Varia on long rides
Varia on long rides
Hi all
anyone using Varia radar on long (14 hours and more) rides ? Any tips its battery only 17 h charge
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I don't think the Varia has enough battery to last more than 3-4 hours on a single charge. However, I just tested mine out and it *will* operate while its charging. So your best bet is some sort of portable power supply. If it were me I'd probably use a compact power bank, stash it in my saddle bag and run a charging cable to the Varia. Something like this: https://www.amazon.com/dp/B005X1Y7I2...ogi&th=1&psc=1
A generator hub might be another option but I've never used one and I don't know if they provide enough power to simultaneously charge and operate the device.
Likes For ksryder:
Quoted: 6193 Post(s)
Liked 4,808 Times
Which version of Varia? The original, current version with light or current version without light?
The current version with the light actually is expected by Garmin to go 16 hours if in "day flash" mode.
- Battery life: 6 hours solid, 8 hours peloton, 6 hours night flash, 16 hours day flash
- Battery life: 7 hours
Bikes: yes
Liked 643 Times
At any rate, I did confirm that the Varia will run while charging.
Quoted: 18883 Post(s)
Liked 10,646 Times
You can put a small battery pack in your saddle bag and run a USB cable to the Varia.
Liked 4,808 Times
Are all your rides so long the battery will go dead?
Varia's sort of nice to have IMO on the open road when you might get to daydreaming about how well you'd have done in the TdF or Veulta if you'd known back in the day that you could have gotten paid to ride a bike. (at least that's my daydream)
When it's all peaceful and quiet, other than the wind in your ears and you are cruising along, that little beep from your head unit when a car is way back there and approaching fast is nice to have.
In urban traffic, Varia might annoy and confuse you with all the beeping and alerts on your head unit.
Note what I said about the lighted version of Varia lasting longer on the battery than the unlighted version. Not sure why Garmin would do that. Maybe LED's don't add much to the cost as does the higher capacity battery.
Likes For Iride01:
What's the thing DCRainmaker says about the Varia? "Only two kinds of people when it comes to Varia: Those that love it and those that haven't tried it." (paraphrased but close).
Likes For JohnJ80:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I have a 1030 and found the Bike Lights Control app allows me to turn the light off or other function. The radar works with the light off. Still messing with it wondering if the light will come on when it sees a car and will
last longer.
last longer.
Likes For biker128pedal:
Quoted: 819 Post(s)
Liked 1,655 Times
Likes For Bald Paul:
To maximize the battery on my Varia radar, I turn off the light on the radar, and use a separate bike light (Cygolite Hotshot!)
To turn off the Varia light:
Settings -> Sensor -> Lights -> Network Options -> Light Mode -> Individual
Settings -> Sensor -> Lights -> Radar -> Light Mode -> Off
Likes For Pearson100:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
I have two and switch when the first one runs out of battery. It's pretty small and lightweight, so no problems throwing it in a jersey pocket.
The only negative is the Edge doesn't automatically recognize the second one; I have to find it in the sensor menu and manually connect to it.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
pretty much spot on. count me among the skeptical converts. got one this february and it's great. haven't been out with it for longer than six hours tho...
Quoted: 2333 Post(s)
Liked 2,097 Times
How loud is the beep on a Garmin 1030 when a car approaches? Can it be heard at 25-30 mph?
Liked 4,808 Times
Don't know if it's a volume thing or a frequency thing. I have a little hearing loss at some frequencies. So electronic beeps and alarms that don't have a full sound spectrum are difficult for me to hear sometimes.
Liked 2,097 Times
They seem louder than the beeps from my Edge 530. My son uses a Edge 1030 plus. When I ride with him, I hear the beeps from his 1030 on his bike better than the beeps from the 530 on my own bike.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Depends on your hearing, and possibly your choice of helmet since that creates wind noise close to your ears. With a Giro Atmos Synthe it's easily audible for me up to 25 mph or so, but around 30 mph or above it's definitely inaudible and I find myself glancing down on occasion to see what its current status is.
Liked 10,646 Times
Liked 4,808 Times
But if you'd explain what your needs are maybe someone can assist you.
As mentioned with the phone app it can be paired to a watch. I think elsewhere I read someone had it paired to hearing aids. So if you use headphones of any sort, you ought to be able to get it through them.
My son has Varia Vison, which is the heads up display that clips to your sunglass arm. I'm pretty sure he gets visual alerts from the Varia radar on it. Garmin discontinued Varia Vision though. Sad, I sort of wanted one, lot of useful stuff it can show you without having to look down at your Garmin Edge while riding.
Likes For Iride01:
Quoted: 1186 Post(s)
Liked 289 Times
It's a unique beep different than beeps for other notifications. I have minimal hearing in my right ear but don't have any trouble hearing normally including going down hills at up to 60kph. On the flats if there's a strong headwind it can be harder to hear sometimes but it's rare I don't hear the beeble.
Likes For gregf83:
Liked 10,646 Times
Everybody should have one of these, Varia or no. It will let you charge your phone and other things in an emergency.
Likes For Seattle Forrest:
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
That said I am not impressed by the security of the charging port for external charging.
An electronics insurance policy might pay off with a search for a low profile/magnetic plug, as well.
Same issue of needing a tether attachment point for the varia rear, for those of us with little faith in rubber bands.
Quoted: 942 Post(s)
Liked 527 Times
You really ought to watch some YouTube reviews instead of drawing conclusions from bits of information because that is not accurate at all.
Liked 2,097 Times
If you have information contrary, please let me know.
How hard would it have been for Garmin to provide a volume setting and a selectable tone for something as important as the warning of an approaching vehicle
