Shimano 105 Di2 or Shimano Ultegra Di2
Old 08-04-23, 07:49 PM
Kai Winters
Quoted: 191 Post(s)
Liked 359 Times in 207 Posts
Originally Posted by Steve B.
I have never read of any method of adjusting individual gears, just the method I described of tuning where the chain sits center on a cog, for all the cogs.
So it is a misstatement...when 'adjusting the gears' what is really being done is the rear derailleur is being aligned so the jockey pulley, and idler pulley I guess, is aligned with that particular gear so the chain isn't touching either the gear above or below...was this not understood when 'adjusting the gears' was mentioned? I suspect most of us know when this is said you are adjusting the derailleur as the 'gears' are only 'adjusted' if a spacer is used to move the cassette itself.
But I guess clarification is our friend...
One of the great benefits of electronic shifting is the ability to adjust the rear derailleur so it is precisely aligned to each gear of the cassette. A mechanical derailleur can't be adjusted this way but honestly we've used mechanical derailleurs for decades with few complaining of this inability. I've never considered it, whether possible or not, and I've been building bikes from the frame up since 5 speed friction shifters...yipes I'm old...long live 'straight blocks'
Kai Winters is offline
Old 08-04-23, 08:17 PM
Mtracer
Quoted: 160 Post(s)
Liked 193 Times in 133 Posts
I don't think anyone thought you were literally saying physically aligning the gears. Here's your original statement:
Both systems are fully configurable for shifting and I especially love the ability to tweak the rear der position for every gear on the cassette.
And again in this last post:
One of the great benefits of electronic shifting is the ability to adjust the rear derailleur so it is precisely aligned to each gear of the cassette. A mechanical derailleur can't be adjusted this way ...
What exactly do you mean by adjust "every" and "each" gear in the above statements? To me this sounds like you are saying the indexing can be fine tuned separately for each gear.
And what can you do with the Di2 that you cannot do with a mechanical in terms of adjustment? I'm not trying to argue, but twice now you've made statements that to me seem to be saying there is some way to adjust indexing individually for each gear. And if this is possible, I want to know how to do this.
If I misunderstood you and you simply mean the Di2 indexing is adjusted electronically, affecting all gears the same, similar to a cable tension adjustment, then that's fine. I simply read more into your statement than you meant.
Mtracer is offline
Old 08-05-23, 05:19 AM
Kai Winters
Quoted: 191 Post(s)
The rear derailleur on my 12 speed 105 Di2 system can be aligned for each gear on the cassette. I use the Etube app which moves the der into whatever alignment I want for each gear. The alignment is stored in the der's memory and when shifting into each gear it moves into the setting I've set it to. So the rear der is in fact individually aligned to each gear. This is not the case with a mechanical system. You align the rear der. using cable tension/spring loading in one gear to it's 'optimal' position which is then carried on with each shift. If a gear is a bit off you can adjust cable tension but by adjusting cable tension you affect all gears. Di2 does not work that way thus is individually adjustable.
In general this hasn't been an issue because the rear der, mechanical, does move in a precise location providing an efficient and quiet drive train. However as the cassette gears are closer together...11 speed, etc. the distance between the outer links of the chain are closer to the upper and lower gears. If the rear der isn't precisely adjusted and/or the cable and/or spring no longer holds the der in that exact position some rubbing sounds may occur requiring an adjustment. Most don't notice or perform enough routine maintenance that this adjustment is made.
You do have to manually set the upper/lower...high/low...limits with mechanical screws on the 105 system which is the same as all mechanical systems unlike Ultegra, etc which is done electronically.
I think this poor horse has been beaten enough and I'm done here...good luck everyone...I'm bored and moving on...
Old 08-07-23, 02:46 AM
TerryDi2C
Di2 fanatic
TerryDi2C's Avatar
Quoted: 53 Post(s)
Liked 64 Times in 41 Posts
You cannot adjust the rear derailleur for each gear separately. It is one setting for the entire cassette.
It may look like that in the app, but there is only one adjustment setting for the entire RD/cassette .
Yes, you can go through each gear and change the adjustment/indexing value with the derailleur in any position you like... but you'll be changing the same setting/value. Perhaps I'll post a video tonight... in about 10 hours.
TerryDi2C is offline
Likes For TerryDi2C:
Old 08-07-23, 07:43 AM
Mojo31
Quoted: 8617 Post(s)
Liked 5,713 Times in 3,132 Posts
I have found this to be true as well. The goal is to find the best compromise.
Mojo31 is offline
Old 09-21-23, 09:16 AM
Jughed
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 388 Post(s)
Liked 534 Times in 267 Posts
Originally Posted by Maelochs
Some of those broken cranks are Dura-Ace and some of those photos are not cranks..... but even so I would ask, what did the rider do to cause that damage? If those cranks were breaking in normal use,I'd think we'd be hearing a lot more about it ... and seeing recalls.
Probably the people saying they have heard about Ultegra breaking ... heard it from this one site, in a big circular self-reference. If someone can show me four or five other sites that discuss this phenomenon Not referencing this site ... I mean, just because it is the internet doesn't mean that we shouldn't use critical thinking and do proper research.
I cannot count how many times I have seen two dozen news reports, all based on rewrites of the same single report, and people say, "Well, it is on two dozen news sites," like that means it is true.
Where are the recalls and lawsuits?
Here you go...
Shimano to recall 760,000 Ultegra and Dura-Ace cranksets due to crash risk | Cyclingnews
Jughed is offline
Old 09-21-23, 09:28 AM
Maelochs
Maelochs's Avatar
Quoted: 7454 Post(s)
Liked 3,141 Times in 1,678 Posts
Worldwide recall to come as six injuries found in over 4,500 reported incidents of failing components .... out of 760,000 units sold.
That says a lot for Shimano.
Maelochs is offline
Old 09-21-23, 09:30 AM
Maelochs
Maelochs's Avatar
Now I have to go look at my cranks .... ugh.
Maelochs is offline
Old 09-25-23, 09:13 AM
88ss
88ss's Avatar
Quoted: 99 Post(s)
Liked 117 Times in 55 Posts
Nice thread, after reading it I hope to convert to the 105 D12 that a few of my riding buddies are using and doing well with, nice to know it is doing well for everyone else too.
88ss is offline
Old 09-25-23, 10:24 AM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1663 Post(s)
Liked 1,248 Times in 874 Posts
Originally Posted by icemilkcoffee
Do you guys even internet? How is it possible that everyone acts surprised that there are reports of Ultegra cranks breaking and bending?
I guess we all just assumed the OP was talking about the current, 12-speed generation because he is comparing 105 Di2 and Ultegra Di2?
The crank issue has only been reported for the prior 11-speed generation of Ultegra and Dura-Ace HollowTech cranks. (I am not suggesting that it is impossible for the current generation to have the same problem; I am just not aware of any reports thereof.)
SoSmellyAir is offline
Old 09-25-23, 01:22 PM
georges1
Steel is real
georges1's Avatar
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 566 Post(s)
Liked 779 Times in 512 Posts
Take the the Ultegra if you can afford it otherwise the 105 is outstanding value for money
georges1 is offline
