Minimum Clearance Between Rear Rack and Wheel?
I've got a Trek Verve 2 and I'm trying to decide on which rack will fit best on the back. I tried the Topeak MTX regular (not the 29er) and it seems to have very very little clearance between the rack and the wheel. I mean, it shouldn't be bouncing around any but it seems awfully close. Normally how much space should there be?
Relatedly, I've had a heck of a time figuring out the wheel size. I guess I could have just tried to measure. :/ But that Topeak rack says it fit either 700c (that's what I have on the Verve 2) or up to 27.5". Problem is, I think my 700c is actually 29". I don't know.
I do have disc brakes, so I gather I need the version made specifically to work with disc
Pics would be awesome, if you can post them, just so I can get an idea of what's a good fit and what's not. I don't want the rack to be TOO high.
Thanks for any insights here.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
The only 3 problems I can see with a rack very close to the rear tire:
- mud might stick to the tire and scrape on the rack (causing drag and a scratched rack)
- no room for fenders
- can't get bigger tires
I'd prefer at least half an inch of clearance, more if I might get fenders.
"disc brake versions" of racks were designed to accommodate disc brakes that were located above the seat stay - those racks had the struts pushed outward a bit. I don't think you need that kind of rack on a Trek Verve.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
About a pinky tall if you don't need fenders, about a thumb wide if you do.
Disc racks were a thing because the brake mounting bolts interfered with the legs if you used the usual mounting hole. So the disc rack mounted to a special skewer. Not great. Most bike companies fixed this by moving the mounting hole UP which makes the rack ride pretty high. Not great. The best fitting racks are the ones that are specific to the bike if there is one. Might not be the best kind of rack, but it will fit great!
Genesis 49:16-17
Genesis 49:16-17
Attachment points
I see two types of holes down where the rack would attach. One kind of protrudes a bit, like its a little nub poking out but that has a threaded hole in it. Is that intended to allow use of racks that are not specifically designed to for use with disc bikes? (Can’t post pics yet)
Bikes: 2021 Trek Verve 2 Disk
Quoted: 130 Post(s)
Liked 119 Times
https://www.trekbikes.com/us/en_US/e...olorCode=black.
Quoted: 130 Post(s)
Liked 119 Times
I just realized, having gotten a Topeak rear rack for disc brakes, than the Verve 2 Disc does not actually require the disc version of that rack. The Verve 2's disc calipers are directly above the horizontal chain stay and not above the seat stay. This placement means the calipers will not interfere in any way with the rear rack's vertical tube that connects the rack to the bike frame. I also think the Verve 2's wheels are 29" and so they need the Topeak Explorer 29er to give the optimum clearance between the rear wheel and bottom of the rack (allowing practical installation of fenders later. A bit of trial and error to figure this out, but luckily, Amazon returns are easy.
Quoted: 1819 Post(s)
Liked 1,693 Times
I can confirm. I got a rack that was for a 29inch wheel and it fit's perfectly find on my 700C wheels. I got a disc specific version as well.
