Does Anyone Wrap (Tape) Handlebars From The Center Outward?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Does anyone start wrapping (taping) the handlebar at the inside point, nearest the stem, and going outward?
Everyone I know starts at the bar end and works inward, so that the job needs to finish with sticky tape around the last wrap.
Seems to me, if you do it the other way and use the bar end plug to secure the wrap, you can avoid the use of sticky tape. Okay, there's a bit to hold down the start of the wrap, but it is covered by the wrap.
Am I the only one who finds the sticky tape a bit unsightly?
group W bench
When bar tape used to be flat ribbon or smooth vinyl style, this method worked quite well. The edges of the tape laid flat. With the newer cork and cork gel tape, the edges don't lay as flat. If you wrapped from the middle out, your hand would rub against the edges and peel them up (try running your hand backwards across the tape on your bar now). At the shop we use good quality electrical tape to finish the wrap. Don't tape the wrap to the bar but just cover the last bit of bar wrap. Let just a little hang over the edge and pull the tape fairly tight. The electrical tape will curl over the edge and give you a nice finished look.
Quoted: 9 Post(s)
jyl, With cork or padded tape starting the wrap at the plug prevents a bulge in the tape near the stem, starting the wrap at the plug creates a shingled effect and seems to hold up better to use, for me anyway.
Using twine to cover the electrical tape is a classy way to finish a handle bar wrap.
Brad
Brad
Quoted: 2026 Post(s)
Liked 1,095 Times
I couldn't find a reference to them right now but I've seen circular "clamps" that cover the bar tape at the stem to replace electrical tape and give a finished appearance.
Quoted: 14 Post(s)
Liked 13 Times
Some people use whipping instead of tape: https://davesbikeblog.squarespace.com...andlebars.html
Quoted: 1438 Post(s)
Liked 1,092 Times
I have found that self-fusing tape does a great job of securing the end of the wrap. It adheres only to itself so can be removed easily without a gooey mess and will not creep like electrical tape. It is also available in colors to match or contrast your bike's color scheme. Here is one vendor: https://www.rescuetape.com/ It can also be used to hold cables, etc. in a neater fashion that zip ties.
Just keep pedalling!
Bikes: 1987 Schwinn Circuit, 1987 Panasonic DX-4000, 1984 Peugeot PSV10, 1989 Centurion Prestige, 1973 Raleigh Sprite, 1987 Peugeot Canyon Express, ~1986 Raleigh Capri, 1994 Trek 850, 1984 Centurion Pro Tour 15, 2012 Gravity Zilla
Wow! There is a lot of wrong in this thread.
Yes, you can wrap top-down without any issues. There is no need for electrical tape to hold the cork tape down. It works fine with cork tape. This is now the only way that I wrap handlebars.
Here are some examples:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
And no issues with peeling, big-heineken? I started out wrapping bars the same way as the OP, and for the same reasons, but they inevitably started to peel. Now that I wrap from the ends, everything is solid.
- Scott
- Scott
Quoted: 443 Post(s)
Liked 27 Times
I have wrapped from the top down for 40 years. I don't use cork or gel tape and I don't have any problems.
Now that I think about it, it's longer than that. I got my first drop bar bike in 1960.
I also don't use tape with an adhesive back, I hate that stuff.
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,362 Times
1. If you underlay your bar tape with double sided tape (sold
as poster tape at office supply stores), you can cut down on
peeling/shifting under use considerably...which ever way you go.
2.I used to go top down. Now I go bottom up. Call me irresponsible.
3. If you use vinyl electrical tape as your fastening tape near
the stem at the top, you can seal the ends of it with a soldering
pencil with a flat tip to melt the end into the final turn. Be
careful, as it is easy to melt right through the tape.
incazzare.
I do this only with thin cloth tape, which I then shellac.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Bikes: All City Nature Boy, Salsa Ti Fargo, Kona Electric Ute
I double wrap my bars: First layer is from the cap up, second layer is stem down and I havent had any issues yet
Bikes: -1973 Motobecane Mirage -197? Velosolex L'Etoile -'71 Raleigh Super Course
I wrap the bar in two stages, from the brake levers down to the drops and so the ends; and from the brake levers on up to the stem. This way I get the overlaps going the right way for each position.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
1. I cut the end so that it forms a right triangle. This minimizes the starting bulge.
2. I start at top and under - go front - up - over - and toward saddle - down - back under - toward front.
3. Do the typical cross wrap at the levers...
4. Wrap to 1/4-1/2 inch past end of bars...
5. Fold the extra into the bars and hammer in the plugs.
The entire time I'm applying considerable stretch throughout.
Even after scrapes and other types of damage - my tape jobs seem to hold up and last quite awhile...
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
=8-)
=8-)
Friendship is Magic
Bikes: old ones
Liked 10,362 Times
Do I sense the beginnings of a new OCD thread stirring?
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
So I was told the objective of wrapping the bar tape from the bottom up was to create a wrap such that your natural riding grip would tend to tighten the tape rather than loosen it.
Probably more of an issue before adhesive backed tapes were introduced and leather, cotton and thin vinyl were the norm.
Personally I also tend to stretch and overlap the tape more than most techs which suits me but some others feel a slight tear is more likely to expand that way. Can't win em all!
I wrap from center to bar end works great never have had it get loose I use no tape or glue this tape has no stickey back as well.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Bikes: 2003 Lemond Zurich; 1987 Schwinn Tempo; 1968 PX10; 1978 PX10LE, Peugeot Course; A-D Vent Noir
Great picture, which IMHO shows the benefit of starting the wrap at the top and wrapping down to the bar ends. Notice how the tape is held nicely in place at the starting points near the stem. I've been wrapping my bars this way for more than 30 years and never thought it was the "wrong" way to do it.
