Ultegra Di2 - How do you set up a triple?
Old 04-22-13, 08:59 PM
Alan Edwards
Alan Edwards's Avatar
Bikes: 84' Ciocc, 79' Shogun 1000, 76' KHS Gran Sport, 96' Schwinn Super Sport,
Hay people, I'm usually on C&V but I have bikes from 73' to 2010'. This pertains to the new stuff, DII2 Ultegra. My local bike shop told me that you can't use a triple with Dii2. My bike shop really doesn't do more then setups and follow manufacture's guide lines. They once told me to throw away my DA 7700 pedals when I wanted to rebuild them. So I rebuilt my pedals, screw them. So is there a "Hack" for a triple, I know there is a way for sequential up/ down gearing with just one paddle ( The computer knows that the next highest gear is up on the front and down on the rear). I know there is a simple two button pad that you can mount on the bar and not use the paddles. I'm just lacking in the info on a triple. Thanks, I don't want to get in any ones way, I'm just slow.
Alan Edwards is offline
Old 04-22-13, 11:06 PM
David Broon
Sqrl
A) it's just di2. No ii. We're not on the second version yet, and that would be DiII.
B) You can do anything with enough creativity, but as far as I am aware, you can't use a triple or do sequential shifting with it. (yet)
Welcome to the 41!
Also, find a new LBS.
Originally Posted by carleton
Doing one-legged squats while holding chickens in each hand will make someone strong...that doesn't mean it's the best way to train for track racing.
Originally Posted by Nagrom_
That would be spectacular. A trail of blood and sealant.
David Broon is offline
Old 04-22-13, 11:50 PM
hamster
I'm sure that there are more than a few people who'd be interested in hacking Di2 to work with a triple, but there are several problems.
1) you'd need to take apart the front derailleur and replace the cage with one for a triple FD. I suppose you could buy a sacrificial 6703 FD, take the cage and toss the rest.
2) you'd need some special equipment to reprogram the system. It retails for $200 in the U.S.
3) (the real problem) you need special hacked firmware that supports a triple. To my knowledge, it does not exist because no one figured out how to do it. It is not easy to hack firmware for some obscure electronic device without any source code or documentation.
hamster is offline
Old 04-23-13, 05:16 AM
DinoShepherd
cycle-dog spot
DinoShepherd's Avatar
Bikes: Look, Niner, Ellsworth, Norco, Litespeed
Would a mountain double get you where you want to go?
You can have 26..38 up front. Or 40..28.
When combined with an 11..28 that should give you decent gearing.
Just thinking out loud.
DinoShepherd is offline
Old 04-23-13, 05:46 AM
RT
The Weird Beard
RT's Avatar
Liked 3 Times in 3 Posts
Is it possible to Di2 the back end and cable the front end, or does that make way too much sense? Electronic shifting makes so little sense in my Fredly world as it is.
RT is offline
Old 04-23-13, 06:05 AM
LowCel
Throw the stick!!!!
LowCel's Avatar
Bikes: GMC Denali
Quoted: 176 Post(s)
Liked 92 Times in 31 Posts
Pretty sure the brains of the operation are in the front derailleur.
I may be fat but I'm slow enough to make up for it.
LowCel is offline
Old 04-23-13, 06:21 AM
RT
The Weird Beard
RT's Avatar
Yeah, guess would need a whole new left lever then. Oh well.
RT is offline
Old 04-23-13, 08:02 AM
rangerdavid
rangerdavid's Avatar
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
I would think a newer version would be Di2.2
rangerdavid is offline
Old 04-23-13, 08:14 AM
mrardo
mrardo's Avatar
Bikes: Trek 6.9, Davinci touring, Mountain bike and a Trek tandem
The real advantage to DI2 is the perfect front derailleur. Getting a triple working reliably is hard, more black art than skill. If a DI2 triple was easy Shimano probably would have done it. It would bring me back to a triple if Shimano could get it right.
mrardo is offline
Old 04-23-13, 09:04 AM
CrankAndYank
Bikes: 2 x 2012 GT Series 1, 2012 P2C
WADR, if you need a triple, you don't deserve Di2...
CrankAndYank is offline
Old 04-23-13, 09:05 AM
kv501
kv501's Avatar
Me too until I rode it.
Like buttah.
kv501 is offline
Likes For kv501:
Old 04-23-13, 09:09 AM
Alan Edwards
My thought was that if the FD self adjusts then if it was set up for a triple you would not need to change the cage. The RD might need a longer cage to take up chain wrap, but that would be an easy fix. I'm going to send a letter to Shimano. DinoShepard +1 I did not know you could get a double down to 26-38. David Broon Yes you can with sequential shifting, It is for sale and you add a button to your handle bar...$150. Where is the brain, I thought it was in the brake levers. Different parts have different parts of the brain??? Just seems like a no brainer for Shimano to get it to work for a triple.
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times in 560 Posts
How to set up Di2 triple - step by step:
1. Open computer and go to craigslist.
2. Post "triple crank for sale"
3. Use money from sale to buy a double crank.
Sure...not helpful but I sure feel better.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Likes For Psimet2001:
Old 04-23-13, 11:16 AM
Bostic
Quoted: 9 Post(s)
Liked 3 Times in 2 Posts
I'd buy a triple DI2 if they offered it. I use the 52t ring on my triple to drop riders on compacts on long descents.
