Charging BionX Battery While Riding
Jerry (or anyone else), what kind of connector are you using to attach the onlybatterypacks battery to the inverter? Is that something you bought from onlybatterypacks?
Thanks,
(PS-I sent you a PM, but I'm not sure if bikeforums alerts you to those, or if you have to log in & check for them)
Thanks,
I know this is an old post, but I have tried to connect my charger to the battery and when I do, it cuts off all power to the motor... As soon as I disconnect the charger, the power is available for the motor.
So I can charge the battery while on the move, but not if I need the battery power for the motor.
I am using G2 contoller and 48v battery pack, more modern than this post so maybe BionX updated the system to not allow for charging while riding?
Thanks for any help.
Quoted: 880 Post(s)
Liked 817 Times
BionX has a proprietary system, and most (all) of us aren't conversant with it. Grin (ebikesca), as well as others, have elucidated the enigma(s); you might ask them if they have a solution.
