Inner tube pattern
Inner tube pattern
Old 06-26-22, 09:55 AM
alexk_il
Quoted: 142 Post(s)
Liked 34 Times in 26 Posts
Inner tube pattern
Just replaced an old tube, noticed a strange crossed pattern. I'm sure it's my fault, but I'm still curious how I caused it? The tube is OK otherwise.
alexk_il is offline
Old 06-26-22, 09:58 AM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times in 623 Posts
Low PSI?
Fred "The Real Fred"
10 Wheels is offline
Likes For 10 Wheels:
Old 06-26-22, 10:15 AM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
Are those marks on the side of the tube? Tire iron marks? Or is there a similar pattern on the inside of the tire?
One thing I try to do is keep the inner tube untwisted so any damage seen on the tube after being pulled out can be matched with the same spot on both the tire and rim. (And I always mount tire with the label either the valve or the rim weld. I vacillate between the two, Valve is easier and faster but the label gets dirtier from my hands while pumping and the rim weld location has a long history as that is where tubular tire labels are located. Tugs my heart.)
79pmooney is offline
Old 06-26-22, 10:22 AM
alexk_il
Quoted: 142 Post(s)
Yes, the marks are on both the sides of the tube. This pattern goes on both sides all along the tube, not on a specific spot. No marks on the rims or the tire itself.
alexk_il is offline
Old 06-26-22, 11:18 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,218 Times in 2,365 Posts
It’s the threads of the tire casing like those below. It looks like you use talc.
It also looks like your tire is a 60 thread per inch (TPI) tire. Low thread count tires can be a problem if one of the threads breaks. The messed up portion of the tire above looks like this from the outside.
The tire had a definite snake belly to it.
Stuart Black
cyccommute is offline
Old 06-26-22, 12:43 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Maybe it's when the slightly undersize tube makes contact with the tire when inflating, it "creeps" a bit and leaves "scuff marks"?
Bill Kapaun is offline
Old 06-26-22, 03:25 PM
wheelreason
Quoted: 501 Post(s)
Liked 626 Times in 370 Posts
That is caused by riding a flat tire.
wheelreason is offline
Old 06-26-22, 08:16 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
I don't know if this statement is true or not, but based on Occam's Razor, I like this response.
MudPie is offline
Old 06-26-22, 11:42 PM
alexk_il
Quoted: 142 Post(s)
Don't remember ever riding a flat tire.
​​​​​​I did roll the bike with deflated tires out of my garage this year. Maybe that's it. Strange that this only happened to one tire, the other one didn't have this.
alexk_il is offline
Old 06-26-22, 11:46 PM
alexk_il
Quoted: 142 Post(s)
Also thought about it, I sometimes even hear a popping sound when a new tube untwists itself during inflation in the tire. Maybe that's it.
alexk_il is offline
Old 06-27-22, 02:46 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 853 Post(s)
Liked 1,436 Times in 818 Posts
The popping sound is likely the tire seating in the rim. Why would your tube have to untwist? If it is twisted inside the tire, you have installed it incorrectly.
delbiker1 is online now
Old 06-27-22, 02:53 AM
alexk_il
Quoted: 142 Post(s)
Some tires were/are made by Spanish inquisition to torture those who installs TLRs with normal tubes. Challenge Bianca Pro HTLR is one of these, there is absolutely no easy way to install a non-latex tube without twisting it in a few places. But it's great tire otherwise.
The tube in my photo came off an old Conti Cyclocross tire, I think it was TLR too and I struggled a lot while changing the tubes with it.
alexk_il is offline
Old 06-27-22, 12:07 PM
BCRider
BCRider's Avatar
Bikes: Norco (2), Miyata, Canondale, Soma, Redline
Quoted: 44 Post(s)
Liked 45 Times in 35 Posts
Those are just marks from the texture on the inside of the tire from the cords that cyccommute showed you. Next time you have the tire off look on the inside and you'll see the texture that imprinted itself on the tube.
Keep in mind that as you ride the tire squirms around a little and the tube squirms a little inside the tire as well. Over time if the cords are quite proud on the inside they will micro wear a pattern like this into the surface of the tube. It's nothing you did. It's simply the tire's makeup affecting the tube.
BCRider is offline
Likes For BCRider:
