PSA For Older Fixed Gear Riders
For the most part I ride my fixed gear bike on the flat lands and use a geared bike when heading out on long rides with hills. Recently, probably thinking I’ve been doing better than I actually am at age 63+ riding 72 gear inches, I’ve been going farther even up/down some decent hills. I normally don’t try to set any speed records when going for a longer ride. A little over a week ago I was feeling my oats and did 40 miles which in and of itself isn’t probably that big of a deal. More and more I’ve been doing 25-30… but the head wind coming back the second 20 miles of this ride turned out to be a problem. Normally I just lope along against such winds but this time I really pushed it. I felt fine when I got home but later that night – nope. Must’ve done some pretty good repetitive motion aggravation (maybe hip flexor?) fighting the wind at a much higher cadence than usual. I could barely get up from seated positions, walk, etc. because of my hip. A little more than a week later and all seems better now but lesson learned - don’t make drastic changes all at once.
Likes For takenreasy:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I'm only 52 but already feel my body starting to deteriorate in some areas. I've learned to be careful about starting out too hard from a dead stop on my fixed gear (or anytime a bike is in a higher gear than should be). It can cause problems for my knees. Once I'm moving, I can push pretty hard without trouble. It's the first couple rotations of the crank with high force on the pedals that tends to be problematic.
Yep, ten years ago my main concern was my knees. Never had problems and didn’t want to start. I’ve always stood on my pedals starting out or going up hills for that very reason. Maybe my hip issue was karma catching up to me for avoiding knee issues.
Quoted: 586 Post(s)
Liked 612 Times
I have finally reached the 60 mark and still ride fixed a portion of the time. It varies but if I stay around my neighborhood it is almost 100% on a fixed gear, of which I currently own several. I don't have any issues with my knees or anything else as it relates to fixed versus geared biking but I do think there is potential for issues when I resist the momentum of the cranks a lot. I don't have to do it that often because there's only one steep hill in my neighborhood. Let's just say it is more fun going up than down. I'm sure it is very subjective but riding fixed hasn't had any impact on my health other than positive. Not being able to coast definitely keeps you burning those calories.
Well, at this point I think it’s just getting old sucks. It’s been a while since this episode happened and I was actually getting back to feeling “normal.” But, of course, then I over did it with some work around the house before being totally healed. I need to begin realizing that once something is aggravated the proper amount of rehab time needs to be put in or else. I’ve been quite active my entire life and thought that I learned this lesson in my 40s, 50s… - guess not. Either way, fixed is the best for most of my riding and I’ll eventually be doing it again with more appreciation.
I’m 64 and went for a ride on my SS a couple of days ago for the first time in a few months. We had been traveling and using our Bromptons while on the road. After riding my SS my left knee REALLY hurt. It was sore to the touch which was unusual. I’ve always had knee problems so I was concerned. The weird thing is that when I woke up the next morning it was completely pain free and just fine! Strange, but I’m not complaining.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I'm 47, been riding fixed since '99. Ripped my left femur head out of it's socket skidding in '16 and been living with a lot of pain ever since. Usually riding any bike helps with the pain, but every few weeks I tell myself that if my hip is going to hurt, I"m going to give it a reason. And then I take the tracklocross bike out for a lap. Just found out today I am finally getting surgery early next year, so I'm going to have to give it up soon..
Ah, after using my "wisdom" and laying low and then gradually getting back into things I'm back on my fixed gear bike like notheing ever happened. I'm so happy to be active again with running and biking. But most importantly totally stoked that I'm back on my fixed gear bike - my true love! So, back to my PSA: if you are an active person who is aging, don't take for granted that you can still make leaps and bounds into new hights without proper planning.
I just logged in here for the first time in about 10-years (I'm 53 now) I dragged my FG out of the garage and cleaned it up last week. After my first pathetically short ride in all that time, I could feel my knee caps about to explode. Yah, I could climb and spin nicely with a 48/18 back then, but not so much now. I dropped the chainring down to a 44 and am taking it cautious until all those supporing muscles and stuff around my knees remember what they're there for. So far so good. Just good 'ol quad soreness, but no knee pain.
Quoted: 399 Post(s)
Liked 274 Times
Not the oldest around here but dam close to it - fixed only for more than few yrs - a ton of age-related physical problems but my knees ain't one of them - small gearing is a wunnerful thing
I think I'll eventually get to the point of nothing "screaming" once my brain functions. To add to my original misery I discovered (after 10 times of my wife telling me my injury was a fit problem) that my "new" seat was over a 1/4" too high. I'd swapped it out during the summer but just used the old seat as a reference instead of doing my usual checks. So, fitting the bike properly and for now dropping to the low 60's gear inches I'm riding fixed again and will hopefully use my "wisdom" to get back to where I was.
I'm 64 and I ride 95% on my SS. I used to ride fixed but stopped after I broke my arm a couple of years ago. I find that I get a better workout with my SS than a geared bike. I have a fairly rolling hills circuit that I ride and it definitely helps with my strength on the bike.
I also find it take me a good 2 or 3 miles to get fully warmed up so I take it a "bit" easy on the first hill but pound them hard after that. I think my current setup is a 46/17. I converted to SPD pedals and shoes 7 or 8 years ago and the sore knees are now a thing of the past. My Brooks Pro saddle is now fully broken in and is at the peak of its prime.
I average about 17.4 MPH by myself over a rolling hills course. Once in a while I'll hit a 17.8 ave for a ride when I feel strong.
Life is good.
Life is good.
I'm only 37 and love riding fixed gear, mostly mtb - but I am definitely not as ambitious as when i was 25. I barely skid. And I go really slow. My gearing is like 50 gear inches - so i don't stray that far from home. haha
I recently picked up a bucket list track bike for fun - but more of a neighborhood fair weather cruiser.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I've only skidded twice on my fixed. Both unintentionally when I took it out after not being on it for a while, but riding freewheeled bikes. Unconsciously tried to coast....
I has a slight right knee injury from an accident jumping when I was 12.. When I started riding fixed in my 40's future knee health was more important than cool. Now when I start feeling that old knee issue I get on the fixed and it loosens it up. Kind of wierd.
I live in an area with hills so ride 63-70 gear inches.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
I'm 60 and have battered and bruised my body to the point of my ssfg being permanently in ss mode.
I use it for grocery store runs because there is nothing not bolted on. (homeless parts supply is an issue)
Accepting that 155 pound me can't do what 220 pound me did has been difficult though. I can do 20 miles without complaint still, but mile 21 seems to be my barrier, my back starts hurting and my right shoulder feels like there's an ice pick in it.
Sucks getting old.
Sucks getting old.
Quoted: 2700 Post(s)
Liked 486 Times
Quoted: 525 Post(s)
Liked 931 Times
LarrySellerz I had a pretty bad crash a few years earlier that had apparently, knocked my pelvis pretty far out of alignment. I didn't have the luxury of resting/recovering after that one before returning to my 28m commute. It hurt pretty bad, but I kept riding another 1.5yrs before my body wouldn't let me pedal anymore. So I started commuting fixed so that I didn't have to actively tell myself to pedal.... and heavily self-medicated. My fixie skid technique was never the best, but I'm sure I didn't have my weight far enough forward.
The bike:
The bike:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
The bike:
The bike:
67 years young and enjoy fixed riding. I moved from S. Texas to Kentucky and lowered my gearing so that I could get around a bit easier. I use front and rear brakes to bleeed off speed on the hills here.
I rode a bit of everything, but really enjoy fixed for the simplicity of the bike and simplicity of riding. Knees still work well.
Likes For imabeliever1:
