120 hub 110 rear spacing
Looking at getting a NJS frame with 110 rear spacing but want to use a 120 hub. Will this work without having to cold set the frame to 120? I know someone on this forum has tried.
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
testertips all you have to do is change the spacers and the axle . Or just cut the axle down .
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
It depends on the design of the hub. You might be able to swap out the locknuts for thinner ones. Can you show pics and describe the hub?
