Rossin Record
Quoted: 5 Post(s)
Rossin Record
I'm thinking about selling my Rossin Record, which we've been discussing on this post: https://www.bikeforums.net/classic-v...l#post22671965
I did some minor fixes, including new tape and fixing the bars/cables.
Likes For kmelmon:
Quoted: 1470 Post(s)
Liked 594 Times
It's a bit of a frankenbike with that mix of Csmpy and Suntour components, which pulls down the value a bit as most would want everything to match, so I'd be leaning .more towards the $600 estimate.
BTW, I'd take off that skewer type seatpost clamp and replace it with a conventional seatpost bolt. Those tend to damage the seat lug clamp ears.
Likes For Chombi1:
Edumacator
Quoted: 1760 Post(s)
Liked 1,843 Times
Hit or miss as to what you might get. If someone in that size is looking for a record, the value is in the frame I would think.
Unfortunately what you get out of it might not be enough to offset the regret if you sell it.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1980s Vanni Losa Cassani thingy, 1985 Trek 670, 1982 AD SLE, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981? Faggin, 1996ish Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe (most not finished of course), 1989 Fauxsin MTB, 1981 Ciocc Mockba...I...am...done....
Quoted: 5 Post(s)
Will Sell for $750 plus shipping
I'd be willing to part with it for $750, plus the cost to ship it safely.
Note: For some reason I'm not allowed to post in the "For Sale" area, does someone know why?
Bikes: Indeed!
Quoted: 1261 Post(s)
Liked 2,472 Times
Quoted: 1576 Post(s)
Liked 1,290 Times
One thing I would do is to properly adjust the length of your brake and shift cables. Both shift levers are in the wrong position for the actual gear that the chain is in, E.G. your front shift lever is in the position I would expect if your chain were on the larger chainring and the rear looks as if you wouldn't be able to shift to the largest cog. As for the brakes, both brake releases are open, Your brake cables should be adjusted so that you can close the release levers and have proper braking
Likes For alcjphil:
Quoted: 1407 Post(s)
Liked 1,704 Times
And the rear housing looks short. Route it on the DS of the stem to minimize the near kink at the lever. IMHO the housing should not rub on the rear seat lug, save the paint. I don't have a NDS pic but you can get it from this pic.
P1040763 on Flickr
Likes For bboy314:
