Bleeding hydraulic disc brakes on a front-loading cargo bike?
Quoted: 100 Post(s)
Liked 57 Times
Hi, all. Advise me on bleeding hydraulic brakes, particularly the front brake, on a front-loading cargo bike? I'm about to try it for the first time with my Douze, and I'm concerned that because the bike is too big to put on a repair stand or pick up and move around, I won't be able to get the brake lines at the optimal angles to get all the bubbles out. How do you do it?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Don't overthink it, just bleed the brake. You can always remove the caliper and put it on the ground and take the lever off the bars and hold it as high as you can get it. It's not critical.
Likes For cxwrench:
Quoted: 6173 Post(s)
Liked 4,790 Times
It also helps to get the brake manufacture's instructions. Shimano's will be found here..... https://si.shimano.com/#/
And for video and other documentation, this place does a great job of telling you how to do it.
https://www.parktool.com/blog/repair-help
Random vid's on youTube, even some of the best produced are done by those that really shouldn't be allowed near a bike with a tool in their hand.
But how much help do you think you are going to get since you don't tell us what brake you have, brand and model of bike or any details. My hydraulic brakes may not be your hydraulic brakes. They only work on the same principle. They don't have the same design.
Quoted: 100 Post(s)
Liked 57 Times
Liked 4,790 Times
Thanks, but that's not the point. All the directions you link there are for normal bikes. As I mentioned, I'm talking about a Douze cargo bike here -- which is a bakfiets-style frame, more than 8 feet long in total, with a very long brake hose running to the front wheel.
Likes For Iride01:
Clark W. Griswold
Quoted: 4330 Post(s)
Liked 3,955 Times
No real difference unless you have a non-standard brake but I cannot believe that Douze would use something non-standard, they use Bosch motors and make what look to be a nice product from what I remember seeing when I last looked. I think you can just do it like a normal bike that is what we do at the shop with all the similar bikes.
Likes For veganbikes:
Quoted: 100 Post(s)
Liked 57 Times
Clark W. Griswold
Liked 3,955 Times
No, it's a standard brake (Tektro Gemini). When you're doing a front-brake bleed on a cargo bike, do you usually have to take the hose entirely off the bike, in order to get the air out of it? Or can you get by with just taking the caliper off and taking the hose off the fork?
When in doubt ask the local shop that sold it to you and see if they can help out, save you some hassle and headache. I personally don't mind bleeding brakes but for a big cargo bike I would not want to do it at home, those things are heavy and my stand can't really handle it at home and I don't have the set up for the park stand nor the money.
Liked 4,790 Times
When bleeding brakes on a motor vehicle they have much longer and much wider brake lines. Yet the air bubbles still get pushed down the brake lines and out the lower and further away caliper body. At least they did when I was DIYing my own vehicles 20 years ago. Maybe the physics involved isn't the same, which I highly doubt. <grin> But we also could push the fluid from the brake calipers to the master cylinder too. So if one way didn't work the other would.
Probably on your brakes you can do that too. But first, find the procedure recommended for your brand of brakes and brake lever. Hopefully they are the same brand so there won't be a conflict of design that might make one way of bleeding them ineffective.
