BB89.5 vs BB92 Shimano bottom bracket (misterious 2.5mm spacer)
Quoted: 8 Post(s)
Dear bikeforums.net community
As must of us know there are twho differen mtb shimano pressfit bottom brackets: 89.5mm and 92mm.
If we look carefully into the shimano techguide we see that the description mention that the 89.5mm ist for symetric frames and uses a 2.5mm spacet to become also 92mm total width.
The 92mm should be used with asymetric frames.
So my question is: Can someone explain me why there is 89.5mm + 2.5mm spacer version and a 92mm version? They both endup in a 92mm width.
From a numeric point of you that doesn't make sense at all.
I really don't get it - is there another tecnical mystery I overlooked or I still not able to catch?
Many thanks for your answers and your time spent replying me.
best regards
Matt
best regards
Matt
Quoted: 103 Post(s)
Liked 144 Times
I find this helpful
FSA – EasyBottomBrackets (fsaeasybottombrackets.com)
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Quoted: 713 Post(s)
Liked 796 Times
One fits in a 92mm width bottom bracket shell and the other fits in an 89.5mm bottom bracket shell. The crankset has the same length spindle on both, so a 2.5mm spacer(outside the BB shell) is necessary to take up the extra space on the spindle.
Randomhead
Liked 3,690 Times
Do they think you might need to move the chain line over that much? There was some bike I assembled that came with spacers and I forget where they intended for them to go. Mid-range Salsa, IIRC. The shop owner consulted with Shimano, but I don't think I ever heard the outcome of that
