Predictions about upcoming new bike tech
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I’m not looking to start a debate about the pros and cons of specific novel features or of bike evolution generally. I’m just imagining what a state of the art bicycle might look like ten years from now, whether we feel good, bad, or indifferent about it.
Here’s what I think is coming (along with my prediction on each feature’s likelihood):
- (Very likely) Anti-lock brakes. Should be easy enough with everything going to hydraulic discs. You just need to add some wheel speed sensors, a computer, a little valve and motor on each caliper, and a power source. This might not be a totally pointless feature. Many will argue it’s a solution to a problem that doesn’t exist--perhaps that’s true. Regardless, I will be surprised if it does not appear in the next several years.
- (Probable) Tire pressure monitoring system. Also quite simple; would follow from technology used on cars for many years. They just need to develop smaller and lighter pressure sensor/transmitter units (probably located on the valve stem), and some software for the cycling computers/smart phones. You’ll never have to wonder how many PSI each tire has, or worry that you might not know when a tire suddenly begins to deflate.
- (Absolutely certain) Smaller, lighter, and more efficient motors for e-bikes. Plus smaller, lighter, and longer lasting batteries as well. Perhaps there will be solar charging on the bike (even something like photovoltaic paint, so the entire frame is effectively a solar panel?) And regenerative braking, so instead of working hard to build up kinetic energy and then throwing it away as friction, you could recover some of that energy to put back into the battery when slowing or stopping.
- (Possibly?) Rear-view camera and cockpit display (probably integrated with the cycling computer, which is already becoming more of a multi-functional display). Garmin Varia radar already gives an audible and visual indication, but it only shows that there is a vehicle (or two or more vehicles) approaching, with a relative indication of their distance and speed. A camera will let the rider remain facing forward and see a lot more detail. Is it a dump truck that’s weaving all over the road and flinging dirt and rocks everywhere? Just a Mini Cooper two lanes to the left? Technology to do this already exists and would just have to be refined/adapted for bikes.
- (Hopefully) Much better bike locks. Better = lighter and smaller but also tougher to defeat, while not becoming outrageously expensive. It seems like lock technology has not progressed very much in the past several decades. There have been little, incremental improvements, but a determined thief can still defeat any lock without much effort. I’d like to see high tech materials change this situation, so that the limiting factor will become “how strong is the structure you’re locking your bike to?”
What do you folks think? What predictions would you add to the list?
Quoted: 1460 Post(s)
Liked 1,480 Times
Tire pressure monitoring already exists and is integrated into head units.https://www.sram.com/en/quarq/series/tyrewiz
It's expensive, so hopefully it will come down in price as the tech gets developed more. What I really want is the ability to remotely set my tire pressure. Like, punch in 35psi and the tire valve automatically adds or releases air until it hits that number. This would be an absolute game changer for off-road riding.
ABS? Maybe. Bikes don't have onboard computers to control an ABS system like cars do, so there's some development needed on that front, but with electronic drivetrains becoming more common maybe it's possible to start expanding this to other components and have a central computer that controls it all.
My predictions:
My predictions:
- Internal hub gearing that is electronically controlled and/or seamless CVT style to maintain specific power output for a given cadence (like ERG mode on a smart trainer, but for riding outside).
- Integrated lighting becoming standard on all types of bikes, even race bikes - daytime running lights are the norm in 10 years
- Integrated on-bike storage for tools/flat kits that don't require strapping bags onto seats or frames
Likes For msu2001la:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Likes For Rolla:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
That's anther good prediction. I can see it likely coming about.
Quoted: 20810 Post(s)
Liked 9,456 Times
There was ABS on rim brakes a while back, and it seemed to be pretty effective. It didn't take hold for whatever reason - not a pretty solution, not a problem that needed solving, or lack of marketing, etc.
Maybe Shimano gets to that point with their recently-patented boost-by-wire, but I like hydro as it is for the immediacy, tactile feedback and stopping power vs lever force, etc. So yeah... meh.
Quoted: 873 Post(s)
Liked 726 Times
Quoted: 645 Post(s)
Liked 797 Times
”Litespud! Wake up! You were dreaming again….”
Likes For Litespud:
Liked 1,480 Times
https://cyclingtips.com/2021/09/want...s-can-do-that/
Trek and Specialized already do that on some frames. More commonly found on MTBs. For road cycling one doesn't need to carry all that much more than what fits in jersey pockets, while a small saddle bag is not a big deal to anyone who isn't so vain as to avoid them for purely aesthetic reasons.
Does calling me vain for wanting this make you feel better?
Likes For coffeesnob:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
All of those things are going to require more hardware and larger batteries to run them as well as some sort of control module.
