What is a hybrid a hybrid of?
It's generational.
A hybrid was the marketing hype in the 90's
A gravel bike is the marketing hype in the 2020's
And if you're offended that someone says a hybrid is the same as or a pre-curser to the gravel, you're too sensitive
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
A hybrid is the opposite of a monstercross.
Simple.
Simple.
Car dependency is a tax.
Likes For base2:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Originally Posted by cyccommute;
You keep moving the goal posts. Now they have to be tubeless ready. That can be changed if desired. Or you can do tubeless the old school way.
A “gravel bike” is kind of nebulous as well. There’s racing, all road, gravel, bikepacking, etc. It’s just as open a term as “hybrid”. In fact, “hybrid” is probably a better name since gravel bikes are just road bike built to act like a 1990 mountain bike or a 1990 mountain bike modified to act like a road bike.
Guest
Liked 3,270 Times
Originally Posted by MarcusT
It's generational.
Guest
Liked 3,270 Times
Originally Posted by badger1
Oh, and yes: the term 'hybrid' is utterly meaningless in today's bicycle market.
I think “hybrid” initially held promise as describing a happy medium between road and mountain. I just wonder if it has skewed so far away from the mountain bike side that the name really applies anymore.
Not offended, just unconvinced. But, hard as it is to believe, that’s not the topic anyway.
Likes For MarcusT:
Guest
Liked 3,270 Times
This was Bridgestone's take:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Thanks for clarifying that when you said earlier that "modern hybrids are just flat bar gravel bikes," you really meant that "some higher performance hybrids" are like gravel bikes.
Can you show an example of one of these higher-performance 1X hybrids that has a carbon fork, hydro discs, gear braze-ons, and big tire clearance? I don't think I've encountered one.
Some options that fit most if not all the criteria:
https://www.specialized.com/us/en/di...=322110-199972
https://www.specialized.com/us/en/si...=322036-200213
https://www.jamisbikes.com/bikes/urb...itness/sequel/
https://konaworld.com/dew_deluxe.cfm
https://www.norconorthshore.com/prod...r-384114-1.htm
https://www.pedalroom.com/bike/yarrr...ablooner-34927 (a shameless plug for myself, I do need to get photos of it in current mode but it has decent tire clearance (I haven't totally maxed it out) and fits the other requirements and has ridden on gravel many times.
Honestly in the end a bike you ride on gravel could be considered a gravel bike. Some bikes are certainly more ideal for gravel but I think we get so hung up on naming sometimes but when we look back into history most bikes at the time were gravel bikes by default as roads weren't really there. I mean look at the Buffalo Soldiers who rode almost (or maybe all) of 2000 miles back in 1897. They rode a 1x bike back then festooned with frame bags and handlebar bags and this was 1897 https://onlinebicyclemuseum.co.uk/18...ding-roadster/
https://rediscovering-black-history....iment-part-ii/
I say gravel is just a surface and in the end if you enjoy riding on it and you can handle it with your bike, go for it have fun and you'll be fine.
Quoted: 4227 Post(s)
Liked 2,488 Times
Hybrid is a jack of all trades master of none type of a bike. Good for pavement, commuting, fitness riding and not too bad off pavement if you put some off-road tires on it. Just like a crossover suv.
Liked 2,488 Times
Muirwoods has clearance for up to 29 x 2.1 tires, which makes it very suitable for off road riding... DSX can fit tires up to 700 x 50 mm.
It still works like it did if you replace the "mountain bike" with "XC mountain bike".
Likes For subgrade:
Bikes: Way too many
Quoted: 900 Post(s)
Liked 606 Times
I still see them as a hybrid between a mountain bike and a road bike, albeit not an aggressive version of either.
To be fair they do suit a lot of people who only want a single bike. They aren't better than a mountain bike off road or a road bike on the road, but if you only take it out a few times a year along some MUPs and easy trails then they do the job perfectly.
If I only had a single bike (!!) then I'd probably have a hybrid with one of the 63mm suspension forks, and some fairly chunky tires.
Quoted: 2482 Post(s)
Liked 2,955 Times
The term "hybrid" (referring to a practical, versatile, comfortable bike) could only have been coined in an automobile-centered country, where such unglamorous bikes were of no interest. Elsewhere, they have been used for everyday transportation since the early 20th century and are called (in various languages) simply "bikes."
Likes For Trakhak:
Bikes: Bicycles? Yup.
Quoted: 481 Post(s)
Liked 1,582 Times
Hybrid, schmybrid, whatever you want to call it, the bike for the Mrs is not out there (or I haven't found it) and all the new bikes I've seen so far require changes upon purchase.
Requirements
CF frame preferred, would go AL
commuter style handlebars, higher than the saddle
1x electronic shifting
disc brakes preferred
Canyon Roadlite CF 9 is close, would need different stem and handlebars.
Requirements
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
While I don't necessarily agree that a hybrid is just a straight bar gravel bike, my first adult bike - a 2002 Cannondale Silk Adventure 400 has clearance for at least 45mm tires. Some gravel bikes don't have that much clearance. It also has a front shock which most modern hybrids don't seem to have. In fact, when the Cannondale Quick first came out, I didn't see it as anything except a road bike with straight bars - or what I called a "rybrid" or somewhere in between a road bike and a true hybrid bike. Today, my old hybrid would probably be considered very close to a hardtail 29er. And looking at today's Cannondale Adventure, it looks more like a comfort bike than a hybrid.
Likes For Lombard:
Quoted: 4405 Post(s)
Liked 4,856 Times
In the UK "hybrids" are usually flat bar road bikes with upright geometry and fairly wide tyres. Aimed at either city commuters or for very tame on/off-road riding. Also mostly aimed at the lower end of the market, although Canyon offer some pretty high-end "hybrids" which are very much flat bar road bikes.
Quoted: 6193 Post(s)
Liked 4,809 Times
Interesting. They call the FX Sport 4 a "fitness bike for riders who want the speed of a lightweight road bike with the comfort and control of a flat handlebar," so I guess it's a "hybrid" of a fitness bike and a flat-bar road bike.
Neither the Trek nor the Sirrus has tubeless-ready tires or wheels, so maybe that's what distinguishes them from true gravel bikes. I suspect the geometry is different as well, but I haven't bothered to compare.
IMO, all of this just further establishes that "hybrid" is an outdated term for a vague-at-best bike category.
edit.....
Well heck, seems I'm wrong, Trek still lumps them by a Hybrid category.
https://www.trekbikes.com/us/en_US/b...-bikes/c/B528/
I guess just like 700C tires the term will be with us forever. The manufacturers probably wont fully let go of it as long as we continue to use it. And we won't let go of it if the manufacturers keep using it.... a viscous circle!
Quoted: 1944 Post(s)
Liked 2,164 Times
IIRC, in the early 90’s when mtbs became popular, a large number of them were only used on pavement. There has been, and always will be, a large segment of the cycling world that will want flat bars.
Manufacturers basically put out a 700c version of a hardtail with a triple crank. The gearing fell in between road and mountain, although easily mtb gearing was not very low compared to later years.
I don’t see it as marketing hype, but supplying a bike to a lot of people who will never ride off-road, nor ride drop bars. I don’t have any numbers, but I would guess hybrids have outsold their counterparts over the years.
John
John
Guest
Liked 3,270 Times
Agreed, and my intention wasn't to bash the bike. They clearly fill a demand, even though the category has morphed into something that only tangentially corresponds to the name.
Likes For Rolla:
Guest
Liked 3,270 Times
They're sort of the mini-van of bikes: unglamorous but useful.
Guest
Liked 3,270 Times
Likes For Rolla:
Quoted: 3952 Post(s)
Liked 7,297 Times
I think this was discussed in an episode of Seinfeld.
Sock Puppet
Liked 863 Times
https://www.cannondale.com/en-us/bik...&priceMax=2975
In fact, they only have 3 categories - Road, Mountain, Active and Kids. Active includes the subcategories of Fitness, Urban and E-bikes.
The latest Adventure looks like the rentals you would find near bike trails and in some cities.
Quoted: 18415 Post(s)
Liked 15,539 Times
Likes For indyfabz:
Passista
Quoted: 866 Post(s)
Liked 721 Times
IIRC, when hybrids first came out they were like MTBs with 700c wheels, less extreme low gears and non-knobby tires. No suspension fork, but MTBs didn't had them either back then.
