Chain wax-er thread
Chain wax-er thread
Anyone using this Absolute Black Graphenwax? As far as that goes, what wax are you using? I ride gravel a bunch and my main concern was the dry dusty conditions turning my lube into dirt-grit. So I started using wax and have been using paraffin wax. I generally have to reapply after 70 miles or less. I would love to come up with a wax that is more durable.
Is the Graphenwax stuff worth it? Anyone else use a concoction that extends the intervals?
Quoted: 7649 Post(s)
Liked 3,469 Times
I use paraffin and PTFE powder .... never bothered tracking durability. Do you have to re-apply because you have worn off all the visible wax or because your chain gets really noisy or what?
Liked 3,469 Times
Well .... dust and gravel?
I am not sure you are doing it right though .... because the wax is supposed to get Inside the chain, in between the rollers and pins, and it shouldn't get forced out by dust. Not sure ... but sorry, other than what I have said I cannot help.
Quoted: 4230 Post(s)
Liked 2,947 Times
I use Molten Speed Wax, but I only switched to it on my trainer bike (in part due to getting cats that like to rub up against things), so I can't compare it to riding gravel.
Quoted: 2601 Post(s)
Liked 1,925 Times
I'd never heard of "Absolute Black Graphenwax" so I searched for it. I don't think I've ever had my snake oil detector go off quite so hard or so fast.
First off, paraffin wax coming from a bottle with a spout.
Second, graphene. Wonder material when it's applied flat. It's going to have to be shaken up, in all likelihood, so the microscopic flakes are going to be randomly oriented.
Third, 3-10W friction reduction. In a bike chain application where ordinary friction is about 1 W. What are they comparing it to, the sticky gloop that was used to preserve WW II machinery and tools?
Recommendation 1: see what your local bike shop (LBS) is selling, and buy some. They should have a good handle on local conditions
Recommendation 2: if you really want to wax your chain, buy some paraffin wax, mix in your choice of additives, cook the chain in a small crockpot or double boiler, hang it to drip. Reinstall when cool.
Likes For pdlamb:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
If you melt crayons, can you get designer colored chains?
Likes For livedarklions:
Quoted: 1943 Post(s)
Liked 2,164 Times
For a romantic sunset ride with my wife, I float scented tea lights in our water bottles. Doesn’t seem to help with the shifting though.
John
John
Likes For 70sSanO:
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
Stuart Black
Stuart Black
Quoted: 763 Post(s)
Liked 1,730 Times
"*Doesn't melt off your chain on a hot day."
I've never had wax melt off my chain on a hot day. I live in the southeast, store my bikes in my garage which gets damn hot in the summer and the wax has never melted off....
I just use paraffin wax and some ptft powder
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
I think wax requires an 'investment'- it's not a squirt it on and forget it until you need to squirt it on again routine*. If you want to wax you have to really, really thoroughly strip/clean your chain (even if brand new), then give it a good long soak in your melted wax concoction in a crockpot/slow cooker. If done right it's great- clean, quiet, smooth. Personally I avoid teflon/PTFE etc- there are enough questions about the health and environmental effects for me to steer clear. I've got several chains I rotate through so I've always got a fresh wax-soaked one ready- depending on conditions is seems like I get 250-300mi or so before it feels like it's time for a swap. My wax mix is around 70/30 paraffin/bees wax. The bees wax is softer/stickier than the paraffin, the combo seems to adhere and lube well.
*I think the wax-suspended-in-liquid products are kind of pointless. If the liquid isn't some kind of solvent that completely evaporates away, it will collect dirt and grit like any other liquid lube. And even if it is a solvent that evaporates away, just squirting the product on the chain isn't going to get the wax deep into the rollers and pins where you want it.
Likes For ehcoplex:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Wax sucks, imho. I went through the whole chain-waxing spectrum of crockpots, ultrasonic cleaners, all the different wax recipes, as well as the ones that are premixed and ready to roll. After participating in dozens of discussion threads, and reading every possible chain-lube method, I've come to the conclusion that synthetic automotive transmission fluid (ATF) is the best choice for all conditions. My arguments follow:
1. ATF is reasonably clean. It does not seem to attract dust and dirt like regular oil. ATF has no tackiness to it, well, not much tackiness anyway - not as tacky as motor oil or bar and chain oil - so it doesn't get as filthy as other forms of lube.
