Let me get this straight: <52cm frame + 700C wheels = problems?
So I (5'3" / 160 cm) have been looking for bike to do some short tours and commutes with, for starters, and on a budget.
Is the dominant understanding that you simply can't find a well-proportioned frame with 700c wheels in sizes 52cm and under?
What I've gathered from reading what Georgena Terry and others have said about designing bikes for riders my height and under (plus looking at dozens of x-small road bikes on the used market) is that if you want to cram 700c wheels on a "level toptube" diamond frame with a seat tube of ~52cm or under, it requires compromises with the seat tube and head tube angles, meaning that the seat tube will be at a near vertical angle whereas the head tube angle will be notably slack? This seems to apply to at least most of pre-2000 road frames in the smallest of sizes.
Now, from theory to practice, I found an 80's road frame for cheap since the previous owner complained about the handling. I'm building it up, as an experiment, with 650B wheels and 38mm tires that it clears surprisingly fine.
With that configuration, I'm just barely able to straddle the top tube (=standing over it the bike slightly tilted or on my toes). Also numerous size calculators suggest that with ~70cm cycling inseam I'd need something smaller than 50cm, with answers ranging from 45 cm to 48 cm. I haven't been able to test ride my "experiment" yet, because I'm still waiting for some 155mm cranks in the mail to compensate for a meager 250mm of bottom bracket height after the 650B conversion. Let's see how that goes.
Now I've also got my eyes on a good deal on a sloped toptube frame for 650c wheels, but I'm concerned that with 38cm seat tube and 47,5cm (actual, not "virtual"?) toptube it might be even too small for me?
Since 650c wheels and tires in all but the skinniest junior training sizes are hard to come by, I'd perhaps consider mtb-sized 26" (559mm) wheels with >1" slicks for that frame...
I'd like to hear how this all sounds to you, and which route you might suggest me going?
I am potato.
Quoted: 1784 Post(s)
Liked 1,622 Times
Your bottom bracket seems low to me. I'd be concerned about pedal strikes even with the shorter crank arms.
A taller wheel/tire size would bring everything up.
So would a fork with a longer axle to crown measurement. But, I gather your stand over height doesn't allow for much of either.
Something about this whole thing seems "off" to me. Can you post pictures? Rims lining up with brakes would be a sure-fire way of getting in the ballpark WRT wheel size & Terrys aren't known for toe overlap or other fitment issues. IOW: She knew what she was doing....Are you sure this is the proper OEM fork?
I just feel there is more to this somewhere.
What is this '"80's road frame you found for cheap?"
I would default to these guys being an authority on the matter.
As for the other candidate, it looks like this
With the little info I have (while waiting for the seller to respond to my questions) I tried to make a geometry model, had to guess-timate most of the measurements but here goes:
So what I know is head tube 10 cm; seat tube top to center 40,5 cm; toptube 47,5 cm (which for this model I assumed is measured from the actual, sloped toptube, not the virtual horizontal line which would close in to 50 cm, but OOH I have long arms&torso in relation to my lower half)
322mm radius is for 559 wheels with inflated 42mm tires.
Quoted: 237 Post(s)
Liked 452 Times
I'm 5'4" and ride a 52cm Aethos with 700c wheels...works great.
I've also ridden 49cm frame with 700c wheels...no problems at all
I am potato.
Liked 1,622 Times
I don't think I mentioned anything about brakes or forks so I struggle to follow you here... In terms of brake reach, it's pretty reasonable at 50mm with the said 650B wheels, and I'm confident this is the original fork for this frame. It's a mid-80's low end Rossin "Infinity" road bike in the smallest size, 50cm. I've only just run a mockup configuration, and as of now I don't have a good pic of the bare frameset.
Anywho. If you're confident everything lines up as it should, then all is good as far as I can see.
Car dependency is a tax.
Wow, sounds like someone tried to construct their own "minivelo" without knowing what they were doing!
The 650B mockup makes the wheelbase appear quite long, I'll see how that will affect the handling.
Sub-10" BB height (250mm) sounded low for me too, but I just read from Dave Moulton's blog about his 1953 TT machine having only 9.25 inches (23.5cm)! So I guess, with the shorter cranks and watching out at tight corners I should do fine.
I'm really intrigued with the rusty NOS frame pictured above despite sloped top tubes not being exactly my thing, aesthetically. The seller told me that even the virtual top tube would be under 50mm, and that the frame should clear 28x650c tires, no wider - so no hope for 40mm 26" I guess?
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I have been a frame builder for the last 20plus years and am an small frame expert. If your cad pic is accurate as far as seat height, I would recommend a shorter seat tube. Face it you are really short. To have a frame with the right per-portions, you should strive to have even more seat post showing, than your head tube size. If you don't do it, it look like you have this little stump sticking out of the frame. I am 5'-6", and used to ride a 52 cm for many years. so sure, I could ride some huge frame, but so much nicer to have one with more stand over. so, my bikes tend to have 10cm/ 4" shorter seat tubes, (42 cm), I even have an old Bianchi with a 38cm seat tube. I think you should go with less than 36 cm, without considering anything bigger. On BB height: It really depends on your riding style/ how much it bothers you about forgetting and pedal thru a corner and dig a pedal in in and potentially crash/ get scrapped up. I used to race a lot and when riding a lot of Criteriums with a 10.5 BB, I would occasionally strike a pedal. I tried racing on a bike with a 10.5 BB. Instead of striking a pedal, it would really dig in. I would be lucky to keep it upright. (not fun). Plenty of people don't pedal thru corners/ have low bb's. 10.5 is a really common standard, for a bike with 700c/ wheels 170 mm crank arms.
Likes For headwind15:
On the other hand, I you are right, then that sweet 38cm seat tube, 47,5 cm top tube 650C NOS Colmbus SL frame I found on eBay might just do the trick?
As I've got most of the parts already at hand, I'm going to build up the old 50cm Rossin just to get to ride and see how that feels.
Considering tecnhology etc. I find myself drawn towards the C&V segment, but if I bought a say, post -1980's frame, I wouldn't have any problem per se fitting it with modern components. It just appears that I might be able to get better weight, build quality etc. for the price by going with older standards and used stuff...
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
You have a huge advantage that you have the Rossin to try out. I would guess that the Rossin has a 51 or 52 cm top tube. If you really want a 47.5 top tube and don't want foot overlap, yea, you will need to think smaller wheels.
I'm not claiming to know much about bike sizing or fitting, so I have no idea wether a 47 or 52 cm toptube would be better for me. I would guess handlebar and stem reach also play a part here? I've never had a bike with drops, so I'm thinking of a swept back "comfort bar" with a modest rise, or maybe one of those moustache bars with frop levers at the bends, which would stretch out the position quite a lot compared to say, north roads, right?
Quoted: 1557 Post(s)
Liked 1,732 Times
That steel frame looks to be too small for you. The bottom bracket height is 243mm! I think it was for junior racing.
Back in the mid 90s' to the mid 2000's, Trek and Cannondale both made a bunch of 650c wheel road bikes. I feel these are the best options for shorter riders. I would keep an eye out for those if I were you. This is a 44cm Cannondale R500 I got for my son who was around 5'1" when I bought him the bike:
I put the 155mm Origin8 crankset , short reach Microshift brifters and Panaracer Pasela 650x28c folding bead tires on there.
650x28c and 650x25c wire bead Pasela tires are available all the time. 650x28c folding bead Paselas are available once in a blue moon.
Likes For icemilkcoffee:
Here's the ebay page for that frame, for that price Columbus SL and >1700 gram sure sounds like a steal, right? https://www.ebay.com/itm/26557287338...sAAOSw3f5hcWxp
Judging by the measurements, it seems that frame might have been designed with 24" rather than 26"/650C wheels in mind?
I've been keeping my eyes open for any Cannondales etc. in the right sizes, but so far I've only come across 48-50cm bikes with 700C wheels and awkward seat+fork angles.
The Rossin is coming together albeit slowly, as there still seems to be some issues with availability of parts, namely ITA bottom brackets. One I bought from LBS wasn't the right length after all, so I'll have to order somewhere else.
At the moment I have two 155mm cranksets, a Dotek without chainrings and a Miche Young double with 35-42. I first bought the Dotek from abroad for a little too much, and then I found the Miche locally for much less. The Dotek crank was sold as a BMX crank, but it's obviously meant for double, and the spider looks like it would be easy to drill&tap for triple too. I've heard these Doteks have some bad cred, so maybe I'll try the Miche first.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I believe that unless you put a super high stem on a frame with a 47 cm top tube, your knees are going to hit the handlebars. I do not know of/ never seen geometry for / have never seen an adult bike with a (super short) 47cm top tube.
Finally some pics of the Rossin in its current state! Those 170 mm cranks are there just for test, they look huge with 130mm bcd and the bashguard! Brake reach on these old Weinmann scissor mechanism center pulls is just enough, I considered going with a pair of modern long reach dual pivots, until I figured that might cause some problems with fitting 42mm wide fenders.
The cockpit is kinda weird, I know that. It's there just for a test, I'll figure it out once I get to try how this thing rides. The inverted levers appealled to me because they seem to provide a short reach for my stubby fingers. The swept back comfort bar is to keep my head up high in traffic, and the quill adapter - ahead stem combo is supposed to allow ease of adjustment even after installing handebar tape. Shifter placement is something I'm not very sure about: I'm not used to downtube shifters and the reasonably high handlebar would put the levers quite far down from where my hands are, so I've been thinking about going with either stem-mounted or thumbshifters. I have a Suntour V GT Luxe / Vx set in the parts bin, so I'll probably try that first. This build sure is not for C&V purists
Based on my rough measurements the Rossin figures out something like this:
Compared to my other bikes, a late-80's Schwinn Impact with a 54cm top tube and a 52cm-ish Mercier mixte with a whopping 56cm of effective top tube, this steed sure feels short. But maybe that's just right?
Likes For Krov9:
Quoted: 6178 Post(s)
Liked 4,796 Times
Looks nice, but with that low stack and effective short top tube length will your knees miss the bars?
