Titanium rear derailleur hanger
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I was looking at titanium road/touring frames from various manufacturers and noticed many have integrated rear derailleur hangers. I've only owned aluminum frames (MTB, road, gravel) and they all have replaceable hangers. Should an integrated hanger make me nervous, or is titanium *that* awesome?
Quoted: 1245 Post(s)
Liked 1,319 Times
Likes For Atlas Shrugged:
Even a derailleur is replaceable. What you really don't want is for the hanger to be stronger than the frame.
Likes For BlazingPedals:
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
TL;DR not a problem.
This is my experience as a shop mechanic for several decades. The replaceable Der hangers weaken over time. I don't know exactly why, but they come through often enough out of alignment for me to believe this does happen. I have not seen a titanium frame with an integrated hanger go out of alignment or break off in a mishap.
Likes For TiHabanero:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Clark W. Griswold
Quoted: 4330 Post(s)
Liked 3,954 Times
Quoted: 645 Post(s)
Liked 797 Times
FWIW, my 22-year-old Ti frame has a non-replaceable hanger fabricated from 5/16" 6/4 Ti plate. I'm pretty sure my RD will disintegrate before this hanger budges, and if so, them's the breaks - time for a new RD
ignominious poltroon
Quoted: 2221 Post(s)
Liked 3,407 Times
Although it would indeed suck to break my Di2 rear derailleur, it is the possibility of breaking the frame with the integrated hanger that has me worried.
Those modular dropouts (which include the hanger) I would think would be ideal (but don't have any particularly useful insight).
Quoted: 3352 Post(s)
Liked 1,056 Times
Titanium is almost as strong as steel, and the hanger would be just as good as a steel bike that doesnt have a replaceable hanger.
"They are somewhat designed to fail the idea is those break and save your nice derailleur and your frame."
Yes, they are designed to fail in the event of a maladjusted derailleur or a crash. What I am seeing is the hangers become weak over time under normal use and require realignment and eventually replacement after the hanger has been realigned a few times. Some designs are more susceptible to this than others.
Quoted: 1109 Post(s)
Liked 1,200 Times
We have two recent ti bikes in the garage - 2021 Lynskey and 2021 Litespeed. They both have replaceable hangers - which are aluminum, and available from the companies. The old 96 Litespeed Classic does not have a replaceable hanger.
Quoted: 790 Post(s)
Liked 348 Times
Titanium is repairable, but it will take a shop with a special heliarc setup for titanium to do it, a shop that specializes in welding titanium, then after it is welded you have to give the frame to a mechanic capable of re-shaping and re-tapping the hanger competently so they do not screw it up and have to send it back to the welder again.
I have destroyed to integrated hangers on steel frames in my life, one in a bad crash, one by simply not having the rear derailleur adjusted correctly and sucking the chain behind the big sprocket and bending the heck out of everything. I was able to repair both frames myself, probably because I grew up with an oxy/acetylene torch in one hand, and also used to work at a metal-fab shop when I was a young man among other experiences.
The metal fab shop I worked at had jobs using titanium and if there was a mistake made on a part we had to send it out to have it welded up, which did not help the profit-margin.
So you just have to look at the chances of you destroying the hanger vs. the cost of having it repaired vs. how much good a titanium frame will really do you. I don't think the weight saving of a titanium frame, and it's cost, is going to make any difference in anyone's life unless they are a pro-cyclist making a living at it, for anyone else it is just jewelry.
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Likes For Rdmonster69:
Quoted: 790 Post(s)
Liked 348 Times
Wrong. Multi-speed bikes have a proven practical use, they make it much easier for people to ride up grades, drop bars are proven to let people travel more quickly, coaster brakes are proven to have more drag than rim-brakes etc.. A lot of improvements in the bike as practical transportation have been made. Titanium is not as stiff as steel so it may have different ride qualities, but if they were worth it then 99.99% of the bicycles out there would not be steel or aluminum.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Again to the OPs question ....a Ti DR hanger will be plenty tough ..... and unless is on BF you probably won't get many people calling you out for having one.
Oh and mine was worth it because I bought a 20+ year old one off of EBAY for a good price !
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,200 Times
I have a few bikes with replaceable hangers that have over 10,000 miles on them. I have never had to adjust the hanger at all, much less periodically. I’ve also never replaced one of my own. As a long time volunteer at a co-op where we see just how badly bicycles can be treated, I’ve only had to replace a few (out of close to 15,000 bikes I’ve worked on) and most of those were obviously damaged.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 645 Post(s)
Liked 797 Times
Can you give me the official beng1 verdict on carbon fiber? I see a lot of those racer types using it, and now even ordinary people (racer wannabees!) are adopting it! Damn' plastic frippery, if you ask me....
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,849 Times
Liked 11,849 Times
Hey, if CF were better, all bikes - well, 99.99% of them, anyway - would be made of it. Even kids' balance bikes.
Quoted: 567 Post(s)
Liked 562 Times
Likes For easyupbug:
Quoted: 504 Post(s)
Liked 634 Times
If a Ti frame has different ride qualities than a steel frame that will be because the frames were not designed to the same goal. When designed to the same goal, the difference between a steel and a Ti frame will be that the Ti frame will be lighter and more expensive. And it won't corrode.
