Anyone here broken off a rack-mount bolt? Have remedy?
Quoted: 3459 Post(s)
Liked 1,465 Times
I have never broken a seatpost bolt, but I have had to get them tight enough that I worried about it. On a couple of my bikes I cut a slot into the end of the seatpost bolt so that if it broke I could use a tiny screwdriver to try to get it back out. But I do not tighten rack bolts that much (use removable locktight instead) so I have not cut slots into the ends of any rack bolts.
I had that happen once when I tried to tap paint with a screw. Nowdays I just use taps if the frame is heavily painted.
In the end I just drilled it out. The empty screw shell and drill bit did a bit of a dance and spin inside the hole but the threads lasted for years afterward. And if the threads do strip one can always use a thread repair coil.
Quoted: 18410 Post(s)
Liked 15,530 Times
Great idea! I recently broke a seatpost bolt on the last day of a tour. When I finally took the collar to a LBS it was able to get it out, but the threads of the collar appeared to get damaged in the process. Ended up buying a new collar. It was only $20, and the damaged one was over 11 years old, so not a huge loss. But your idea sounds great should you need to make a repair on the fly.
Liked 1,465 Times
If I was to try a hacksaw, I would start by cutting a slot in a nut, then thread the bolt in a bit so that the slot in the nut holds the saw blade centered where I want it on the bolt. Most seatpost bolts are M6, but my Lynskey is M5.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Well, it cost me $200 to have it fixed (plus $30 for "handling" of the online payment - errrg!). The broken-off piece is still somewhere in the frame, but, I've not heard any rattling. Importantly, everything looks good and is back to working order.
Liked 1,465 Times
A 30 buck handling fee seems highly unusual, and 200 to this uninformed observer seems like a lot.
Quoted: 2604 Post(s)
Liked 1,928 Times
Say whuuht?? I was imagining a bolt broken off in a seatstay braze-on. One hour minimum labor at your LBS, with a coffee from around the corner to move up in the schedule, at worst. How did this turn into a $230 fix and something (bolt piece) is rattling around inside the frame?
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
It was done by someone who specializes in frame repair. $150/hour. Considering that I didn't have to get it re-powdercoated to cover up any heat-damage, I am OK with the $200 cost. Asking me to pay via an internet service was lame, yes. However, he also saved me 25 miles drive x4, by picking it up and dropping it back off to my local.
This job was not possible for the LBS w/a screw-extractor (they did try). The bolt probably had to be carefully chiseled out. The threads definitely had to be cleaned up, because I'd already seen beforehand that they were knackered.
As I said previously, no, the broken-off piece is NOT rattling around and thus not a problem. It's a CrMo frame, so, how you going to get the piece out? The guy would've charged me for the time spent doing that.
However if I'm imagining this correctly, there actually shouldn't be anything rattling inside the frame. Typically those seatstay holes use a braze on that goes through the frame tube and out the other side, so there's no connection to the inside of the frame itself. Much easier the align the brazeon when it goes through the tube.
But also if there was something inside the frame you'd hear it. So chances are there isn't.
I use rack bolts that extend through the hole so that if they break, there is something to grab hold of on the other side.
A well equipped machine shop will have an EDM that can burn the broken piece right out. They mostly use them to remove broken taps.
Explains things well.
