sturmey archer scAW no 1st gear
Hi, Wish I lived down South so I could be riding, but oh well. I picked up a AW hub from ebay to take apart and refurb and to see how it works hands on so I would understand them more. I'm putting it back together and one of the pawl springs went flying never to be found. I was told I could assemble it with one pawl on the bottom left side and put it in a vice to see if it shifts. Well it shifts to 2nd and third but not first. I found this info on a google forum---I should ask, does the hub make the classic click-click-click when
pedaled in top gear. If it does not, it implies that the low gear
ratchet pawls are not working, either because their frail return
springs are broken or are gummed up with old lubricant.
JB mentioned the ticking in high
gear, that's what you get when the hub is lubed correctly, it
dissapears as the oil thickens. It's a good indicator to the correct
viscocity of oil you are using, too thin and the tick is loud, too
thick and it dissapears completely, A gentle tick is sweet music to
the AW rider. It should be barely perceptible when riding in a quiet
environment.
I think you'll find that the ratchet pawls on the right end (low gear)
are not articulating for one reason or another. Check for "gum" and
for bent or missing pawl springs. These springs are weak.
Your problem seems to be that the low gear pawls are not engaging, or
at least not articulating or you would hear them make an over-running
click when riding in high gear. I'm guessing that it may not shift into 1st with one pawl and/or the one spring is weak. I have not put oil in it yet, just lubricated it real good with T9 spray to play with, are the left side bottom pawls for 1st gear. Any ideas? Thanks, Mike
environment.
SE Wis
Quoted: 2397 Post(s)
Liked 2,725 Times
Lots of good stuff here.
https://hadland.wordpress.com/2012/0...y-archer-hubs/
and here
Sturmey-Archer Heritage :: History
BF member also has a youtube channel.
https://www.youtube.com/channel/UC6t...DoQDcOdRqlCdEA
and here
Thanks for replying. I actually was watching one of Dan Burhat's video on how the AW works. I also belong to the facebook sturmey archer forum and they have been a great help. I have got 4 new springs on order and they should be here next week. The other website you gave me was very interesting too. Thanks, Mike
Likes For Moe Zhoost:
Well, I've got her all cleaned up and back together with 4 new pawl springs and she shifts fine with the hub off (I've got it in a vice ) but when I put the hub on it's almost impossible to find first.Following Dan Burkhart's video on how it works. Mike
Quoted: 1036 Post(s)
Liked 619 Times
First should be very close to the furthest you can pull out the cable. I you pull it all the way till it stops, it should get into first. Typically on the bike you adjust it so there's just a tiny bit of additional "give" in the cable.
How did you set the cones? The correct way is to screw the DS cone as far as it will go, then back it off until it lines up with the locking washer. Then you do all of your actual bearing adjustment with the NDS cone.
I've tried adjusting the drive side anywhere from 1/4 to 3/4 turns and just snug the left side up til it touches so there's just a tiny bit of play. What is the best way to do the left side? When I pull the cable out all the way is runs like in 2nd. I've attached pics of my shifter test setup. I just tried this and again 2nd and 3rd shifted fine. !st gear it took 8 revolutions of the crank end to turn the hub 1 time. Shouldn't 8 turns of the crant end turn the hub 6 times or am I crazy? How could this be or am I figuring wrong? Thanks, Mike
pics of my setup. There is a nut on the left side that I can adjust ever so slightly to pull the chain just a little so I can try it easily in different positions.
Well, whatever I find out or don't find out I have accomplished what I wanted to. I've learned alot about how to take apart and reassemble the AW hub and how it works makes sense to me so it was worth the $40 I spent on ebay. Thanks, Mike
Senior member
Quoted: 883 Post(s)
Liked 500 Times
Likes For wmh9680:
I was trying to watch both revolutions without the sprocket on so I put the sprocket on and put just light tension on the hub so it wouldn;t spin freely and it worked out 4 spins of the sprocket did 3 spins of the hub. I think the light tension on the hub did the trick. Thanks again, Mike
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 120 Post(s)
Liked 128 Times
I started rebuilding 3 speed hubs as a teenager. We would take them apart, clean them up, reassemble and ride. Luckily they are pretty bulletproof. Some of the newer Sturmey Archer 3 speed hubs use a rotary shifter. I have more recent experience with the Shimano Nexus 7 speed hubs. They are easy to take apart and clean but the rotary shifting mechanism is not easy to take apart. In fact I never disassembled the rotary shifter on the 7 speed hubs. Eventually the shifting mechanism wore and the hub became useless. AW hubs were easy to change out everything including the shifting mechanism.
Well, I finally got her all back together and working. Here is a pic of the setup I came up with to check the shifting. I can turn either the axle nut and/or the brass lamp coupler to pull the chain and shift to all 3 gears. Thanks everyone, Mike