Will it pass the weight weenie test?
Likes For dedhed:
Quoted: 576 Post(s)
Liked 1,001 Times
Flying bicycles.
Likes For DorkDisk:
Quoted: 3949 Post(s)
Liked 7,295 Times
SRAM will introduce their new 1-50 cassette, for use with their 3-tooth chain ring.
Likes For tomato coupe:
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I think a lot of what is described above is likely to develop as the eBike becomes more and more a standard operator in modes of transport. I can see a Cargo ebike of the future having a heads up display, 360 proximity alarms, ABS, CVT, 100km range etc etc. And it’ll cost almost as much as a small car. But for a lot of families, it’ll replace a 2nd car, or even a first in city centres.
Quoted: 4227 Post(s)
Liked 2,488 Times
Everything that's cycling related including bikes, all parts and components and hardware such as bolts and screws will be made from carbon,, even your bibs and your padded shorts are going to be made from carbon.
OM boy
Bikes: a bunch
Quoted: 514 Post(s)
Liked 642 Times
- (Probable) Tire pressure monitoring system. ...
- (Hopefully)...while not becoming outrageously expensive.
https://www.bikeradar.com/reviews/ma...onitor-review/
yeah, visual area surround monitoring is prolly gonna happen... I'm gonna bet on a glasses Heads-up display from some bluetooth like combo unit - good reason to have those super-kool shades - and a great way to take sunglasses into the i-phone-13+ price range... LOL!
come on... 'Outrageously expensive' is the key operative for cycling... lock-step together
My predictions - Crapon wheels in Walmart... and they'll be exact dupes of stuff we're now paying $1+ - 2+K + for... (might already be there...)
ABS should absolutely happen !!! and be very beneficial for everyone, especially razors... but will be ludicrously expensive for the 1st few seasons.
a prediction - not sure about 10 years... but given some time frame - active suspension for road/gravel/mtb/even 'work'/transport bike, which is NOT some heavy coil spring-oil based Ohlins boinger....
A lot will depend on The Imperious Overlord - UCI - for competition level stuff... and the filter-down to us in the great un-washed...
Save Us !!! Obree Wan !
Yuri - (what fun!)
EDIT : oops, just saw post #2... wondering how much it all weighs - not weight-weenie - but out-of-balance weight does sometimes go 'lump-a-bump' when rolling...
an aside... Graeme is 'genius', everything he's ever worked out/done has come to pass, in some form... 'superman' to 'supertuck' and again outlawed...
and was the highest of class rider !
persistence will win out - as it always seems to; 'evolution' is inevitable - unless we do ourselves in or are helped by the SMOD....
Likes For surveyor6:
Liked 2,967 Times
at some point there may be a wheel propelled by an engine to alleviate the rider from exhaustion. Higher tech might even make it AWD so it's even quicker off the line & stable in the twisties.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
All that stuff already exists maybe not to the level you wish but Bosch/Magura have done ABS, Quarq/Sram have done tire pressure meters and now a electronic suspension thing (different from Fox LiveWire). The Specialized SL line up are pretty light and small but you can also get some of those cheat motors that slide inside the frame and work with the B.B. Solar may not be quite there yet and regen braking has been tried but then you need a heavy e-bike like car weight and you negate the bike at that point. Also plenty of excellent ABUS locks that are light and harder to get through. I have seen some rear view stuff out there but not sure about full connectivity for live usage or quality for regular usage but have seen that crap.
Palmer
Quoted: 1663 Post(s)
Liked 1,817 Times
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,636 Times
Grupetto Bob
Liked 5,636 Times
Grupetto Bob
Liked 5,636 Times
Self sealing tubeless tires which do not require sealant.
Nano-tech self lubricating chains.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
They will continue to become more complicated. I will be continue to become more dejected.
The simplicity is in part what makes then so appealing. Otherwise I would just own a motorcycle or dirtbike.
Likes For mstateglfr:
Quoted: 2432 Post(s)
Liked 638 Times
Higher end framesets will be set up for electronic only, with no provisions for derrailluer cable stops or routing. Double chainrings will die. We'll be up to 15-16 cog cassettes that your current wheelset will not fit so you'll have to buy some new ones. Rear spacing will be wider so your current wheelset won't fit that, either.
Everyone who dares to complain about those things will be looked down on and be called retrogrouches and boomers by the newer riders who are 10 years old right now.
Likes For Lazyass:
Liked 638 Times
After even more time I also think it's possible that lightweight, reliable, race worthy internal gear hubs with many gears will be developed that will be shifted electronically to replace derailleurs.
