Disc Brakes Letting Some Pros Down
Zen Master
There have been at least a couple of Giro riders that have over-temped their disc brakes and shot right off the road. Maybe if they increase the size of the disc rotor by several factors, the increase in surface area will prevent that...then again...there's always rim brakes. Get the popcorn started.
Pro Blames Disc Brakes for Losing at Giro
Ron - Tucson, AZ
Ron - Tucson, AZ
Quoted: 20791 Post(s)
Liked 9,436 Times
He apparently suffered a broken spoke, which he claimed was caused by his disc brakes becoming overheated.
Likes For WhyFi:
Quoted: 9519 Post(s)
Liked 6,265 Times
When you lose you look for excuses, regardless of the type of competition you are in.
Zen Master
I guess it is human nature to discount the word of someone having road racing as their actual profession, riding more miles than most everyone reading this article, having bikes which are maintained by some of the most skilled mechanics, etc.
He breaks down how crappy of a day it was for him, on many levels, including disc brake issues....but there's no matching forum wisdom.
Ron - Tucson, AZ
Ron - Tucson, AZ
Likes For Miles2go:
Quoted: 6099 Post(s)
Liked 4,730 Times
Obviously you just started watching Tours and Grand Tours. Back in the days of rim brakes only there were also plenty of issues. Like the rim getting too hot from braking and the tire rolling off the rim.
Zen Master
Right, those were the days of tubeless tires right? oh, wait...I think we're talking about tires glued onto the rim. ....wonder what happens when you heat up glue. Yeah.
Ron - Tucson, AZ
Ron - Tucson, AZ
Quoted: 18883 Post(s)
Liked 10,645 Times
Likes For Seattle Forrest:
Liked 9,436 Times
Likes For WhyFi:
Clark W. Griswold
Quoted: 4251 Post(s)
Liked 3,863 Times
Look I get that they ride a lot but a decent portion of them when it comes to bikes really not very knowledgeable, they are like the cycling friend every needs to schlep to the bike shop to question the actual professional who sells and works on a wide variety of bikes daily vs. the one bike that rider rides. Trying to blame disc brakes for spoke failure is absolutely silly. Having too few spokes which is the trend these days and loading them with the brake force at the hub is causing issues and also using smaller rotors and things like that. Now if the mechanics went and said yeah that was the cause I would say OK maybe something to that but just being a rider doesn't mean you need to know about the bikes and how they work beyond just operating them while riding.
Every pro is going to want to have something to say when they didn't win. Sometimes it is positive like "hey he was just a better rider, I need to train harder" and sometimes it is "my brakes overheated broke a spoke and yada yada".
Regardless though whatever braking system they use someone is going to say another braking system it better. That is part of the fun.
Klaatu..Verata..Necktie?
Quoted: 10243 Post(s)
Liked 11,595 Times
Tubular. And these still are the days of tubular tires in the pro peloton, though some are riding tubeless, I hear.
Liked 2,909 Times
The operator needs to know when to respect the equipments limitations.
If the course they faulted on was ridden by the same person, using a bicycle not equipped with disc brakes, exerting the same level of performance [& techniques] , & before the current mishap; would the times & speeds be equal or any better?
In the end, the general non pro rider will buy what they want.
-Oh Hey!
-Oh Hey!
Quoted: 6881 Post(s)
Liked 10,871 Times
Sometimes spokes just break.
Likes For Koyote:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 580 Post(s)
Liked 921 Times
Yes, discs get hot, sometimes very hot, and yes, sometimes hot enough to cause braking issues. No, that heat will not be sufficiently transferred (through the 'spider' on the rotor and through the hub's disc boss and out the hub's flanges) to the spokes such that it would cause the metal of the spokes to weaken... that's absurd.
Disc brakes DO, however, put a load on the spokes in a way that rim brakes do not - rim brakes stop the rim directly, while disc brakes stop the rim by exerting force on the hub which pull on the spokes to stop the rim. Enough to break spokes? Maybe over the medium term after many miles. If that is how that pro's spokes broke then it is an issue of not replacing the wheels or spokes soon enough, or of some other problem with the wheel build or configuration. It's easy to forget that lots of riders in that event (and many other events and grand tours) use disc brakes, yet only one person complained of the disc brakes causing spokes to fail.
Perhaps the rider got to the finish line and the team mechanic was embarrassed that a bike in their stable had a problem, and rather than admit the wheels didn't get the attention they needed before the race, or that the wheels given to the team by a sponsor had a failure, used the excuse that it was the discs' fault,
Likes For ClydeClydeson:
Quoted: 871 Post(s)
Liked 725 Times
waiting for Specialized to slap "for flat and uphill riding only" stickers on the revised Roval wheels, then have their marketing claim the next version with more spokes to be safe for downhills and the fastest yet.
Likes For surak:
Quoted: 234 Post(s)
Liked 444 Times
Maybe he is correct and had a problem with his disk brakes.
Perhaps he overheated the rotors by too much, continuous braking.
Perhaps the brake pads were fairly worn or a bit contaminated which resulted in overheating and loss of braking power. We've seen videos showing the pro mechanics washing, etc. team bikes...they are not the most careful because of how many they have to prep, only so many mechanics to do the work, etc.
Perhaps he was just too hard on the braking and plain old overheated them...could have happened with rim brakes...they too would have failed when needed most.
You would have to remove the parts and look at them closely to see if there is a mechanical reason for failure.
I'd want to talk to the rider to hear how, when, etc. they failed.
It is interesting.
Oh it is a lot of fun to be in a race and the rider in front of you rolls his sewup...you know the next few seconds are going to be hair raising fun for those behind.
It is interesting.
Zen Master
I didn't confuse tubulars and tubeless (raced a decade on sew ups), so read it again knowing that I meant to say tubeless, then oh wait!...no, we're talking about glue, tubulars, sew ups.
Ron - Tucson, AZ
Ron - Tucson, AZ
Zen Master
Of course not. The discussion wouldn't be as interesting if I didn't paint that picture. Now we can see that pro cyclists don't know what they are doing, bike mechanics might not be maintaining the brakes properly, etc., etc.
Ron - Tucson, AZ
Ron - Tucson, AZ
Liked 11,595 Times
The problem is, it doesn't make sense.
Likes For genejockey:
Liked 4,730 Times
Races of any sort for the last couple centuries have almost always involved manufacturers showcasing and doing practical testing of their latest technology. If we are only to race on proven and trouble free technology, then we'd probably be riding the stuff that was cutting edge back in 1903.
Likes For Iride01:
Quoted: 389 Post(s)
Liked 255 Times
I'm going to make a wild assumption: There are very few, if any, pros that ride their brakes down a hill in a race. I really doubt if there were any over heating problems.
Likes For Jack Tone:
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
He also said he had a sore back.
By the way his teammate actually won the stage...Wonder what kind of brakes was he using?
Quoted: 4272 Post(s)
Liked 4,707 Times
Likes For PeteHski:
Liked 9,436 Times
You came across a statement from a pro rider that was so dumb that it didn't merit discussion. Since you wanted to generate a discussion, you decided to adopt the position of an intellectually challenged devil's advocate.
Is that about right?
Likes For WhyFi:
