Shifter worries
Old 11-24-22, 03:43 PM
frogman
frogman's Avatar
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 248 Times in 158 Posts
Shifter worries
So here you are 15 miles away from home, on a trail nowhere near any roadways on your gravel bike and your brifters crap out. How do you make field adjustments to lock them up to stay at least in a low gear so you can pedal back home ? That is my fear with the Shimano 10 speed
brake shifters. I had Shimano bar end shifters mounted up on the handlebar with Paul Thunbie mounts earlier and with them I could switch to friction shifting if the indexing crapped out, which was nice, but now I am spoiled with the Shimano brifters.
frogman is offline
Old 11-24-22, 04:07 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1957 Post(s)
Liked 2,932 Times in 1,489 Posts
You're overthinking this massively. Replace the cables/housing once a year like you'd change the oil in your car...it's preventative maintenance. If you're that worried about it carry a spare cable with you and maybe some needle nose pliers. If you think you can get home in one gear put the cable in the derailleur backwards so the head is in the barrel adjuster. Push the derailleur into a gear you can ride and tighten the anchor bolt.
As happens all the time this should've been posted in 'bicycle mechanics' not GD but I wouldn't have seen it as I'm still banned from that section.
cxwrench is offline
Old 11-24-22, 05:41 PM
frogman
frogman's Avatar
Quoted: 327 Post(s)
thanks cxwrench, the cable technique sounds good. I will check it out.
Yeah, I'm sure I'm overthinking it
frogman is offline
Likes For frogman:
Old 11-24-22, 08:06 PM
wolfchild
wolfchild's Avatar
Quoted: 4113 Post(s)
Liked 2,403 Times in 1,247 Posts
My bikes don`t have shifters, I ride singlespeed.
wolfchild is offline
Old 11-24-22, 08:49 PM
Koyote
Quoted: 6570 Post(s)
Liked 10,311 Times in 4,414 Posts
How is that relevant?
O​​​P: ​​cxwrench is spot-on. But if you still get stuck, just ride home or call a friend for a ride. No biggie. It is marginally easier if you ride a 2x, as you can shift the other derailleur.
Koyote is offline
Likes For Koyote:
Old 11-24-22, 09:33 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2630 Post(s)
Liked 3,168 Times in 1,929 Posts
I have 10's of thousands of miles on 6600 brifters without issue of them crapping out. I have on bikes, when a cable broke out on the trail/road, jammed an appropriate size stick off the ground in the RD to hold it in a favorable gear. Another hack is tie off the exposed inner cable to hold it in the gear you desire.
dedhed is offline
Old 11-24-22, 10:46 PM
tempocyclist
tempocyclist's Avatar
Quoted: 291 Post(s)
Liked 630 Times in 308 Posts
If it's a front derailleur cable there's nothing to worry about, as it'll simply drop you into the small chainring and you can ride home in a tiny gear. You'll be able to climb fine and spinning out downhill won't matter really.
If it's the rear derailleur cable, like above has said try jamming something from the roadside into the rear derailleur to "push" it into a good gear, or pull the cable tight so it "holds" in a middle gear then tie it off to the frame ir a mounting bolt or whatever is in reach of the cable. Not pretty, but it'll get you home. Worst case scenario is that you're stuck in the small front / small rear combination. You'll likely still be able to pedal yourself home.
It's not a huge concern though. Times I've had a cable snap in tens of thousands of miles: 2 (both could have been prevented with a little more maintenance)
Helpful... 🙄 🙄 🙄
tempocyclist is offline
Likes For tempocyclist:
Old 11-24-22, 11:51 PM
Canker
Quoted: 316 Post(s)
Liked 196 Times in 124 Posts
the limit screw will get you at least one if not two gears up from the hardest.
Canker is offline
Likes For Canker:
Old 11-25-22, 01:13 AM
veganbikes
Clark W. Griswold
Quoted: 4012 Post(s)
Liked 3,538 Times in 2,364 Posts
Hey sorry my medal maker is closed for the holidays hope it is ok they make it next week?
I love single speeds and fixed gears, I have two of them and have plans for the third but that isn't so much relevant in this thread. We are all pretty understanding that generally yes a single speed or fixed gear is lower trouble and no shift issues however if you have a shifter probably listen to what cxwrench said it is good advice. Keep things well maintained and you are less likely to have an issue and if you get totally screwed out there just Missy Elliot it:
Put your thing down, flip it and reverse it
Also get really top quality cables and housing and that can help as well along with maintenance. If you have severe bends a more flexible set up like say Jagwire Elite Link might be helpful to provide a smoother cable transition and with the really high polished slick stainless cables it makes them glide so smooth.
veganbikes is offline
Old 11-25-22, 10:04 AM
cxwrench
cxwrench's Avatar
Bikes: lots
You just had to post something didn't you?
cxwrench is offline
Likes For cxwrench:
Old 11-25-22, 10:32 AM
Iride01
Iride01's Avatar
Quoted: 5843 Post(s)
Liked 4,466 Times in 3,078 Posts
Carry some thing that you can cut the cable with where it runs bare along the downtube. Then you can tie it off on a bottle cage or some where else convenient in the gear that you want.
