Camp Stove Butane Canisters
Palmer
Quoted: 1663 Post(s)
Liked 1,817 Times
In Japan, own a nozzle stove, and want to come to the US to cycletour?
They make adapters to go the other way, too.
Quoted: 3459 Post(s)
Liked 1,465 Times
While trying out the adapters for nozzle canisters on my backpacking trip a couple months ago, some other backpackers were curious about those weird canisters I had, as they were used to buying backpacking gear. During two weeks, I only saw two people using liquid fuel, I was the only one with nozzle type canisters, everyone else was using threaded canisters.
Within the backpacking crowd, while threaded canisters were the norm, there were the Jetboil campers and the campers (like me) that used a stove and separate pot.
But I suspect in a few years the nozzle canisters will be the norm in areas where car camping campers are shopping. This would be in addition to propane cylinders that are already common for the small BBQ grills. And I assume that the threaded canisters will still be the norm for backpackers and canoe/kayak campers.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Just a side note, but the ones I've seen at my local Walmarts, Coleman-branded and made in France, are not 'all-weather' mixes. I was just out in low 40s-high 30s and I learned I would've had a lot of trouble with one of those if I didn't have a back up MSR canister. I hope these new ones come with some propane in them.
Stuart Black
Stuart Black
Interesting thread!
I used to have a Gerry stove that ran on butane. It had two dish shaped halves that held the valve assembly. It was great for making tea in the am.
Butane burns hotter than propane, so may be even less suitable for simmering.
aka Timi
Fantastic post TiMSN! And more great info in the thread.
I tour mostly in Europe, from Scandinavia to Greece.
Depending on where I’ll be I take the most common stove:
Scandinavia, Northern Europe (Germany, and Holland (? never toured in Holland, too flat) have the threaded valves.
France, Spain, Portugal: Ezy-Click, (old skool puncture type can be found as well). Haven’t been to Italy for a long time, so I don’t know. Sidenote: I don’t get on in Italy. Could be just me…
Greece! Almost only puncture (C216) although I have seen threaded. Times may be changing.
I don’t know if the type in the OP are available in Europe. New to me.
Thanks again
Thanks again
Liked 1,465 Times
Thanks again
Thanks again
I have talked to people that carry two stoves in Europe, one for Ezy Clic and one for threaded. I bought a used MSR Super Fly on Ebay that will work on both, I bought it specifically in the event I ever went to France. Primus also makes a stove, the word Duo is in the model name that I have heard will work on Ezy Clic canisters and threaded canisters.
https://www.primusequipment.com/eu/e...imer-duo-stove
Someone in the past on this forum has said that Decathlon stores in France have threaded canisters.
Photo of my MSR Superfly on an Ezy Clic canister. (Someone was giving away a couple of these canisters at a swap meet since he did not have a stove that worked on them, I was happy to take them off his hands.)
The MSR stove in the photos above will NOT work with the nozzle type adapters that I cited earlier in this post. Only threaded stoves will work on those adapters.
aka Timi
I don’t recall seeing threaded cans in Decathlons in France. I was there this September. Could check out their website.
Ezy-click, yes, and it’s about the cheapest place to buy them. Mr. Bricolage (a hardware chain) have them too, and some of the larger supermarkets. It’s a bit hit or miss.
The Primus Duo does work on both types, though unless you’re going ultralight, I’d recommend the Primus Mimer Duo. Robust and your frying pan won’t slip off so easily.
A duo on a very windy french Atlantic beach. Guitars make great windshields
Palmer
Liked 1,817 Times
Down the rabbit hole: the old "puncture canister to threaded stove" adapter:
~If~ you live/tour in a place where puncture canisters are sold, this isn't a bad deal since the puncture canister is the least expensive - and easiest to recycle.
Quoted: 18410 Post(s)
Liked 15,530 Times
I seem to recall some campers using an older version of that in Spain 2000. The canisters that automatically sealed when you removed the burner were hard to find in the south.
Liked 1,465 Times
The stove on the adapter is an old Primus Powercook, that is a stove for threaded canisters. I cropped this out of a bigger photo.
The black tape on the top of my upper spare canister is to cover the punctured hole after use, they did smell.
To pack that adapter, they are big and heavy so I would not bring it unless I really thought I would need it on a bike tour outside USA.
A couple decades ago a locally owned camping goods store went out of business. I learned about their closing sale well after the sale started, by the time I got there weeks later almost everything was gone but they had that adapter for about 90 percent off, so at that price I thought that if I used it once, it would pay for itself. And have only used it for that one trip where I took the photo.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
I use the small 100 gram container, articles I've read said they'll last a weekend? that size for me lasts 4 weekends, I carry a spare 100 gram cantainer when I have just one left.
There is a device called FlipFuel, this thing will take an almost empty canister and transfer it to a full canister, assuming there's enough room, but would be useful for those that find almost empty canisters in the trash while camping: FlipFuel Review: Transfer Your Half-Empty Fuel Canisters Into One | GearJunkie
Quoted: 408 Post(s)
Liked 184 Times
Oh an backpacking trip recently I used an alcohol stove using Heet Gas-Line Antifreeze and Water Remover, 12 fl. oz. 28201 - Advance Auto Parts
Quoted: 1182 Post(s)
Liked 833 Times
MSR Pocket Rocket- left side, threaded canisters only, and Primus Duo- right side, threaded and non-threaded canisters.
The Primus stove is heavier, but it worked well in 11 European countries.
Liked 1,465 Times
Thanks for the photo. The Primus Duo attachment to the canister looks better to me than the MSR Superfly that I have, the Superfly has a piece of aluminum riveted into a piece of plastic that does not grip the canister as well as I would like.
Liked 4,217 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 15,530 Times
