Lungs and heart
Quoted: 722 Post(s)
Liked 353 Times
Lungs and heart
im 55 good shape little fat but ok fitness. i find early in my rides going hard is limited by lungs for 1st 5 miles or so.
become breathless...but warmed up its the leggs that go 1st
whats behind this...any ideas.
after good warm up 6 miles then it all works but its the leggs that limit
Quoted: 5224 Post(s)
Liked 3,581 Times
Likes For rumrunn6:
Quoted: 8279 Post(s)
Liked 9,033 Times
Sounds kinda normal.
Quoted: 2952 Post(s)
Liked 3,106 Times
For me, the harder the effort, the longer my warmup needs to be.
Quoted: 722 Post(s)
Liked 353 Times
you know it in my 30's could hold 170bpm all day trained with HR...now 150 i wanna die....
Likes For thehammerdog:
Quoted: 896 Post(s)
Liked 2,063 Times
Ride more, you'll go faster and/or further.
Other than that... that's cycling.
just another gosling
Quoted: 3888 Post(s)
Liked 1,938 Times
Normal. Your blood vessels become more flexible as you warm up and can then carry more blood. You can speed the process some by doing a couple lowish gear spinups to high rpm and then a couple of hard 1 minute intervals. That'll release the chemicals which help circulation. Legs getting more tired than lungs after warmup means you're using too big a gear.
Results matter
Results matter
Likes For Carbonfiberboy:
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 97 Times
[QUOTE=
after good warm up 6 miles then it all works but its the leggs that limit[/QUOTE]
The warm up is key- have fun.
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Warmup is indeed key. For me, every eastbound or northbound ride starts with a hill climb. Southbound rides start with more than a mile of level ground, which facilitates a decent warmup. (I can't go more than about 1 km to the west without getting very wet. ) I have learned over the years to use a very low gear and to take that initial cold start climb at an embarrassingly slow pace, which makes all the difference. If I start out too fast up the hill, it takes me at least another 15 minutes to catch up to where I would be following a more gradual start. Warmup is everything!
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
I feel that way every spring on the first half dozen rides. Don't overdo it at first; you'll likely forget about it after a while, but you do have to push through some pain.
Likes For Chuckles1:
Likes For Flip Flop Rider:
Liked 3,581 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
My lungs always seemed to be the most limiting thing for my performance. And it stands to reason since they get CO2 out and O2 into your bloodstream so the muscles can use it.
It's been a 10 year process, but I don't feel as limited by my lungs as I once did. Though they are still probably the thing that limits me most. It's just that I've trained my legs and the rest of me to deal with their limitations. But.... it takes time.
Deep breathes anytime you think about breathing on or off the bike. If you cough after taking several deep breaths, then you need to work on that. I too used to cough after a really deep breath or two. Now I can breath deep and fast for a long time without wanting or needing to cough.
I read that pro cyclist have a very fast respiration rate on the bike. Somewhere on the order of 60 breathes per minute. But I only saw that once. Don't know if I was mistaken nor have I searched further for more info. Anyone else know about that?
Likes For Iride01:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
As a pro cyclist is an elite endurance athlete they should be able to produce a higher MVV than a non elite endurance athlete for sure and would think that their ability to maintain a higher than average minute ventilation would be impressive. That being said a resp rate of 60 is very difficult to pull off. I would be surprised and impressed if even a pro cyclist could maintain that RR for very long. One thing that makes me think it is unlikely is the overall cardiovascular conditioning may render RR's that high unnecessary.
As I said before I could be totally wrong but taking a big breath of air every second for minutes on end is very taxing.
Likes For Rdmonster69:
Liked 4,808 Times
Rdmonster69 Just to be clear, I might have misrepresented the article. It might be that it was only talking about certain short periods when on the bike. Or maybe something else entirely. However they were comparing that the average joe cyclist didn't have near the respiration rate of elite pro-cyclists. The main jist of the article was differences between pro's and us never-will-be-anything-like cyclists. Respiration was just a short mention in it that I recall.
Probably something I read on CyclingNews, CyclingWeekly or VeloNews. Early this year or sometime last year.
Quoted: 4559 Post(s)
Liked 2,802 Times
I'd be surprised if elite level pro and amateur cyclists breathed in any unusual way unless they were at lactate threshold. I've seen pros chatting almost normally while riding at a pace that would leave me gasping for air and passing out within 5 minutes. And recently Mark Cavendish had a few choice rants for the TV motorcycle crews who were -- possibly deliberately -- influencing or rigging a race to provide a draft for favored riders. Cav was riding very fast to catch up yet still was able to loudly repeat the same complaints to any passing judge or cameraman passing on motorcycles and cars. He wasn't wrong. I was mostly impressed that he could speak loudly and fairly normally while riding so hard. I'd be on the verge of passing out from exertion.
From the perspective of the 50+ forum, I could come up with all kinds of reasons and excuses why I'm getting slower despite working harder to stay fit. But it all boils down to "I'm old, and getting older."
Yeah, I could wish for all kinds of things to delay the inevitable. I had hoped my window of opportunity to continue getting stronger and faster would remain open at least a crack until I reached 65. But, nope. I'm about to turn 64 and I've weakened and slowed dramatically this year after a few consecutive years of steady improvement after resuming cycling at age 57. In 2015 I was starting from nothing, extremely poor fitness, so I knew I could only improve for awhile. And I did... until this year. That window of opportunity closed last year and it won't get any better without PEDs.
That's just the reality of aging. It varies for different people and some folks may continue to improve or at least maintain measurable fitness awhile longer.
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 147 Post(s)
Liked 93 Times
81, asthmatic. takes me at least 10 miles to be breathing easily
Likes For Artmo:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Specifically I would love to see a full pulmonary study including
A. Lung volumes via Plethysmography.
B. Airway Resistance
C. Diffusing Capacity using the single breath carbon monoxide test
D. Slow Vital Capacity and Forced Vital Capacity
E. Maximum Inspiratory and Expiratory Pressure
F. Maximum Voluntary Ventilation
This set of tests would basically be a full battery of respiratory muscle strength as well as standard lung functions .I would think the RMS tests would be above normal and the standard functions would not be hugely different. This info may even be out there somewhere. As a clinician I would be most interested to seeing the RMS of an elite athlete is that much different than a regular human.
Liked 4,808 Times
No worries ..... I would be utterly shocked if a pro cyclist couldn't breathe deeper, harder and faster for a longer duration than normal humans. There real overwhelming advantage is the strength and efficiency of their circulatory system.. You have to breathe far less when your heart is able to deliver mass quantities of oxygenated blood. That's why I said it was really interesting and would be very curious as to the actual physiological make up of a pro cyclist.
Getting back to breath rate, it just seems like HR. Once you have the volume maxed out then a faster rate gets you more. To how much it can contribute might be in the realm of marginal gains. But in racing marginal gains are a part of what makes a difference at the finish line.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Check out the book "Breath" by James Nestor. I thought I knew how to breathe and have never had a breathing problem, but I learned quite a bit from that book.
In the wind
I had the same problem this spring. Climbing a hill I have ridden up for decades, I realized I was climbing like a fat old man.
So, I rode a lot this summer, lost 10 pounds and attacked the hill again last week.
At that point, I accepted that I ride like an old man, but now I'm slower on the downhills.
Likes For mercator:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
Wait til you hit 70 or 75 years.......!
It usually takes 4-5mi for my suspended leather saddles to get warmed up. By then I know if the joints are ready to go. Most routes have hills, and the last 2km of every ride is hard - up the hill to our neighborhood, with a 42/24, at the end of 50mi..
