Rene Herse sued over tubeless tire blowoff on hookless rims
Sunshine
Quoted: 10956 Post(s)
Liked 7,485 Times
https://www.bicycleretailer.com/indu...9#.YlA8oMjMKUk
RH has changed their guidance at least a couple times in the last 4 years, right? At least thats how it seems.
Tubeless for road is still a mess, despite what a few on here claim. It just is. Between higher pressures, rims that are cheaper to make being pushed as better, and sizing of both rims and tires being less than ideal...it is a mess. There is simply no other honest way to assess the situation from 30,000 feet.
Maybe nothing comes of this? Or maybe more uniformed tolerances are pushed more quickly?
It says Little had researched the Compass tire model on the brand’s website and concluded it was an appropriate fit for his rims. He said nothing on the company's website or the tire’s packaging suggested the tire was inappropriate for use with hookless rims. The complaint alleges that the company was aware of other consumer complaints about the tire model blowing off hookless rims.
The suit alleges that after the crash Little sent the tire to Rene Herse for inspection and that the company later told him they had lost the damaged tire despite promises to return it.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
As for the lawsuit, Rene Herse’s big problem is spoliation of evidence in not preserving the tire. At a minimum the plaintiff gets a jury instruction that the tire would have been helpful in proving their case.
As for tubeless road being a mess, I think you’re painting with way too broad a brush. The issue here appears to be whether this particular tire was safe to use with hookless rims.
The one incident may or may not tell you much about hookless rims with other road tires. And it tells you nothing about road tubeless on hooked rims.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
pan y agua
Liked 724 Times
Also, being a defense lawyer, I may not be very sympathetic to plaintiffs, but who files a law suit over what essentially appears to be some road rash?
Any tire can blow out and lead to a fall, for any number of reasons. It’s a risk inherent in cycling. When the adverse consequence is some road rash and a pulled muscle, put on some tagaderm, and suck it up.
Sunshine
Liked 7,485 Times
Industry news op-eds write about the confusion. Industry insiders have discussed the frustration.
It sure doesnt seem like too broad a brush. Saying its a mess seems very much on point.
Likes For mstateglfr:
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I have some Compass [sic, NOS] 38mm Barlow Pass tires on my (hooked, tubed) rims now. I think more changed than just the Rene Herse label, and that the ones that actually say "Compass" on them, even if they are NOS, aren't "tubeless ready." They don't say "don't use as tubeless," but I got the impression somewhere that I shouldn't.
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Am I though? You have rim/wheel brands that specify which tires they accept on their wheels. I would say that alone is clear evidence that road tubeless is a mess. Tire brands and wheel brands are both constantly checking compatibility for safety. Users at home are constantly confused as to what will or wont work and what combo of tire with their rim will actually even mount without using a mounting tool that looks like the Jaws of Life.
I haven’t mounted a tubeless tire with any other than my hands in over two years. Everyone paints tubeless as this horrible to maintain process where it’s really not much more effort than a tubed tire- again jmo
Likes For phrantic09:
Liked 3,434 Times
The problems with "road" tubeless, specifically (which is what mstateglfr was focusing on), are the much higher pressures and typically narrower tires. The current Rene Herse (formerly Compass) recommendation is not to use tubeless for anything less than 35mm tires. The wider tires like the 38mm Barlow Pass are run at much lower than typical road pressures (eg: 40 psi vs 80+ psi).
Likes For Polaris OBark:
pan y agua
Liked 724 Times
Admittedly, there’s some confusion to sort out, as different manufacturers take different approaches. However, like most things it will sort itself out.
And even now, many of us seem to be successfully managing putting the right tire in the right rim. It”s not rocket surgery.
Sunshine
Liked 7,485 Times
^ I call that 'a mess'. It certainly isnt a harmonic and tidy process.
Quoted: 3949 Post(s)
Liked 7,295 Times
Liked 3,434 Times
So you need to know that your tire is compatible with your rim, and you run appropriate tire pressure.
My kid is running 23 mm Vittoria tires tubeless at high pressure on Bontrager carbon rims. Supposedly this will work fine (and so far it has), but I wouldn't be a bit surprised if he blows a tire off. I had a tubed 28mm Vittoria blow off a hooked rim. Shyte happens. If it happens at high speed, the results can be problematic.
Quoted: 20810 Post(s)
Liked 9,456 Times
I guess that I don't understand why people that think XYZ is a mess don't just leave well enough alone from XYZ.
I have TSS wheels (Zipp 303S) and I know to pair them with tires that the manufacturer has stated are compliant with ETRTO TSS standards - simple enough. If one wishes to avoid that kind of "mess," fine, but it's dreadfully tedious to defend the hyperbolic admonitions being hurled from people on the sidelines.
Likes For WhyFi:
Liked 7,295 Times
Liked 7,295 Times
Liked 9,456 Times
Liked 7,295 Times
Liked 9,456 Times
Okay, sure. So why not just wash your hands of it and be done with it? Those that are comfortably navigating the waters don't need to constantly be told about how treacherous it is from those on shore.
Likes For WhyFi:
Liked 3,434 Times
My main point is the 38mm Barlow Pass tires may have changed as well since 2019. About six months ago I purchased some "Compass" 38mm Barlow Pass tires from a LBS, which presumably are NOS dating to 2019 or before (when the name and label changed to "Rene Herse"). The packaging did not explicitly say that they were tubeless-compatible, and I do know that the treading was slightly thicker that what is on the current Barlow Pass tires labeled "Rene Herse," so some things have actually changed with these tires as well, not just the website description. Whether that change is limited only to the label and the tread thickness and tire mass, I do not know.
Liked 7,295 Times
What's your problem? This thread is about a lawsuit involving tubeless tires, and the primary issue in the lawsuit will be compatibility of the defendant's tires when used on the plaintiff's wheels. Comments about present compatibility issues are spot on topic.
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Likes For datlas:
Liked 9,456 Times
I'm commenting on the practice that's rampant on BF, in general. Lots of comments, like the OP, exist solely provide unsolicited *****ing, moaning, and complaining while warning off others from something that they seemingly have little interest or experience with. Why dedicate time and energy to something like that? It's like hate-watching a show just so you can enumerate its flaws to fans of the show. It's weird.
Likes For WhyFi:
Liked 7,295 Times
Quoted: 321 Post(s)
Liked 263 Times
In fact over the years they've been able to make much finer extrusions anyway.
Liked 3,434 Times
You call attention to it by going to the hospital and wracking up charges. The attention of your insurance company, specifically. THEY go after whomever they believe they can recover costs from. They even have a BS term for the procedure: subrogation.
