Disc Brake Caliper Bolts - What's this white stuff?
Bikes: 2013 Giant Roam XR1
Quoted: 12 Post(s)
I mounted my bike onto a trainer for the Winter, but I had to remove the rear disc brake caliper in order to make it fit.
Now I am putting it back together, but I noticed the bolts have some white stuff on the threads.
Image:
Another image: SRAM Level TL Caliper Hardware Kit, P/N 11.5018.021.006
Doing a search, I found various guesses, but no clear answer: Lithium grease? Threadlocker? Anti-seize?
What should I do here? Do I clean off this stuff and re-apply blue thead locker? Lithium grease?
Image:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Thread lock. If the bolts are not the same length one will have blue and the other white. Generally the one you have highlighted will have blue as they're both the same.
Likes For cxwrench:
Quoted: 114 Post(s)
Liked 119 Times
It could be threadlock compound. I’ve had some mounting bolts with a dab of lock compound on the threads. The compound is usually blue, since blue tends to indicate a grade. (Blue = removable, Red = permanent). However, I’m not sure if all brands use the same color coding.
Quoted: 12 Post(s)
Do I need to clean it off and then put on new thread locker? (I have the blue stuff.)
Bikes: lots
Liked 2,932 Times
Quoted: 12 Post(s)
Thanks.
Further research has made me think this is really a thread sealant product, rather than a threadlocker.
In this case, you're probably right in saying it should just be re-torqued to spec.
For future reference, and google indexing, I also thought the white coating could be:
ND Microspheres Acrylic ThreadLock - A kind of thread-locker that can be pre-applied in a dry form. The active ingredients are encapsulated in tiny 'micro-spheres,' which get released which the screw is tightened. But it doesn't come in white.
Vibra-Tite VC3 - Another thread-locker that can be pre-coated at the factory. It's red or clear, but they can make it custom colours.
Really Old Senior Member
Thread "treatment" shouldn't be white & powdery.
IF this is, it's corrosion from a steel bolt into an aluminum caliper.
Likes For Bill Kapaun:
Bikes: lots
Liked 2,932 Times
