I installed 24" tube on 26" wheel. Is it dangerous?
I needed 26" tube and found 24" tube at home and installed it. Now what? I already bought right tube, should I replace it or it is OK to ride? thanks.
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 861 Post(s)
Liked 354 Times
Opinions are going to vary, but will throw out as a data point that the limited availability of tubes for giant 36 inch rims (and the fact that the early butyl tubes that were available weighted a ton) means that a fair number of people in both the giant bike and unicycle communities just started running 29er tubes in them, which is quite a bit more stretch than 24 to 26. I installed one once to see if I could, but haven't ridden it since some lighter weight tubes made for that size were economically available for a bit a couple of years ago.
Likes For UniChris:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,322 Times
It is 8% stretched. You will be fine.
Likes For Cyclist0108:
MotuekaCascadeChinook
Bikes: '20 Tarmac Disc Comp '78 Raleigh Competition GS
Quoted: 4184 Post(s)
Liked 2,708 Times
I'd only expect that the 24" tube will wear out faster and flat quicker if punctured.
If that is unsafe to you then change it. Otherwise just wait till it gives you troubles.
Likes For Iride01:
Mad bike riding scientist
Quoted: 4804 Post(s)
Liked 2,359 Times
I don’t necessarily see a downside to use a smaller tube other than having to stretch the tube on installation.
Stuart Black
Stuart Black
Liked 2,708 Times
Say What?! Tubes don’t “wear out”. Tubes don’t move inside the tire so there is no mechanism for wearing one out. And air will leak from the tube at the same rate as any other tube if punctured.
And since many people don't do so well with keeping their tires inflated, then a stretched tube is going to be worse in that situation than a proper size tube.
You know how many people riding Schrader valves have the stems at an angle from riding under inflated tires. I'm certain every one of those valves where straight when the tube and tire installed. So what moved? The tube or the tire and rim?
Liked 2,359 Times
On the other hand, if a tube is the wrong inner diameter, I could see it as more likely to keep the tire from moving because the tube sits further down in the channel of the rim. This would press on the bead tighter than a larger inner diameter tube and keep the tire in place.
Stuart Black
Stuart Black
Quoted: 669 Post(s)
Liked 452 Times
I built my first 29er from a frame and there weren't tubes at my LBS yet, so used 26er's for at least a year until they got flats or whatever (might have been much longer). No problem.
Assuming that the setup wasn't out of alignment to begin with, I would guess that it's typically the tube and tire moving together. It hard to visualize why a tube would experience axial slippage by itself relative to the surrounding rim and tire, but an underinflated tire slipping against a rim would be understandable, and would tug on the tube.
Liked 2,708 Times
I guess your issue is my choice of using "wear out". Yes, in your definition of wear out, they don't wear out per se. I guess maybe fail would have been a better choice.
So do you have an issue with this re-write?
Maybe I'm completely wrong, it just seems that the more you stretch a tube the thinner it is and the more stress it is under. So it will have a shorter life. And to me a shorter life is wear, whether any material is worn from it or the material changes properties or not.
I'd only expect that the 24" tube will wear out faster fail sooner and flat quicker if punctured.
Likes For Iride01:
Liked 2,708 Times
Quoted: 1068 Post(s)
Liked 278 Times
Once in place, entirely uneventful.
OTOH I’ve had other tires that have been more temperamental, and where ALSO fighting an escape-prone tube quickly turns into a real PITA.
So that’s really what I use as a judgement base. Can I fit the smaller tube w/o cursing, then I’m quite happy to do so, and to leave it in for its operational life.
If it’s a wrestling match making me wish for a 3rd hand, then it goes back out at the next appropriate opportunity.
Likes For dabac:
Liked 2,359 Times
On my trip, I actually attempted to address this with a 27.5” tire. I didn’t use them because they were too wide to fit in my road tires.
Stuart Black
Stuart Black
Zircon Encrusted Tweezers
In a pinch I used a 559 tube in a 622 wheel and intended to swap it out later but forgot. I rode about 6 months with it like that and there were no problems. I only realized I had forgotten about it when I went to put on a different tire.
