Vintage MTB brake levers.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Looking for non linear-pull/non V-brake levers with more leverage, probably achieved by longer levers.
Are Dia-Compe SS6 levers what you guys would recommend? Anything else? Thank you.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Sounds like you are looking for flat bar levers for cantis or Road calipers? AKA “short pull”? I know Shimano makes a set for pretty cheap (like $20) that I used for a flat bar conversion. They are marketed as flat bar road levers.
Have you Googled “brake levers” along with “canti”, “short pull” or “flat bar road”?
FYI: it is more than just the lever length that differentiates V-brake levers from canti/flar-bar-road levers.
Likes For Kapusta:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Have you check the Velo Orange site? A lot of stuff is out of stock, but those arent real popular, so they may have something that will work for you.
Likes For c_m_shooter:
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
These would be some of the best in the biz:
https://www.paulcomp.com/shop/compon...l/canti-lever/
Plus if you are doing a vintage style MTB, purple levers would set it off just right : )
Likes For veganbikes:
Quoted: 1943 Post(s)
Liked 2,164 Times
Dia Compe had a few designations. If I recall correctly…
The PC (Power Control) series works with cantilever, centerpull, and road caliper brakes. So do the SS series.
The DP (Direct Pull) series works with linear/V brakes.
I’ve used PC-7 and PC-11 with cantis and side pulls for years. I like the longer lever.
I would think the SS-6 would work equally as well.
Ebay has been my go to source for older Dia Compe levers, along with just about everything else.
John
John
Likes For 70sSanO:
