cranks loose but the bolt is tight
Old 11-18-22, 08:36 PM
whydoibike93
whydoibike93's Avatar
Bikes: 19 pitch,05 7300fx, giant stance 2
Quoted: 23 Post(s)
Liked 13 Times in 9 Posts
Hi my trek cranks are loose but the boltis tight can feel them moving when pedaling how do i fix that? Will i hurt anything by ridiing it with them loose? Is it time for a new bb.? tia
whydoibike93 is offline
Old 11-18-22, 10:10 PM
Steve B.
Quoted: 3220 Post(s)
Liked 2,042 Times in 1,169 Posts
Sounds like a square taper crank. Riding with it loose just makes it worse. Its actually the crank that is shot, wear on the inside of the crank makes it loose. Usually caused by a loose bolt allowing the crank to move. 'Ya need a new crank. Note as well, the square taper shaft is steel, the crank is aluminum. Crank loses in those situations.
Steve B. is offline
Old 11-19-22, 12:22 AM
csport
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times in 102 Posts
A more detailed article on the subject
csport is offline
Old 11-19-22, 09:41 AM
whydoibike93
Quoted: 23 Post(s)
Okay thnx ill be getting new cranks soon i hope.
Old 11-20-22, 05:05 PM
whydoibike93
Quoted: 23 Post(s)
Update went to my lbs yeasterday morning and the guy told me that my spindle is moving and not the ctlranks how do i fix that?
Old 11-20-22, 09:11 PM
csport
Quoted: 217 Post(s)
Need more info: is it a cartridge bottom bracket? Is it square taper? Maybe some photos?
What does the guy at the LBS say?
csport is offline
Old 11-20-22, 09:45 PM
Steve B.
Unless you have the tools to get the crank off and the tools to tighten the bottom bracket, why not have the shop do it ??
Steve B. is offline
Old 11-20-22, 11:22 PM
base2
I am potato.
base2's Avatar
Quoted: 1782 Post(s)
Liked 1,620 Times in 926 Posts
Cheap bikes often have non-cartridge bearings. Instead they have a fixed cup, & an adjustable cup with a lock ring. The adjustment likely needs to be revisited.
The exact tools needed will vary depending on the bottom bracket you have. https://www.parktool.com/en-us/categ...bottom-bracket
Probably HCW-4, or HCW-5, a pin spanner of some variety and maybe a crescent wrench.
For a simple adjustment you might need to remove the non-drive-side crank arm to gain access. CCP-7 is a good tool. For a complete overhaul/rebuild, you'd definitely need to remove both crankarms.
The adjustment is an easy 2 minute job. But for a one-off job, a bike shop is cheaper than the tools.
base2 is offline
Likes For base2:
Old 11-21-22, 09:34 AM
freeranger
freeranger's Avatar
Quoted: 426 Post(s)
Liked 694 Times in 433 Posts
And if it is an inexpensive btm bracket, the shop could install a better one, so future problems might be avoided.
freeranger is offline
Old 11-21-22, 01:43 PM
whydoibike93
Quoted: 23 Post(s)
Yes square tapper bb
