Eyelets not sitting flush
I have a set of new rims that have eyelets. I started to build them today but stopped when I ran into something strange.
I noticed on the rear wheel that the spoke tension was dropping longer than I'm used to as I was stress relieving the wheel. Usually, once I get close to final tension there's not much drop unless there's some spoke windup going on. On this wheel however, the tension kept dropping every time I'd relieve stress (dropping 1 or 2 points on the Park tension meter).
Anyway, what I noticed was that a lot of the eyelets had come away from the rim. If I pull the nipple out, the eyelet can now rattle up and down. These weren't like that before lacing.
I looked at the front which was only about halfway tensioned. I grabbed some pairs of spokes and squeezed them as if stress relieving, and could see the eyelet start to work away from the rim surface.
Do you think this would be an issue long term?
Senior member
Quoted: 915 Post(s)
Liked 566 Times
Tension drop after stress relieving is expected if you are doing it right.
As for the eyelet, it looks to me like it was not properly clinched at the factory and I would be looking at warranty options.
Likes For Dan Burkhart:
Half way there
Quoted: 983 Post(s)
Liked 876 Times
What does the eyelet look like from the inner side? Perhaps the inner flange of the eyelet was defective, though since it is a lot of eyelets I'd suspect a manufacturing fault. Personally, I would stop immediately and contact the vendor to return these. I would not trust them to stay true.
You've spent good money on the rims and spokes and are also spending a lot of time to build these wheels that will always be iffy. Send them back and buy a different brand.
aka: Dr. Cannondale
Quoted: 2103 Post(s)
Liked 3,207 Times
Bad rim eyelets, return the rims.
What’s with the chewed up nipples?
Quoted: 5368 Post(s)
Liked 1,807 Times
This is characteristic of too much spoke for the rim. Namely either too much tension, too stout a spoke, or, usually, both in concert.
I can't offer an opinion without knowing the details including what rim, what spokes and tensions, and your stress relieving process.
It helps to remember that stress relief is about bringing the spokes beyond yield, but can also bring the rim beyond yield, pulling the upper surface in and allowing the eyelet to settle.
It's easy to blame the rim, and that may well be the case, but go back and review the process.
Liked 1,807 Times
FWIW these problems weren't rare BITD when folks started using thicker spokes and/or higher tensions on the lighter rims more common back then.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FB
Chain-L site
Quoted: 3730 Post(s)
Liked 1,051 Times
By over stressing and distorting the rim. It's a different outcome of the same issue that causes stress cracks near spoke holes.
I doubt any modern anodized rim can deflect that far without first cracking. The aluminum is too hard for that.
Liked 1,807 Times
I can see how an unanodized thin wall rim from the '80s could distort enough to push the rivet up, but it doesn't look like the rim material is pushing up on the rivet. There's just a gap.
Until the OP provides details, including an explanation of his stress relief process, we can only throw stuff against the wall to see what sticks.
However, having seen similar failures over the years, I admittedly tend to blame mechanics more than I do metal. However, I don't have enough info to offer an opinion, just a possibility to consider.
Lastly, there's no point debating. It's up to the OP to consider the possibilities posted here, factor those with his own experience and draw his own conclusions.
Liked 1,051 Times
If you note, i prefaced the post saying that the details matter. I was simply offering a possibility to consider.
Likes For Kontact:
Liked 1,807 Times
Keep in mind that most riding loads are such that they slacken spokes, and reduce stress at the spoke holes.
Meanwhile, the stress relief process is about overloading the spokes, and as a by product doing likewise to the rim.
FWIW I've never seen an eyelet pulled out on the road, even with super light rims, but I've seen more than a few pulled out by builders.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1030 Post(s)
Liked 861 Times
This was my thought. Not to mention if a wheel can't handle stress relief by a builder, it won't be able to handle the number of stress cycles by a rider in a single ride.
These are (relatively) inexpensive and not name brand rims. I've had good luck with them in the past, but I've not seen this before.
My stress relieve process is usually to place the wheel on it's side and bounce some of my weight on the rim while spinning the wheel to do the full circumference. I'll also place the wheel in my lap, put my elbows on the rim and then grab the far side and give it a pull (hard to explain). These are 42mm wide double wall rims, so fairly stiff.
I'd say max tension wasn't ever over 130kgf while building up.
Thanks for all the replies. I'm moving on from these.
Sock Puppet
Liked 861 Times
