Do I need to replace my chain with my cassette?
Old 05-07-21, 08:53 AM
djdelarosa25
Quoted: 83 Post(s)
Liked 4 Times in 4 Posts
Just swapped out my 11-34T cassette with an 11-28T because the jumps were pretty big on an 8-speed. I've read that I should be changing my chain, too, as it could quickly wear out my new cassette. My chain is around 2000 km old. Is this necessary?
djdelarosa25 is offline
Old 05-07-21, 08:56 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Depends on how worn your chain is.
cxwrench is offline
Old 05-07-21, 09:04 AM
deacon mark
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times in 121 Posts
I doubt it based the mileage it can happen if the chain is too far stretched for a length of time. Frankly put a new chain on the bike and if it does not skip you are good to go. If it skips you need a new cassette but I highly doubt it.
deacon mark is offline
Old 05-07-21, 09:49 AM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
Although it might not be necessary, but since you have a new cassette, I would put on a new chain, too. Might as well start with a fresh set of cassette and chain.
As mentioned, as chains wear over time, they tend to "stretch" such that they no longer match the cogs of the cassette, and skipping occurs when pedaling with power. Your old chain may or may not be "stretched" to cause this condition. You can measure the length of your current chain (12 links should equal 12" exactly) or just pedal around and see if the chain skips. If it doesn't skip, then you should be fine.
However, I put on a new chain when replacing a cassette. More of a peace-of-mind thing for me.
MudPie is offline
Old 05-07-21, 10:49 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,782 Times in 3,300 Posts
I think you should replace your chain with a chain. <grin>
Iride01 is offline
Likes For Iride01:
Old 05-07-21, 10:53 AM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 995 Post(s)
Liked 1,202 Times in 689 Posts
I believe the conventional wisdom is that if you have a worn cassette, it will have worn your chain as well. If you're changing a perfectly good cassette just to get different gearing, that's not the same reason. Racers swap wheels with different cassettes back and forth regularly. Some people have a different wheel with its own cassette for the stationary trainer. Others will change cassettes for the different terrain they are about to ride in. Never heard any of them claim it wore the chain more quickly.
It's like riding a bicycle
urbanknight is offline
Likes For urbanknight:
Old 05-07-21, 11:19 AM
oldbobcat
oldbobcat's Avatar
Quoted: 512 Post(s)
Liked 444 Times in 334 Posts
Generally, my friends and I get a cassette to last through two chains.
oldbobcat is offline
Old 05-07-21, 11:31 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Some people keep a chain and a cassette together as a set.
dsbrantjr is offline
Old 05-07-21, 11:37 AM
urbanknight
Over the hill
Quoted: 995 Post(s)
I've heard of that, but is there documentation of that doing anything good? Maybe it's because I grew up racing in a time when you had to push a little (easily lost) pin just right in order to change chains, but it seems like a hassle to do that unless there were some serious wear problems if you didn't.
Old 05-07-21, 11:39 AM
dsbrantjr
dsbrantjr's Avatar
It is trivial to do this with a quick link.
Likes For dsbrantjr:
Old 05-07-21, 11:41 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
You answered the opposite of the OP's question. He has a new cassette and wants to know if he should replace the old chain. You recommended replacing an old cassette if he fitted a new chain.
Anyway, I agree that a new chain with the new cassette is a good idea. Start fresh as the cost isn't that much.
HillRider is offline
Old 05-07-21, 12:36 PM
deacon mark
Quoted: 399 Post(s)
My bad and your advice fine but personally if it was me and the chain did not skip I would not replace it. Frankly I use shimano cassettes and they have gone way up in price and are harder to find now. I would like to have an 11-32 but they are expensive compared to pre covid.
Old 05-08-21, 07:21 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4729 Post(s)
Liked 1,530 Times in 1,001 Posts
Chains are consumables, so feel free to also put a new chain on, but keep the not-old old chain perhaps for the next time you need a 'new' chain.
Sy Reene is offline
Old 05-08-21, 10:11 AM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4334 Post(s)
Liked 2,977 Times in 1,614 Posts
A new cassette will not damage a used chain.
Shifting might not be quite as good as putting on a new chain though... that's kind of always true.
DiabloScott is offline