2. It penetrates. ATF will work its way between the chain plates and pins a little easier.
3. Cleans up easier. I hit the chain with a little WD40, and give the chain a good wipe. Usually this does the trick.
4. Economical. A quart of oil - I use Mobil 1 synthetic - lasts a long time. I apply it with a refillable pump-type oil can, let it drip a little, wipe it off and ride away.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
I melt a pot of paraffin wax in the spring and dip two chains per bike for 5 minutes. I change them out mid-season. If they squeak before change out time, I renew them by pulling about 5mL of paraffin in kerosene saturated solution into a syringe with short tubing attached, and slowly depress plunger as I turn cranks backwards while letting tip of tubing ride on top of chain to apply. Best I've come up with so far for my dry conditions riding. Pretty easy with masterlinks for removal and installation. Bought a ten pound block of paraffin a couple years ago that will outlive me.
Quoted: 4391 Post(s)
Liked 4,833 Times
I've used Squirt for a number of years and found it pretty good on the whole. It Requires re-application every 100 km or so, but a 5 min job at the most and the drivetrain remains pretty clean. I've run this on dusty mtb trails without any excessive noise or drivetrain wear.
But now I've found something better. Silca Super Secret. Another drip-on wax, but it penetrates into the chain much better and had excellent results on the ZeroFriction website. I've been using it on my road bike this season with great results. It still needs re-application every 100-150 km, but again it's a 5 min job and the drivetrain remains spotless. Chain wear is also pretty minimal. Mine is only 25% worn after 7500 km, including a few really wet century rides.
Likes For PeteHski:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Liked 2,947 Times
For the drip ons do you have to clean the chains as rigorously as for the melted wax? Getting a new chain to where I think of it as clean enough takes a while and requires generation of a lot of dirty solvent that I need to dispose.
Liked 4,833 Times
Initially yes. Easier starting off with a new de-greased chain. Thereafter I rarely de-grease them again unless riding a lot in the wet (which I try to avoid).
Quoted: 809 Post(s)
Liked 1,022 Times
I follow Oz Cycle methods.
He adds Teflon. I don't. Just wax and Lamp oil.
He has a liquid version as well:
He has a chain lube test video as well:
I even used his DIY water proofer.
Liked 4,210 Times
Most of the wax based lubricants use mineral spirits as the carrier and it evaporated completely. There are wax based lubricant products that add a bit of oil to the mix. White Lightning Epic Ride is an example. But the solvent used to carry the mix evaporates. The oil (with wax in it) remains behind.
Finally, you are just dead wrong on the lack of penetration. The wax solution has a low viscosity…lower than melted wax…and a bicycle chain is hardly a sealed system. The solution will penetrate into any crevice that hot wax does, carrying the wax with it, and leaving the wax behind when the solvent evaporates. Recall that the solution is saturated, which means that as the solvent in the solution evaporates, the wax precipitates out of the solution. The only difference between the two systems is that you don’t have to drag out a pot, melt wax, and dip the chain.
Stuart Black
Stuart Black
Liked 4,210 Times
White Lightning. I’ve been using it since around 2000. I have dabbled with Rock ‘N’ Roll Red and Gold but haven’t noticed any difference in application or performance.
Stuart Black
Stuart Black
Liked 4,210 Times
The question everyone needs to ask themselves is that if all 97 steps are followed to the letter, do you get significantly better results? I know there are people who claim 10,000 miles on a chain but those claims only come from a few individuals and I would suspect an error in estimating the mileage. If all 97 steps made a difference, there would be a significantly greater percentage of people that get 10,000 miles out of a chain. Most don’t which leads me to believe that 96 of the 97 steps* are useless.
*The one step is a single wash with mineral spirits. That is all that is needed for a new chain.
Stuart Black
Stuart Black
As far as White Lightning is concerned, I don't know anybody locally who's managed to get decent endurance out of their products. This past year, one of my White-Lightning-using friends tested how it would work on his gravel bike, and the chain started screaming just a few miles after we left pavement, or about 25 miles of total endurance for that lube application.
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
Hard to properly compare without testing in the same environment. Different places have gunk that affects exposed surfaces in different ways, like how those of us from the Pacific Northwest are routinely told by people from other places that the rim brake track wear that we experience doesn't exist.
Liked 4,210 Times
Stuart Black
Stuart Black
