Shimano CS-4600 Tiagra 10spd (12-30t)
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
Basically any shimano or SRAM 10 speed road cassette
Likes For dedhed:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
it entails ATTEMPTING that cog size and cranking the B-screw in All the Way.... crossing fingers and quietly mumbling incantations may help.
and IF it fits, a new chain cut to the correct length will be needed.... and i'd strongly advise the "Small-Small" chain length setting method but someone will say that it doesn't work for them, so i won't mention what has worked for me since 1968.
Likes For maddog34:
Quoted: 128 Post(s)
Liked 98 Times
Quoted: 6191 Post(s)
Liked 4,807 Times
It has to be a 12-30 10 speed casssette or can you make do with a 12-28?
https://www.universalcycles.com/shop...2&category=534
If you have to have 12-30 then it's available in the higher price point Ultegra CS-6700
https://www.universalcycles.com/shop...4&category=534
Other brands too. But this isn't filtered for Shimano compatibility.......
https://www.universalcycles.com/shop...p?category=534
Likes For Iride01:
SE Wis
Liked 3,390 Times
Likes For dedhed:
Quoted: 128 Post(s)
Liked 98 Times
Liked 4,807 Times
Seems like a important thing to know. At least it is if we are talking about what range you want on the cassette. This is your opportunity to change to something else if you need it.
If you seldom use the 30 tooth cog, then you might just get something with less teeth on the low gear. 28 or even less. If you need that 30 tooth cog and there are somewhat frequent times when even it is not enough, then a 32 or 34 tooth might be the thing to look for the low cog. However then you'll have to know exactly what your rear DR is so you can see if it'll handle bigger or not. The part number for the DR will be stamped on the backside of the parallelogram if it's Shimano and can be difficult to see with the wheel in. Might be gunked up too.
Likes For Iride01:
Quoted: 1943 Post(s)
Liked 2,164 Times
Likes For 70sSanO:
Quoted: 128 Post(s)
Liked 98 Times
It's a trek-domane-4-3-compact-56cm with a Shimano CS-4600 10spd, 12-30t
Quoted: 430 Post(s)
Liked 460 Times
Get any 10 speed 12-30t cassette, but they are not as common as 11-28t and 11-32t cassettes. You might be able to get the 11-32t to work; for sure the 11-28t will work but it might not give you a low enough climbing gear. If you need a lower climbing gear you might as well go with a 11-34t or 11-36t, but that may require a new rear derailleur.
SE Wis
Liked 3,390 Times
So basically it's "what was there" not "what I need" or "what I can work with"
If you don't find yourself running out of low on hills with the 30, you could probably easily go to the more available 28.
If you can push the 12 an 11 shouldn't be an issue either
Liked 4,807 Times
And what do you want to do for that trek-domane-4-3-compact-56cm with a Shimano CS-4600 10spd, with a 12-30 cassette? CS-4600's are no longer manufactured but there are other 10 speed cassettes you can put on it.
There'll be other considerations too when you change the cassette. One will be chain length. And getting a larger tooth count low cog might require a DR change. Also, if you have decided your cassette is worn out, then I'm assuming it's because you put a new chain on the bike and it now skips on some of the cogs. But if you haven't replaced the chain and there isn't any skipping, then there probably isn't any reason to change a 12-30 cassette for a 12-30 cassette.
Don't be shy...
Open up and share some details about why you seem focused on it being a 12-30 CS-4600 and nothing else.
Don't be shy...
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Liked 1,464 Times
I run a 50/34 chain ring combo and have no real need for an 11T cog in a 11-speed cassette, and am hardly the only one (here on BF) who thinks so. OP is trying to replace a 10-speed 12-30 cassette, so using a 11-XX model may increase the gearing gap between cogs by more than he is comfortable with. I agree he needs to examine/discuss his cassette and gearing needs to see if other cassette options (e.g., 12-28) are suitable.
But just for fits and wiggles let me throw another option out here:
Prestacycle UniBlock Cassette | 10-Speed Shimano / SRAM for HG 10 Freehub - Prestacycle
Liked 2,164 Times
That 12-30 is a really nice cassette with very good gapping. If you like it, Amazon has the CS-6700 for $63 on their CS Saturday sale.
https://www.amazon.com/SHIMANO-CS-67...TF8&th=1&psc=1
John
John
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Shimano is conservative with their ratings. Going 2 teeth over the rated number of teeth will almost always work. Just make sure it doesn't bind in the large-large combo before you ride it.
