Gorilla glue for inner tube punctures?
complete noob to bike repair here...I've been looking online regarding glues for inner tube punctures (with patches) - I've only got Gorilla Glue at home currently, and it seems the concensus is to get rubber cement. I'm still curious as to just how effective Gorilla Glue would be.
also, how true is the stuff bike shops say about patching inner tubes being a short-term?
Really Old Senior Member
Get a REMA repair kit.
Don't screw around with less.
https://www.rematiptop.com/products/...pair-kits.html
Likes For Bill Kapaun:
No, get good stuff.
A friend of mine used a poundshop puncture repair kit and had the glue melt right off the tube due to the heat generated from braking on a fast and long descent.
Personally, I prefer a brand new tube every time.
Likes For Tawraste666:
Quoted: 809 Post(s)
Liked 1,018 Times
+1 on Rema Tip top kits. The patch, if done correctly, will last decades. I also like that the patch is thin and tapered at the edges but the most important thing is that it works. Bike shops always provide a new tube. This is just how they work. They get money for the tube and the labor.
Likes For Velo Mule:
Quoted: 426 Post(s)
Liked 699 Times
Rema, as prev stated. When there is a tried and true product, why would you use something else? If no LBS nearby, a local auto store probably has them. I've never considered a well done patch job as temporary.
Quoted: 4792 Post(s)
Liked 3,918 Times
Another Rema fan. Good thing is there are plenty of other kits that use the same glue and patch system that work but Remas are consistently the best so I I have a choice I always go there. (Good patch kits use vulcanizing glue, not a cement. Fundamentally different system.)
Likes For 79pmooney:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Likes For ThermionicScott:
Quoted: 1438 Post(s)
Liked 1,092 Times
You do not want glue, you want "vulcanizing fluid" which, when correctly used, causes a chemical bond between the tube and the patch. Sulfur something something, one of the organic chemists in the group might chime in.
Ther previously-mentioned REMA kits have the right stuff.
Likes For dsbrantjr:
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I have had patched tubes that lasted thousands of miles. Rema, IME, is the best. Also, I sometimes use glue less patches, again IME, they work well and I have had some last long term, some not. With all tube patching, it has to be done properly to work properly.
Likes For delbiker1:
Quoted: 1109 Post(s)
Liked 1,200 Times
Thanks all, will order some REMA as suggested!
also, I've heard of some anecdotes regarding a patched tube losing integrity over time when left unused - I'm assuming this also holds no water?
I was just thinking of Gorilla Glue since I was a little desperate for a fix at the time and that was the only thing I had lying around - it's good to hear the patch will last long-term, though
If you're using TPU tubes, you'll probably need a special patch kit.
Latex tubes are very easy. Patches for butyl tubes work very well with latex. Or, you can use a piece cut from an old latex tube as a patch, just apply the vulcanizing fluid to both the tube and the patch.
I rotated through 3 tubes for my commuter bike over 12 years. Each of them have about a dozen patches. The only thing that eventually killed one was the valve broke.
Quoted: 2337 Post(s)
Liked 2,813 Times
++++1 on Rema kits. Take your time, use the sand paper well, put the glue on AND LET IT DRY put patch on....ride
Likes For squirtdad:
Quoted: 581 Post(s)
Liked 921 Times
A properly patched tube (with a separate patch and glue/vulcanizing fluid like Rema Tiptop) is not a temporary repair. The only time I have had a flat at a properly applied patch was when I was not able to find and remove the object stuck in the tire that caused the initial flat, and it eventually poked a hole through the patch.
The one-step peel-and-stick 'glueless' patches, in my experience, are a temporary fix at best, although others have had better luck than I.
There are a few kludges that can replicate the less-than-100%-reliable glueless patches (Gorilla tape, and the stretchy plastic tape we call 'hockey tape' might work), but nothing that works nearly as well as Rema vulcanizing fluid and the patches made to bond to it.
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 118 Post(s)
Liked 219 Times
If you have been around long enough you know once you open the little Rema Tip Top glue tube it will be dry the next time you use it. So my SOP is to carry a couple of inner tubes and just replace as needed.
Walmart sells an 8 oz can of SLIME brand Rubber Cement "for use with patches and plugs" that I have used. NAPA Auto Parts also sells some kind of vulcanizing fluid that I have used.
So when I'm home and at my leisure I patch my tubes with the Tip Top patches (the best IMO) and save opening the Tip Top glue (vulcanizing fluid) until I have an emergency on the road.
Quoted: 2479 Post(s)
Liked 2,948 Times
Likes For Trakhak:
Quoted: 836 Post(s)
Liked 1,059 Times
EDIT: I forgot to mention that, I believe it was cyccommute, pointed out some time ago that it's not the air that gets in but the solvent that evaporates through a poor seal at the cap so basically using the same solution is to keep an airtight seal and a little fluid at the cap helps to do this.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Here's an oldie but a goodie classic take on the question
https://www.bikeforums.net/road-cycl...er-cement.html
Quoted: 425 Post(s)
Liked 454 Times
I've done the Gorilla Glue thing as an experiment (to fortify a peeling edge of a regular patch job) and while it seems to hold up it should not be the primary recommendation. It takes forever to cure properly and when it does it expands and hardens. Best to go with the popular opinion already mentioned in this thread.
Liked 1,200 Times
Likes For BrenZan:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 249 Times
Gorilla glue won't hold up because it won't stretch as the tube expands with air. You would be better off for about 12 hours using the black Gorilla tape!
Rema is the best in the USA, as others have stated. I've used Rema for years till I switched to glueless patches about 30 years ago and was using nothing but Park glueless patches, the other brands of glueless patches sucked, the Parks would last till the tube dry rotted! But then about 3 years ago I started having problems with the Glueless patches holding up, they would only last maybe 48 hours. I thought I got a bad box, so I tried another box, same thing, I then e-mailed Park and asked them what was up, they said the tube manufacturers changed the composition of the tubes which in turn made glueless patches a fail. That was sad, because I loved glueless patches.
Likes For rekmeyata:
Quoted: 581 Post(s)
Liked 921 Times
rekmeyata Never tried it on a tube, but I was told that Gorilla tape can be used as a rim tape for tubes AND tubeless setups on fat bikes. It works on my fat bike with tubes, haven't tried tubeless yet.