Bostic is offline
Old 04-23-13, 12:17 PM
hamster
I was originally thinking that, if you don't change the cage, the chain would rub against the tail end of the cage when in the granny ring. But I just took a close look at my Ui2 FD and the cage seems to be long enough (there's space between the chain and the tail end even in 34/12 gear). 50/39/30 should work without physical changes. Maybe even 52/39/30.
Electronic rear / cable front is crazy. Mostly defeats the idea of having electronic shifting in the first place. Most of the value of electronic is in smooth reliable front shifting and front auto-trim. Besides, it simply wouldn't work, the system won't function if it does not see all components.
hamster is offline
Old 04-23-13, 01:16 PM
Alan Edwards
Thanks Hamster Good to know that my thinking is correct. Now more complaining to Shimano. It just looks like a programming job, and they did it the first time so why no for triple. Thank you all for the info, better here then the Shimano website.
Old 04-23-13, 02:06 PM
Ritterview
Tandem Vincitur
Ritterview's Avatar
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
On the tandem forum, we'd love to have an electronic shifting triple. Thus this post, which I copy/paste.
[HR][/HR]
Originally Posted by waynesulak
Give us an electronic triple then we can compare manual to electronic. The thought of an electronic triple that does everything as advertised would be great. No long cable run issues, great front shifting, what's not to like?
The thing is, we will all grow old before Shimano or Campagnolo makes a triple shifting FD. If you talk to anyone in the bicycle industry about tandems and triples, they recoil from you as does Dracula from a cross.
I think it is doable, however, to modify existing systems to shift a triple. One thing to note is that the 11-speed chains are narrower, and thus the chainrings can be more closely spaced. This requires less range of throw of the FD. There might, even now, be sufficient throw now on Di2 or EPS to shift an 11-speed FD on a more closely spaced triple.
How it could be done for Campagnolo (and presumably Di2 as well) is depicted on this graphic. (1)The new Athena 3X FD donates its cage. (2) If the throw on the EPS FD isn't sufficiently wide, then a longer arm (as depicted) is fabricated using 3-D printing (see video below) to obtain wider throw. (3) The EPS brains are hacked to get it to make 3x shifts. All of these things have been done individually. K-Edge has done more than this to produce a mountain Di2 group.
3-D Printing bicycle parts:
Strava Tandem Club
Ritterview is offline
Old 04-23-13, 06:28 PM
hamster
They did not. They made physical modifications to RD to allow a 11-36 cassette and they put a standard Dura Ace Di2 FD on a 40/28 mountain crankset.
hamster is offline
Old 04-23-13, 09:23 PM
Ritterview
Tandem Vincitur
Ritterview's Avatar
Yeah, but what about the shifter? Not stock that is.
Strava Tandem Club
Old 04-23-13, 09:52 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Pfft.
They could easily do it. They don't want to.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-23-13, 11:28 PM
hamster
This guy https://nyvelocity.com/content/equipm...ra-di2-tt-hack built TT Ui2 shifters by taking apart road bike shifters, keeping the circuitry, and routing the button wires to switches mounted on aerobars. (There are two buttons and three wires - up, down, and ground - in each shifter.) It's purely a mechanical mod.
The shifter in your pic is functionally the same. It only has one pair of switches because the bike has 1x10 drivetrain so there's no front shifting to be done. This does not involve any firmware hacking.
hamster is offline
Old 04-23-13, 11:45 PM
marqueemoon
or tarckeemoon, depending
marqueemoon's Avatar
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Not sure what the tooth differential Di2 is rated for, but the Sugino OX801D and OX601 are 94/110 so you can have a small ring down to 30t on a double with a reasonable q factor, outboard bearing bb, and no chainline wonkiness. If you just want low gearing in the triple neighborhood with a double and a short cage rd that's how I'd do it.
marqueemoon is offline
Old 04-23-13, 11:53 PM
JakiChan
Bikes: Specialized Sirrus Comp
Personally, I'd love a stock electronic RD that can do a wide range cassette. On my Roubaix right now I've got an 11-34 with an XTR RD. If there was a way to do the same thing with a stock electronic RD (not the K-Edge hacked RD) I'd do it in a heartbeat.
JakiChan is offline
Old 07-14-15, 08:34 AM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
Sorry for the necro-post, but this might be possible now.
Unless I am reading this wrong, it looks like Lennard Zinn says that if you purchase XTR (mountain bike) front and rear derailleurs, you can use these with Di2 road shifters.
You can run a full XTR Di2 drivetrain with your Di2 road levers (you could use any Di2 ST or SW Di2 switch, like climbing, sprint, or TT switches with it). That would be analogous to mixing 10-speed ST-6770 (Ultegra Di2 shifters) with 11-speed RD/FD, or 11-speed ST-6870 (Ultegra Di2) or ST-9070 (Dura-Ace Di2) with 10-speed FD/RD-6770 (original Ultegra Di2). Both of these road combinations do work.
Tech FAQ: Mixing Shimano road, MTB Di2 derailleurs - VeloNews.com
Cyclist0108 is offline
Old 07-14-15, 08:49 AM
rpenmanparker
rpenmanparker's Avatar
Quoted: 6556 Post(s)
Liked 58 Times in 36 Posts
But as a triple?
Robert
Originally Posted by LAJ
No matter where I go, here I am...
rpenmanparker is offline
