For the love of English 3 speeds...
Yes.
Its not that hard to change the threaded cog though. You will need a sturdy bit of metal that can be placed in a vice. The handle of a spanner will do nicely. You place the driver on the handle of the spanner so that it is kept still. You'll need a 'chain whip' which is a handle with a bit of chain attached. You can get such a tool from Park Tools, used for removing cogs from track bike hubs. The tricky bit is that the chain will have to be changed out with a length that fits your cog. I found that was not difficult.
https://www.parktool.com/product/spr...n-whip-sr-12-2
I had to play with some small washers when I mounted the wider chain for the cog to the tool.
Surly has a handsome 22T cog. Its shiny but fits inside the chaincase so it can't be seen.
Easy with the right tools.
I generally take a propane torch and warm the sprocket up just enough that its too warm to hold onto comfortably, then set the driver on the bar or old wrench and remove it with the chain whip. You don't want to turn it colors, just heat it up enough that there's a temperature difference between the driver and the sprocket. I've had a few that wouldn't even think of moving come right off by simply applying a bit of heat.
Heat only the sprocket, not the driver or the bar your going to use to hold it with. The sprocket will expand just a bit making it easier to remove.
Likes For dirtman:
www.theheadbadge.com
Quoted: 2401 Post(s)
Liked 4,350 Times
British bike thread needs some streamlined LNER content.
Now back to the regularly scheduled programming with a Class 290, demonstrating two of the best forms of transportation in one picture.
-Kurt
-Kurt
Likes For cudak888:
A little bit of heat works wonders too for the stubborn one's. (I don't mean take a torch to it, just warm it up, often a hair drier is all it takes).
TigerTom
TigerTom
Old fart
Quoted: 3571 Post(s)
Liked 3,368 Times
Likes For JohnDThompson:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
Likes For thumpism:
Liked 4,350 Times
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 356 Post(s)
Liked 259 Times
You can use any driver from any A hub- AW or AG. They have been interchangeable since the A hubs were introduced.
Likes For Salubrious:
Quoted: 478 Post(s)
Liked 634 Times
i thought I did answer (though not with conviction as I haven’t tried it myself): it appears all the Ax series hubs shared drivers and since it’s a quick change you can try one from any AW hub you have - it should go together quite easily.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 439 Times
Liked 2,445 Times
Likes For thumpism:
Quoted: 1299 Post(s)
Liked 103 Times
Likes For BigChief:
Liked 439 Times
Glad to see you back.
I was getting worried as you hadn't posted for a while.
My grandparents house backed onto the train tracks and we would spend hours counting cars....
Finished this brown Raleigh Sports and sold it to a neighbor just in time for a Christmas present for her husband. He'll use it as a town commuter. Had to remind him to ease up on the pedal to shift. Had to switch out the original leather Brooks--it looked like a desert cow skull when I got the bike.
Likes For jkrug:
Liked 2,445 Times
Likes For thumpism:
Phyllo-buster
Quoted: 2288 Post(s)
Liked 2,033 Times
Likes For clubman:
Quoted: 339 Post(s)
Liked 623 Times
I"m working on a Raleigh Space Rider at the moment. Almost finished except the 3 speed S/A hub won't shift. The chain that goes into the axle doesn't move at all. Short of disassembling the hub is there any way recommended to free up the shifting chain.
I thought I might flood the hub with penetrating oil then flush with alcohol or acetone and refill with oil.
Will this work or make matters worse?
I'm no steam expert but I was told while visiting a steam locomotive shop that the area around the smoke box can be in excess of 650°F, and the fire box can be over 2,700K° under way.
That bike is hanging on the outside of what is likely the actual smoke box for that engine, I would think that even though air flow when moving forward would cool the bike, heat conduction would certainly cook that bike thoroughly regardless of surface cooling. .
Soak it with Kroil or PB Blaster and see what happens but chances are if its rusted bad, your going to be taking that indicator out in pieces if its rusted into the axle.
If the indicator unscrews and the hub is stuck inside, you might as well just take it apart now.
They're easy to work on, once you do one, you'll likely take everyone you get apart just to be sure of what you have.
Likes For vintagebicycle:
Liked 103 Times
If something is rusted bad enough to be stuck like that I can't imagine anything short of opening it up will do it any good.
Inflate Hard
Inflate Hard
Likes For BigChief:
Liked 103 Times
Likes For BigChief:
Liked 4,350 Times
Is anyone else thinking about how hot that bike is getting hanging on the front of the boiler like that? I can just picture all the grease dripping out of the bb and hubs as it hangs there.
Mind, given the expansion of air volume at such heat, those tubes would have probably blown the tires off the bead. There might be more at play here than we know.
-Kurt
Liked 4,350 Times
-Kurt
Phyllo-buster
Liked 2,033 Times
I would guess hi-tensile but Alex was a superb engineer so I'll bet it's strong. In fact, I've never seen a bent fork or frame on a Moulton, the racks act like bumpers.
Liked 4,350 Times
Also, is it just me, or is something off with the rear dropout? Looks as if the bottom of it is not there or considerably splayed.
-Kurt
Likes For cudak888:
Phyllo-buster
Liked 2,033 Times
Likes For clubman:
