How to wash my bike with wash gun?
Dogma f10,CP super red 12s,CP ultra bora 50.I don't want water into bearings with water gun.what kind of water gun should I buy?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1349 Post(s)
Liked 1,243 Times
N o n e
Friend washed his Bike at the Car Wash.
Destroyed All the Bearings
Fred "The Real Fred"
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Wrong answer. The correct answer is pretty whatever you can afford. It's not going to wreck your bike by itself, you have to make all the mistakes. I've washed hundreds and hundreds of bikes w/ pressure washer and not killed a single one. This one is great, hopefully it's available somewhere: Muc Off bike washer
Likes For cxwrench:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
One of these. They come in colors to help match the bike
Quoted: 2952 Post(s)
Liked 3,106 Times
Just don’t aim it at parts with bearings.
Quoted: 6178 Post(s)
Liked 4,795 Times
Why don't you just wipe it off with a damp towel? Or use those premoistened towelettes that come in a cannister? If it's not caked with mud, I can't see where you need a hose or pressure washer of any sort.
Quoted: 2479 Post(s)
Liked 2,948 Times
Garden hose at low pressure plus soft long-bristle and short-bristle brushes. Takes no longer than a pressure washer would. Why risk washing out lubricant?
(My neighbor uses a gasoline-powered leaf blower for the postage-stamp-sized lawn in front of his Baltimore row house. What made me think of that?)
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
+1 damp rag.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 1815 Post(s)
Liked 1,693 Times
Don't do that. No sort of high pressure washer should ever be used on a high end road bike that has not done at least 100 km in torrential rain. Even then, the bike should be completely disassembled and overhauled before it goes back out on the road. Pressure washers are not needed anywhere near a road bike
Likes For alcjphil:
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
climber has-been
Quoted: 3415 Post(s)
Liked 3,543 Times
The 'don't (pressure) wash your bike' myth is just that...a myth. As I posted before I've washed a metric **** ton of bikes, many of them w/ a pressure washer. I think that most of the people claiming all the crazy stuff about pressure washers ruining bikes have never even used one.
It’s a significantly bad idea.
I’ve had to replace rusted headsets on far too many rental bikes, thanks to a clueless mechanic armed with a garden hose.
Put some soapy water in a bucket, apply with a couple of brushes, lightly rinse off with a fine spray from a garden hose, wipe down the frame with an absorbent cloth.
Or if only the frame needs a quick clean, spray some dilute ammonia on the frame, wipe with a soft cloth. I do that almost daily to get off the sweat drops and spilled drink mix.
That is all.
Bikes: lots
Liked 2,932 Times
A pressure washer is really good at injecting water into the moving parts of a bicycle. Even a garden hose with a nozzle will do the same.
Some soapy water in a bucket, a couple of brushes, then lightly rinse off with a fine spray from a garden hose.
That is all.
That is all.
climber has-been
Liked 3,543 Times
I didn’t write that it can’t be done. I wrote that it’s a significantly bad idea, because it is. And I explained the failure mechanism. And I shared personal experiences of such failures.
The way bearings fail has been studied for at least 100 years. The top causes of bearing failure are loss of lubricant and water contamination. Pressure washing can produce both. Why take the chance?
Likes For terrymorse:
Bikes: lots
Liked 2,932 Times
If you’re telling the truth, and you’ve power washed many bikes without ruining moving parts, I say you’ve been lucky.
Likes For cxwrench:
climber has-been
Liked 3,543 Times
When you've washed bikes as a pro team mechanic for the better part of 15 years 'luck' isn't part of the equation. Knowing what you're doing is a big part of it. Of course if you do it incorrectly you can blow right past seals. If you do it the right way you won't ruin a thing. Pretty much every pro team mechanic I've seen and/or worked with uses pressurized water to wash bikes. It's not hard if you are smart about it.
Pro team bicycle mechanics are equally untrained in engineering and tribology, and they are just as susceptible to picking up stupid tricks, passed down from older mechanics who swear they’ve been “doing it for years with no problems”. I wouldn’t trust any mechanic with a high pressure wand, even the “pro team” ones who claim they are “smart” about how they wield it.
Spraying high pressure water anywhere near bearings is risky. Such practice isn’t allowed in any industry that I can think of. Except bicycles, of course, where myth and lore survive.
Ride, Rest, Repeat. ROUVY: terrymorse
bike whisperer
Liked 716 Times
I don't think pro team mechanics are a great example to cite if you're talking practices to promote longevity... Replacing stuff regularly is likely to be preferred to spending more time on daily chores. It's certainly expeditious for them to use pressure washers.
Perhaps the clue is in cxwrench 's name? Mud, as opposed to dust, and cross bikes rather than road bikes?
Likes For Kimmo:
Quoted: 479 Post(s)
Liked 277 Times
I have used the Hybrid cxwrench method for 40+ years. I wash my bikes.. a LOT. I don't use a pressure washer, but I do use a pre-pressure reducing valve garden hose that has enough pressure to reach the sun (okay, maybe the moon). I use the pressure on the wheels, tires, frame/fork, under the saddle... I dial it back for the drivetrain and hubs, and don't hit the bearings directly. It's not rocket surgery.
In addition to always having very clean bikes, I also ride some old bikes. Somehow, those two are NOT in conflict with each other.
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
At the family home, we've got a 2300 psi electric pressure washer. Anytime I have my bike(s) there and need a good cleaning, I don't hesitate using the pressure washer. I just make sure to switch the nozzle out to 40° and it does the job. I've been cleaning all my bikes this way for the last 14 years and helps rid of all the crud that builds up especially on the cassette and brake calipers.
Likes For primov8:
Advocatus Diaboli
Liked 1,531 Times
I'm kinda surprised nobody's posted this classic yet.
Quoted: 18398 Post(s)
Liked 15,495 Times
Take it in the shower with you.
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
If my bike is on the roof of my car when I take the car to the carwash it gets sprayed down. None of the bikes that I have been doing this with (for years) have self-destructed. I just don't spray down the bearing surfaces with a high-pressure spray. This isn't exactly rocket science. Use common sense and you'll be fine.
Likes For Andy Somnifac:
Bikes: lots
Liked 2,932 Times
