Flat bar gravel bike build…. With a twist
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times
Hi all,
I ‘ve almost completed a mini-project… Although I own a couple of folding bikes and a carbon gravel bike, i wanted something to play around and be able to fit child seat etc. …
so I built a flat bar gravel bike but it is based on a mini velo frameset (2008 dahon smooth hound frame and 2010 smooth hound fork).
I run a 1x9 groupset with:
-45t chainring mated to 11-36T cassette. The gearing (gearinch) is similar to the one on my 11s gravel bike but the 1st and 11th gear is missing; not the end of the world 😋
- The derailleur is Sora currently operated by a alivio shifter. I also have a set of sora dropbar shifter if I wanted to fit flared dropbar (and travel agent for v brakes).
The stem is the 100mm stem I removed from my gravel bike and the bar was 800mm cut down to 600mm. If I find it to twitchy, i will fit a 80mm stem as I think the bar is too far forwards from the wheel hub.
The wheelset is Kinetix comp with 47-406 Kenda… I can also fit some 35-406 slick.
Yes,it has a manual KS dropper post and bracket to pull a tag along kid bike well it’s a Trailgator connected to a frog bike.
the saddle is a fabric scoop (demo part because cheap).
After a test run, it does ride like the other folding bike but it is much more rigid and great to jump curbs.
With the seat down, it is a little a bmx… once the chain-guide is fitted , I’ll be off to a pump track with the kids 😜
Quoted: 264 Post(s)
Liked 238 Times
Quoted: 264 Post(s)
Liked 238 Times
I rode it most of the weekend - on and off.
it worked well with the child seat on a gravel ride, was better towing another bike…
Likes For Fentuz:
Quoted: 264 Post(s)
Liked 238 Times
i went on a proper pump track and it was good fun and tiring!!!
Likes For Fentuz:
Sunshine
Quoted: 10955 Post(s)
Liked 7,483 Times
what is the seat tube angle and chainstay length? The ST angle looks really steep and the chainstay length really long. Cant tell if thats accurate or just appearance based on the fact that its a mini.
Quoted: 264 Post(s)
Liked 238 Times
head tube is 73deg (I think a 2deg offset headset would make is better)
The wheelbase is about 10mm smaller than the gravel but with 406 wheels, it looks odd.
Quoted: 264 Post(s)
Liked 238 Times
So I went back to a pump track and had fun going around; all this pumping gives a good workout to the upper body… event managed to get some air (small jumps) and while I love going flat out on a XC downhill, I clearly haven t got the same bottle 30yrs later… but i think it would be a bit easier to jump with shorter chainstays… can t have it all 😅
Quoted: 264 Post(s)
Liked 238 Times
After a 2 week x-mas "break" , I modified a few things:
# the litepro 170 crankset was replaced for a bmx jet 160 (my gravel is in sram force 165) because I hit the pedals on the bumps. 155 would be better because it would offer more clearance (similar to the gravel bike clearance), but I think the range of motion would be too small.
# As the derailleur has a small cage and no clutch, the chain kept popping off so I added a chain tensioner, a tube attached to the chainstay which holds the chain between the pedal and the pulleys. I'm not a fan but it seems to be the only solution in 20 ". I spoke with microshift as their Advent 9s derailleur has a clutch but the cage is too long and not recommended for 20"
# 44T chainring instead of 48T which would be equivalent to going from 11-36 to 12-39. I will run the 44 when the bike is fitted with gravel tyres and the 48 when it is fitted with slicks (kojak)
# Since it's very muddy, I modified the 47mm 20 "sks. It's not cosmetically pretty but it protects us (kids and me, not the royal one ) well ...
# Instead of using the rear child seat, I moved the small one to a shot gun and he loves it... It much easier and definitely more fun
To give it better off road characteristic and make it less twitchy, I'm thinking about slacking up the headset angle: this kit can be ordered for different length.
https://www.superstarcomponents.com/...le-headset.htm
if I was to fit a 2deg offset using a 135mm kit, in my case, the offset would be 1deg as the headset tube is about 250mm. This would shift the angle from 73 to 72 deg which translates into ~5mm of added rack.
This would give a similar geometry to my gravel bike one.
In the end, it's a nice, fast mini bike that I take anytime I go outside. And best of all, I can easily make "superman" (people laugh a lot)
Quoted: 722 Post(s)
Liked 353 Times
Hi all,
is it a gravel worthy machine?
Quoted: 264 Post(s)
Liked 238 Times
it does for me. You can make it as performant as a aluminum bike.
Mine is top heavy because I have various things to tow and carry kids around but, i could save 1-1.5kg with a std carbon 27.2 seatpost.
i could fit the same ritchey dropbar and run either 1x10 or 2x9.
although I run 20”, the range can be offset thanks to bigger chain ring to match std 700c bike range.
The limiting factor is the brakes, no hydraulic option in my case.
and the 20” may be a little more sensitive to bumps.
Quoted: 264 Post(s)
Liked 238 Times
Quoted: 264 Post(s)
Liked 238 Times
So, I played a little with this bike and, I found that I needed a better rear brake so I fitted a dual pivot caliper dia comp BMX and it does the job... I ruined several old tyres doing skid challenges with the kids: "who is going to leave the longest tyre mark while skidding on a carpark or in the garvels".
I broke a rear spoke so I fitted a stronger wheel and I tried a 11-40 cassette and I am pleased to report that it works well with a Sora short cage derailleur... the cassette looks rather big on a 406 wheel.