Iride01 is offline
Old 11-25-22, 10:59 AM
staehpj1
staehpj1's Avatar
Quoted: 1180 Post(s)
Liked 665 Times in 501 Posts
That will vary depending on the exact setup, but yeah at least one. If yiu are lucky you might get three.
Then why not wedge something between the end of the limit screw and the point it hits to get a bit more if needed?
If you were that worried about it you could make a little cable end with a set screw that could be adjusted to roughly the right gear and fine tuned with the barrel adjuster. Given how unlikely you are to need it and how many other work arounds there are I wouldn't bother.
staehpj1 is offline
Old 11-25-22, 01:21 PM
tomato coupe
Quoted: 3573 Post(s)
Liked 6,511 Times in 2,629 Posts
I saw a variation on that where a rider tied a loop in the cable, and then attached the loop to a bottle cage using a tie wrap. The nice thing was he could ratchet up the tie wrap to put the derailleur in a convenient gear. Of course, you have to carry a tie wrap with you ...
tomato coupe is offline
Old 11-25-22, 01:36 PM
rsbob
Grupetto Bob
rsbob's Avatar
Bikes: Bikey McBike Face
Quoted: 2193 Post(s)
Liked 4,644 Times in 2,453 Posts
Anything to boost a post count, no matter how irrelevant or unproductive (kind of like this one )
Road 🚴🏾‍♂️ & Mountain 🚵🏾‍♂️
”Your lips move but I can’t hear what your saying” DG
rsbob is offline
Likes For rsbob:
Old 11-25-22, 06:09 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 25609 Post(s)
Liked 9,553 Times in 6,645 Posts
Originally Posted by Proverbs 15 : 1
A soft answer turneth away wrath: but grievous words stir up anger.
3alarmer is offline
Old 11-25-22, 07:25 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
Carry a spare thumbshifter and cable with you if you're that worried about it. Even an inexpensive friction only thumbshifter will let you get home.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 11-25-22, 11:19 PM
frogman
frogman's Avatar
Quoted: 327 Post(s)
Carrying a spare thumbshifter sounds like a good option Miele Man.
frogman is offline
Old 11-26-22, 12:26 AM
Camilo
Quoted: 995 Post(s)
Liked 1,017 Times in 658 Posts
You'd deal with it the same as if you have so many flats you run out of spare tubes and patches. And the failure of a shift lever is much, much less likely with simple attention to cables. So if you never worry about having multiple flats exceeding your ability to repair the holes, you should worry even less (less than never) about a shfiter or cable failure. But as others have said, don't ignore the cables for years on end.
Camilo is offline
Likes For Camilo:
Old 11-26-22, 10:31 AM
cxwrench
cxwrench's Avatar
Bikes: lots
You're kidding, right? You're more likely to break a chain, you going to carry a spare one of those too?
cxwrench is offline
Likes For cxwrench:
Old 11-26-22, 11:32 AM
Koyote
We had a poster who devised a rig for carrying an entire spare wheel, complete with tire and cassette...So I wouldn't be surprised if some paranoid bf'er was carrying a shifter around.
Koyote is offline
Likes For Koyote:
Old 11-26-22, 09:50 PM
Milton Keynes
Milton Keynes's Avatar
Quoted: 2280 Post(s)
Liked 1,709 Times in 936 Posts
How often do brifters just "crap out?" Twist shifters on cheap Walmart bikes, yeah, I've seen those crap out and not keep friction or hold their position, but brifters and trigger type shifters are a different matter.
Milton Keynes is offline
Old 11-26-22, 10:42 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 618 Post(s)
Liked 985 Times in 627 Posts
That would be my remedy. If need be, one could swap in a slightly longer screw to ensure you could take the limit to the cog you want. In my case, two cogs over gets me to 16, which would be fine with me.
Otto
ofajen is offline
Old 11-26-22, 10:49 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 5963 Post(s)
Liked 3,797 Times in 2,179 Posts
Like almost never. I’ve got 10s of thousands of miles on these kinds of shifters as well…including thousands of miles far away from home where calling for help isn’t an option. I’ve never had a shifter problem.
Gripshifters aren’t all that delicate either. I see a lot of them at my local co-op. They are simple and robust. I’ve seen broken ones but that’s the result of a crash or someone trying to remove them without knowing how.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 11-26-22, 11:15 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 176 Post(s)
Liked 174 Times in 99 Posts
99.9% of the time it's lack of maintenance (i.e., replacing cables and housing).
Carrying a thumbshifter sounds ludicrous. I'm pretty sure those cheap ones don't split so you have to unwrap the bartape, pull the 'brifter' off of the handlebar, install the thumbshifter, brifter, and re-tape that half of the bar.
Rogerogeroge is offline
Old 11-27-22, 07:18 AM
staehpj1
staehpj1's Avatar
Fairly often with poor maintenance if you count frayed cables at the sharp bend as the cable enters the brifter on some models. But that isn't really a failed brifter i guess. It isn't that obvious if you don't know where to look. It does usually give some warning in poor shifting for a while before failure so unless you just keep ignoring it it isn't too likely to suddenly fail all at once.
I had one get bad enough to be shifting badly on tour, but not close to actually breaking. I stopped in the next town with a bike shop and bought a cable. I could imagine someone not figuring out what was going on and possibly breaking the cable. Carrying a spare cable would be the answer for that though.
staehpj1 is offline
