Zwift Hub at a set resistance?
Quoted: 20 Post(s)
Liked 17 Times
I got a Zwift Hub, is it possible to set it to a certain resistance and just spin, versus using an app like Zwift to follow a route? For example, set to 100 watts and just spin while I watch a movie on TV, which I really like doing?
Thanks!
Thanks!
Bikes: yes, i have one
Quoted: 886 Post(s)
Liked 938 Times
you shoiuld be able to since i believe it follows the ant+ protocol spec. you just need a head unit to tell the trainer to do that. you can try using the wahoo app on your pohone. it is free.
Quoted: 3733 Post(s)
Liked 2,544 Times
It seems like you could find/make a workout that puts your bike in erg mode for a long time at a consistent power that you like.
Quoted: 1208 Post(s)
Liked 1,201 Times
The easiest way to do this is within Zwift. Make a custom workout set to whatever wattage you want. Use the trainer in ERG mode and it'll keep you at that wattage.
How to Build a Custom Cycling Workout - Instructions | Zwift
You can still watch a movie on the same device that is running Zwift - just have it run in the background.
Likes For msu2001la:
Liked 2,544 Times
Quoted: 20 Post(s)
Liked 17 Times
Thanks for the replies!
I found out that my Edge 1030 can control my Zwift Hub. I'm sure you all know this, but to me this is so cool!
Under Training on the Edge I can do Garmin workouts, choose a set resistance or watts (ERG mode), and even follow a route that I have saved in Garmin or one I previously rode.
Hopefully next I will find out that there is a way to record a ride with a GoPro and show it as I ride on the trainer!
Likes For scutchin:
Quoted: 219 Post(s)
Liked 493 Times
Not sure, haven't tried it.
