View Poll Results: How often do you clean your brake rotors (or rim surface) and pads?
Regularly (How often)
3
7.89%
Here and There
12
31.58%
No
23
60.53%
Voters: 38. You may not vote on this poll
How often do you clean your brake pads?
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
I am referring to disc brakes here in specific, but this would very much apply to regular rim brakes as well.
After pulling out the pads on all three of my bikes, and scrubbing them down with a metal brush, I find that the braking performance is now stronger and smoother. I will now get into the habit of doing this regularly, as all three bikes had heavily caked on brake dust/dirt mixed together which is then glazed into the pad due to the heat. I used a softer bristle brush to remove excess dust after removing the dirty layer. Avoid using a rag unless it is perfectly clean as you will just rub oil into the pad.
Quoted: 6178 Post(s)
Liked 4,795 Times
Almost never. Although sometimes I might get something on the rotors while cleaning or lubing my bike and I'll spray a little isopropyl or ethanol on them and wipe them clean.
Drip, Drip.
Liked 193 Times
Interesting how all three of my bike responded somewhat differently after doing the same pad and rotor cleaning for each set of brakes respectively.
Drip, Drip.
Liked 193 Times
good braking habits involve linear, gentle application of braking force, which allows for enough gentle heat transfer to ensure good bedding between rotor and pad while keeping the rotor surface relatively clean.
Doing hard, random stops, especially in dirty conditions is pretty awful for the longevity and overall performance of your brakes. keeping the surfaces clean and occaisonally applying some gentle braking down a steep hill would be really helpful in such conditions.
Liked 4,795 Times
I'm not sure I agree with the gentle braking. Especially if it's long periods going down long slopes. Gentle braking I reserve for the times I need to feather the brakes, usually the rear for me. Otherwise, when I need brakes, I use them. IMO, slowing down quickly generates less heat over all then dragging a brake forever to slow down. I'm not saying do a max effort braking though. Though depending on the situation and exactly how you are using the brakes, YMMV.
Likes For Iride01:
Drip, Drip.
Liked 193 Times
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Sounds like you've got it figured out already -- I don't see the point of the thread/poll.
Likes For Rolla:
Liked 4,795 Times
For cars, trucks and even bicycles, most of the stuff I've read suggests firm braking is better for brake pad and rotor life. Dragging ones brakes is ineffective for stopping and just creates unnecessary heat which is bad for every thing.
Now if you are talking about hard stops where the bike or any other vehicle is going so fast that the braking can't be accomplished before the parts get too hot, then I might agree.
Likes For Iride01:
Drip, Drip.
Liked 193 Times
The pad compound for disc brakes on most bikes i've seen are high performance, designed primarily for hard, irregular use. These type of compounds are dusty and require more cleaning than others.
The linear use of brakes can't always be followed for safety reason. If you rarely get the chance to get some smooth, long stops in, you'll want to take apart your brakes to clean and allow for re bedding more often.
Assuming your pads are coming into contact with the rotors evenly, occasional linear, controlled stops at maybe 75% reasonable effort without locking your tires is super critical for long term performance.
ignominious poltroon
Quoted: 2228 Post(s)
Liked 3,412 Times
Why is it that companies like Shimano that make disc brakes and pads never suggest these sorts of cleaning rituals?
Apart from sanding superficially contaminated pads, at best this is unlikely to do anything useful. You are probably far more likely to further contaminate your pads than you are to restore them using the procedure you suggest.
Likes For Polaris OBark:
Guest
Liked 3,270 Times
Likes For Rolla:
Drip, Drip.
Liked 193 Times
It is an undeniable learning experience for fellows such as yourself
Guest
Liked 3,270 Times
Likes For Rolla:
Quoted: 94 Post(s)
Liked 151 Times
I will file the surface of rubber brake pads that are glazed or use the file to smooth them if they have a ridge (caused by rims that have an indentation) and then clean the rim using isopropyl alcohol. This can improve braking if the pads are still relatively pliant but not if they are old and hardened. This often provides some improvement in braking but falls short of what can be achieved by replacing the pads. Filing does not work for disc pads and I have not found a way to clean them but I do use isopropyl alcohol and sometimes Brakekleen to clean rotors. This can sometimes cure squealing but often replacement of pads and rotors is needed.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
I started to respond to all the things Moisture gets wrong in this thread, but it would be a lot easy to just state the parts I agree with.
That’s about it.
That’s about it.
Likes For Kapusta:
Liked 3,412 Times
Take the pads out and tap them on a hard surface. The "dust", which is from the pads themselves, will fall off. This the the magical force of gravity at work. Wipe off the pistons while you are at it.
Happy With My Bikes
Quoted: 880 Post(s)
Liked 2,304 Times
I picked "No" in the poll as that was the closest option to never. I don't consider brake dust to be contamination.
Likes For Chuck M:
Quoted: 6944 Post(s)
Liked 10,944 Times
This is all nonsense...But then, that was a foregone conclusion, since Moisty is the OP.
It still makes for fun reading, though.
Likes For Koyote:
Quoted: 603 Post(s)
Liked 1,062 Times
I’ve got one bike with some vintage Campy Omega dark anodized rims, on that one I clean the pads quite often, trying to keep brake surface from becoming silver. So far successful, my others with silver rims never.
Tim
Tim
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
I squeeze the brakes easy when I wont to come to stop slowly, I squeeze them a bit harder when I want to slow down fast. I adjust them when needed. That about all the thought I put into the brakes. I figure they get clean enough when I clean the bike.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I can't recall ever having cleaned brake pads on any vehicle I've ever owned
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Advanced Slacker
Liked 2,534 Times
I did actually just sand, torch, and clean the pads on the front of my mtb today. They somehow got contaminated. We’ll see if it helps.
Drip, Drip.
Liked 193 Times
The mechanical disc brakes on my Opus now have pretty sufficient stopping power after taking the pads out to sand them down twice. I also swapped the pads front to rear on the second go to help distribute things out a little. The pads seem to get contaminated easily which doesn't help when most of the use these brakes see is hard used, short distance speed scrubbing.
