Noisy valve stem on carbon wheels
Has anyone came up with a solution in keeping the valve extension from rattling on carbon wheels?
Semper fi
Semper fi
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Likes For GlennR:
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Okay, anyone got a solution for when you discover this problem after you've stuck your tubs on?
I pushed a bit of heatshrink tube over the valve but it's touch and go, didn't quite fit.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
On Your Left
Liked 2,433 Times
bike whisperer
Liked 716 Times
Likes For topflightpro:
Likes For Bob Dopolina:
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
This was years ago, so I can't say if SB uses the same diameter straw any longer.
Quoted: 4225 Post(s)
Liked 2,945 Times
I found that a Starbucks straw was the perfect diameter. I cut a length and fed it down over the valve until it was good and stuck down around the stem. I used an Exacto knife to then trim off any excess. Worked great and didn't fail before pulling the tires off to glue new ones.
Liked 2,945 Times
Likes For himespau:
Likes For JohnJ80:
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Went for a ride with the electrical tape solution- works wonderfully
wish I knew about this years ago
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
These are MUCH thicker than tape AND have glue that will keep them in place even after countless hours riding in the rain.
pan y agua
Quoted: 1443 Post(s)
Liked 712 Times
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Likes For woodcraft:
there’s benefit in the shape and in protection against cheap adhesives/tape but still - tape works just fine.
Quoted: 18883 Post(s)
Liked 10,646 Times
If you had cochlear implants you could turn them off.
