There's competition in the radar market
Quoted: 18882 Post(s)
Liked 10,643 Times
https://cyclingtips.com/2022/07/bryt...nd-tail-light/
Bryton had a large stand at Eurobike showing off all things from its extensive list of head units to a new indoor trainer (more on that later). But perhaps the most interesting thing on the stand was the new Gardia R300 rearview radar and tail light device.
Quoted: 20791 Post(s)
Liked 9,430 Times
DCR is saying that it'll be less than Garmin's 510/515 and that the battery life blows away the 510/515 and should outlast virtually any head unit on the market. Interesting.
https://www.dcrainmaker.com/2022/07/...dar-units.html
Likes For WhyFi:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9039 Post(s)
Liked 3,517 Times
Interesting yes, but it's easy to blow away the competition when you're not on the market yet. Does it have the same range and sensitivity? Other quality?
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 2787 Post(s)
Liked 1,588 Times
I’ve criticized the Varia 500-series styling and mount placement before, so I’m happy to see Bryton had the same thoughts and centered their mount and gave the unit a more modern look.
That said, it’s perhaps kind of surprising they stumbled upon virtually identical dimensions, unless there’s some kind of sharing of the basic hardware. The round lens, single LED, and top mounted light suggest this, too.
Anyway, I hope Bryton’s unit at least shuts up the beeping when the bike is stopped. That’d be a big quality of life improvement for me, as I find the Varia’s incessant beeping really annoying.
Liked 10,643 Times
It's wide enough that you can use it as a snow plow, too.
Likes For Seattle Forrest:
Quoted: 6570 Post(s)
Liked 10,315 Times
Liked 9,430 Times
So, for another bike, I bought the hard mount -- and it must've been designed by a C- student. Just awful. It's wide enough that my left thigh occasionally brushes against it while pedaling, and it puts the unit about 30 degrees off of perpendicularity relative to the pavement on a bike with a pretty standard seat tube angle. If they took returns, I would send it back.
Liked 10,315 Times
Honestly, I can’t understand how they built such a poor mount. Cygolite tail lights come with an infinitely better mount – does not rub your thighs, and the angle is adjustable.
Liked 9,430 Times
It’s mounted correctly. 30° might be an exaggeration, but it is noticeably not perpendicular to the road surface.
Advocatus Diaboli
Quoted: 4639 Post(s)
Liked 1,476 Times
https://www.amazon.com/gp/product/B08N154BBY
Likes For Sy Reene:
Quoted: 3573 Post(s)
Liked 6,511 Times
I bought a Garmin 515 recently and found the rubber band mount less-than-satisfying. It's secure, but it's too easy to move the unit off-center just by handling the bike. So, for another bike, I bought the hard mount -- and it must've been designed by a C- student. Just awful. It's wide enough that my left thigh occasionally brushes against it while pedaling, and it puts the unit about 30 degrees off of perpendicularity relative to the pavement on a bike with a pretty standard seat tube angle. If they took returns, I would send it back.
Likes For tomato coupe:
Liked 10,315 Times
I skipped the garmin offering and got one of these. adjustable angle, as well as a bit more clearance from seatpost clamp area.
PS: thanks, all!
Likes For Koyote:
Liked 2,778 Times
-Oh Hey!
-Oh Hey!
Quoted: 4153 Post(s)
Liked 1,271 Times
With a centered mount, are stuck if it doesn't fit (unless you mount it sideways).
Thread Killer
Liked 1,588 Times
It could have been really cool had Bryton come up with their own, novel architecture for the radar unit, rather than merely slightly modifying the Varia template, but I’m sure there were practical limitations to doing so.
Another potential downside is that the Bryton mount appears to be unique, reducing mount options currently available on the aftermarket compared to the ubiquitous Garmin-style mount options.
Liked 1,271 Times
Then, again, Bryton does some things in a non-standard way for no apparent reason:
https://www.bikeforums.net/electroni...es-format.html
Liked 2,778 Times
after some use, I've not had any real "techie" issues. That doesnt mean I dont have complaints.
The audible alert could be better, & by better I mean having selectable sound levels & types as well as just having a vibrate feature (ie: SMS Text *vvrrrb vrrrbb*)
be a bit more capable in detecting straight rearward traffic from a farther distance, maybe 250 more feet or so would satisfy things.
have not ran it out of juice entirely yet, but so far I have had it "active" for at least seven hours with battery life to spare. It might be on par with the computer's battery life duration. That would be nice if it was at least that capable in staying reliable.
Have not verified if it has a passive charging system like the computer, camera, headlight, backup taillight, & phone. If it is, woot! if not, meh, the battery life does make up for it if that turns out to be the case.
One last peeve.... The mount interface. Why can't they just have it also include four threaded bosses to use an aftermarket mounting setup? That goes for pretty much all bicycle accessories...
-Oh Hey!
-Oh Hey!
Likes For Troul:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1663 Post(s)
Liked 1,252 Times
Amazon.com: TUSITA Bike Seat Post Mount Compatible with Garmin Varia RTL510 RTL515 RVR315, Rearview Radar - Round,D Shaped,Aero Seat Post Compatibility : Electronics
This one has a dual loop band which holds the mount very securely against the seat post. It also appears to be designed such that, even if the band breaks at a single point, it would still keep the mount on the seat post. I like it so much that I bought two and would buy another once I finish building my third bike; I don't think it is a good idea to keep taking the band off and on.
Liked 1,252 Times
This review says that the Varia has less false positives and is better at multiple vehicle detection.
Varia RTL515 vs. Magene L508 vs. Gardia R300 (COMPARED) (cyclistshub.com)
Likes For SoSmellyAir:
Liked 10,315 Times
Actually, since the plastic hard mount is sooo awful, I have left the standard rubber band mount on my gravel bike -- and it has been fine. But I still wish there was a better OEM mount.
Likes For Koyote:
Quoted: 3616 Post(s)
Liked 3,907 Times
I was thinking of buying the hard mount, so it’s good to know this. I use the standard Garmin mount on my road bike, but it easily gets knocked off centre and I don’t like to rely on a single rubber band holding up. So I might have a look at aftermarket alternatives.
Liked 1,252 Times
The one I linked above in post #18 is very good.
ignominious poltroon
Quoted: 2028 Post(s)
Liked 3,053 Times
I use Garmin's seat post mount:
There are copies that cost about half of what I paid for this.
Liked 3,053 Times
Liked 10,315 Times
I will say one thing for that hard mount: it keeps the light in place properly. With the rubber band mount, as someone noted upthread, it's easy to bump it to an off-axis position and not realize it.
