Best bar end mirror
Quoted: 192 Post(s)
Liked 11 Times
Best bar end mirror
What do people like? I’ve been using the Hafny bar end which is pretty solid. Heard good things about sprinttech but it seems cheap. Any other thoughts?
would rather no mirror for looks. But also don’t want to get killed on the road!
this is the hafny.
https://www.amazon.com/gp/aw/d/B07WH...b_b_asin_title
this is the hafny.
Likes For TiHabanero:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Garmin Varia RTL515. Aesthetically pleasing and it has a light to warn following traffic.
Likes For Badger6:
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
Likes For datlas:
Love my Cateye bm-45 mirrors.
- lightweight
- inexpensive
- works really well - glass mirror=sharp image; can adjust angle on the fly if needed
- Low key and unobtrusive on a road bike
this is the hafny.
this is the hafny.
Quoted: 4559 Post(s)
Liked 2,802 Times
Sprintech. Excellent value. I have 'em on two of my three road bikes, and plan to add one to the third.
The ball joint holds securely but is easy to adjust on the fly. Occasionally I knock it out of adjustment against a wall or with my knee, but it's easy to reset. It doesn't lose adjustment on rough roads.
The Italian road bike mirror is a bit more pricey but reportedly very good - a couple of friends use them. They said there's no way to adjust the mirror after it's set, so it's essential to set it correctly for your riding position.
Quoted: 1528 Post(s)
Liked 718 Times
Someone posted the ultimate mirror the other day: a lens from some mirrored sunglasses stuck on the back of their glove.
Bam!
Bam!
Add me to team Sprintech - been durable enough, cheap enough, good enough.
Likes For bruce19:
Quoted: 645 Post(s)
Liked 797 Times
this is the hafny.
this is the hafny.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,283 Times
My wife has been through a ton of barend mirrors ever since she broke her neck and had to get spinal fusion surgery (limited head rotational range-of-motion makes mirrors a mandatory accessory for her...which she uses in addition to the Garmin Varia rear-facing radar).
After trying the Mirrycle, the Sprintech, two different Hafny models, and the Berthoud, the one she found best -- based on clarity of optics, ease of adjustment, and not needing to be constantly readjusted (i.e., staying in one position, not getting jostled around just from the act of cycling) -- is the ~2.25" diameter Hafney HD Convex Blue Glass Mirror with the Automotive Grade Glass. https://www.amazon.com/gp/product/B07WMMQJFW/
Quoted: 1743 Post(s)
Liked 1,281 Times
My wife has been through a ton of barend mirrors ever since she broke her neck and had to get spinal fusion surgery (limited head rotational range-of-motion makes mirrors a mandatory accessory for her.../
Likes For bruce19:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Tried bar end mirrors 20 years ago. The forward lean angle makes them very difficult to see, requiring taking my eyes off the road in front to look down and slightly back. It took only one ride to realize what a bad idea that was.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
I only tried the sprintech. It was tolerable, but seemed as likely to cause a wreck rather than prevent one.
