Did they test different densities of leg hair? I mean, there's the kind that you can barely see, and then there's the sort that so thick it looks like socks.
Likes For genejockey:
Liked 4,842 Times
Bikes: yes
Liked 643 Times
Wait, so shaved legs (82 sec/40km (or 25 miles)) work better than a lighter bike (30 seconds/100 miles, based on a long, argumentative thread)?
It's an interesting series of videos, they did ones on various types of cycling clothing, haircuts, etc. I'm certain I watched one where they tested shaved arms (they actually make a bit of a difference if I recall) but I can't find it now. Bottom line is aero is pretty important.
Liked 9,456 Times
You know in one of the videos they actually talk about where their test subjects ranked on the Chewbacca scale.
Likes For WhyFi:
